I think this is an energy problem
  • Thread starter slammedtgs
  • Tags
    Energy
In summary, the maximum height attained by the pair can be found by using conservation of energy and momentum. First, find the speed of the acrobat at height h (where the monkey is grabbed) using conservation of energy. Then, use conservation of momentum to find the new speed of the acrobat with the monkey. Finally, use conservation of energy again to find the maximum height H, with the speed at the point of the monkey as the initial speed and the final potential energy as the height H.
slammedtgs
A circus acrobat of mass M leaps straight up with an initial velocity of vo from a trampoline. As he rises, he takes a trained monkey of mass m off a perch of height h above the trampoline. What is the maximum height attained by the pair in terms of M, m, Vo, h, and g?
I tried using kinetic energy and potential energy, but get stuck when trying to figure out the height after the mass increases at an unknown height
Hi slammedtgs,
There's a bit more to this problem than using conservation of energy. While he is taking the monkey, energy is not conserved. What do you think will be conserved?
alphysicist said:
Hi slammedtgs,
Well what i was thinking was that as he is rising he's slowing down, turning kinetic energy into potential energy. As soon as he grabs the monkey he is just added more gravitational potential energy to his system, thereby slowing him down.
So if energy is not conserved we can look at the body's momentum as its rising, but how does that turn into max height?
p=MVo initially, and once with the monkey p=(M+m)(v)?
I know that max height will be when the systems velocity is zero.
slammedtgs,
We have to think of this motion in three separate parts. First the man rises to a height h; energy is conserved for this part. Then he grabs the monkey. Energy is not conserved here; grabbing the monkey is essentially a completely inelastic collision. After he has the monkey, he rises to a maximum height; during this part energy is conserved.
So use conservation of energy to find his velocity at height h. Then use conservation of momentum to find his new speed after he grabs the monkey
So this is what I was about to come up with, but I am not sure if it is correct.
(.5)(m)(v*v) v= sqrt(2*g*h) so. (M+m)(sqrt2*g*h). (m+M)(m+M)/(2*g) =H?
Am i on the right track here?
Hi slammedtgs,
I don't think so. It looks like you have about four expressions on the same line and its a bit hard to tell where one begins and another ends.
Look at the first part of the motion: the man starts with speed v0 moving upwards. Once he is at height h, what is his speed? Use conservation of energy here. What do you get for v at height h?
Later in the problem:
Now after he grabs the monkey, what is the speed of him+monkey (at the same height h)? Energy is not conserved during the grab, but momentum is.
After that, the man+monkey rises to a maximum height H. As you said, energy is conserved during this process. You know their initial speed and height for this second part of the rising motion, so you can use conservation of energy to find the maximum height.
The velocity at pt. H would be Sqrt(2gh)
so P=mv at H would give (M+m)*(sqrt(2*g*h)
Kinetic Energy would be (.5)*(m+M)(2*g*h)
So when H is max V is zero
0 +MGH = Etotal
Etotal/MG= H? Is that another way of looking at it?
slammedtgs,
First we need to find the speed at point h (where the monkey is) not point H (the highest point.
From conservation of energy, if we set the height to be zero at the starting point, the initial energy (which is all kinetic) equals the energy at height h (which is kinetic and potential). So we have:
[tex]
KE_i = KE_f + PE_f
[/tex]
or
[tex]
\frac{1}{2} M v_0^2= \frac{1}{2} M v^2 + M g h
[/tex]
Solving this for the speed v at height h gives:
[tex]
v = \sqrt{v_0^2 -2 g h}
[/tex]
So this is his speed right before he grabs the monkey. Multiplying this by his mass would give his momentum at that point.
After he has grabbed the monkey, the momentum is equal to their total mass times their new speed. Since these two momentums have to be equal, what is that new speed?
V at the point of the monkey is Sqrt(v0^2-2gh)
So, (M+m)(v?) = M*Sqrt(v0^2-2gh)
M*Sqrt(v0^2-2gh)/(M+m) will give (V?)
So then take this new speed and use it in a new conservation of energy Equation?
[tex]
KE_i = KE_f + PE_f
[/tex]
(.5)(Mtotal)(v?) + MGH = Etotal
(0)+MHG = Etotal
Etotal/MG should give the max height right?
Hi slammedtgs,
For the new conservation of energy equation, you have the height H in the final potential energy, where H is the answer they are looking for. So that part is good.
However, the initial potential energy right after the monkey is grabbed is not 0, because they are at height h. So you need another potential energy term.
Remember that the speed in the kinetic energy is squared, and this equation is not quite right. You know that the final kinetic energy is zero (for the maximum height) so the energy equation will follow:
[tex]PE_i + KE_i = PE_f[/tex]
where the speed you found from the conservation of momentum equation does go in [itex]KE_i[/itex] as you said. The initial potential energy is at height h, and the final potential energy is at height H.
Related to I think this is an energy problem
1. What is an energy problem?
An energy problem refers to any issue or challenge related to the production, distribution, or consumption of energy. This can include concerns about sustainability, affordability, efficiency, and accessibility of energy sources.
2. What are some examples of energy problems?
Examples of energy problems include climate change caused by the use of fossil fuels, limited access to electricity in developing countries, and the high cost of renewable energy technologies.
3. Why is solving energy problems important?
Solving energy problems is important because energy is essential for human survival and wellbeing. It is also crucial for economic development and addressing global issues such as climate change and poverty.
4. What are some ways to address energy problems?
There are various ways to address energy problems, including investing in renewable energy sources, improving energy efficiency, promoting conservation and sustainable behaviors, and implementing policies and regulations to reduce the use of fossil fuels.
5. What role do scientists play in solving energy problems?
Scientists play a crucial role in solving energy problems by conducting research and developing innovative technologies and solutions for sustainable energy production and consumption. They also provide evidence-based recommendations to policymakers and educate the public on energy issues.
