I think this is a special relativity question
In summary, the problem involves two spaceships traveling on the interstellar freeway, one at 0.5 c and the other at 0.8 c. The velocity-addition formula is used to calculate the speed at which the pilot of Ship A sees Ship B moving away from her, resulting in a speed of 0.5 c.
psych2012
Two spaceships are traveling on the interstellar freeway. Ship A is traveling at 0.5 c and Ship B is traveling at 0.8 c. Ship B passes Ship A. How fast does the pilot of Ship A see Ship B moving away from her? (c is speed of light)
I think the velocity-addition formula is relevant.
V = (v1 + v2) / (1 + ((v1/c) x (v2/c)))
V = (0.5c + 0.8c) / (1 + ((0.5c/c) x (0.8c/c))) = 0.93c
This answer just doesn't make sense to me which leads me to believe that one of the values should be negative, or I need to alter the formula.
I'm wondering if maybe it should be V = (0.8c - 0.5c) / (1 + ((0.8c/c) x (0.5c/c))) = 0.21c. I really don't know.
I would say you are correct, that one of the speeds should be negative.
As I read the problem, both ships have measured their speed relative to the freeway, whereas the velocity addition equation, as it is usually derived, is meant to find the speed w of a something with speed w1 measured in one frame that moves relative to another frame with speed w2, both speed being positive in the same direction. Translating this to your problem, one possibility is to map the speeds as w = v1, w1 = v and w2 = v2, with the other possibility being to swap v1 and v2. Inserting this into the velocity addition equation and isolate for v you will find that is transforms into the same velocity addition equation again, now only with a minus for either v1 or v2 depending on which of the mappings you chose.
Any other opinions? I'm wondering now if it would just be as simple as 0.8c - 0.5c = 0.3c, since the velocity-addition formula is usually used if there is a third stationary object observing the other two objects in motion, and there is no third object in this problem.
psych2012 said:
Any other opinions?
You are of course welcome to ask others to comment, but my reply was not really an opinion even if it did started out sounding like one.
Direct addition of velocities, while valid in Newtonian mechanics, is never valid in relativistic mechanics and this is true no matter if it involves physical objects or not. The essential aspect is that when you have three different inertial frames of reference that move (on a line) relative to each other you can from the knowledge of two of the speeds calculate the third using the velocity addition equation.
I apologize for suggesting that your reply was an opinion. I used your reasoning to arrive at an answer that I understand and am satisfied with. Thanks for your help.
(0.8c - 0.5c) / (1 + (0.8c/c)(-0.5c/c)) = 0.5c
FAQ: I think this is a special relativity question
What is special relativity?
Special relativity is a theory proposed by Albert Einstein in 1905 that explains the relationship between space and time. It states that the laws of physics are the same for all observers in uniform motion and that the speed of light is constant in all inertial frames of reference.
How is special relativity different from general relativity?
Special relativity deals with the effects of motion on space and time, while general relativity deals with the effects of gravity on space and time. Special relativity applies to objects moving at constant speeds, while general relativity applies to objects in accelerated motion or near massive objects like planets and stars.
What are some practical applications of special relativity?
Special relativity has many practical applications, including GPS technology, particle accelerators, and nuclear energy. It also helps us understand the behavior of objects moving at high speeds, such as spacecraft and subatomic particles.
How does special relativity impact our understanding of the universe?
Special relativity has had a profound impact on our understanding of the universe. It has helped us develop a more accurate model of space and time, and it has led to groundbreaking discoveries in physics, such as the concept of mass-energy equivalence (E=mc^2).
Can special relativity be proven?
Special relativity has been extensively tested and has been shown to accurately predict the behavior of objects moving at high speeds. However, like all scientific theories, it is constantly being refined and improved upon as new evidence and technology become available. So while we can't definitively prove special relativity, the overwhelming amount of evidence supports its validity.
