I want to build my telescope any advice ?
In summary, Dave has created a blueprint for a telescope that is adjustable in both length and aperture. He is also interested in feedback from others to help him fix any bugs in his design.
ranroun
hi..
i am into astronomy as a hobby and i noticed as i was looking for telescopes that the telescopes u buy are not that flexible and that u have to buy a telescope for each type of observong ( to have the best quality of course).
so i made up my mind to build my own telescope(a refractor) that has 2 variables :
1)the lenth of the tube , and thus the focal lenth (because i can put different lenses in it)
2)the apreture (as in put a diaphragm that would reduce or maximize the amount of light i get).
i made blueprints and all , and before i start id like to see if any of u has any additional information or modifications to give me that would let me fix my model if it has any bugs.
start by giving me ur opinion about wat i said and ill post more for more details.
thx in advance , and long live astronomy :biggrin:
Astronomy news on Phys.org
Telescopes do this. For low vis objects (almost all of them), you use the scope at full aperature, but for very bright objects such as planets and the Moon, you can put a cap on the objective end of the scope to reduce the light.
Why? Why not just get different lenses?
It might be a good idea to post your blue prints.
Further to Dave's comments:-
You really should use the maximum of your telescope's aperture as much as you can - the resolving ability (How fine the detail you can make out) of a telescope is directly dependent on the aperture - more aperture = higher resolving (finer detail) ability
You can get about 2x magnification per mm of objective diameter - so for example, if you are using 100x magnification - don't stop the scope down to less than 50mm diameter, otherwise you will impact on the scope's resolving power.
If you really want to dim the image more than that - a variable polarising filter is the best way to go
If you want to lengthen the focal ratio - use a barlow lens
If you simply want to vary the magnification - then as dave says, just get a selection of eyepieces - magnification is a direct function of the focal length of the telescope's objective lens, divided by the focal length of the eyepiece you use.
So - a scope with focal length of say, 1000mm, will give you 40x if you use a 25mm eyepiece (1000/25 = 40)
To get, say 100x from the same telescope - just use a 10mm eyepiece (1000/10 = 100)
4mm eyepiece - 1000/4 = 250x
etc, etc...
Ambitious project. My biggest concern would be the handling and mounting of interchangeable lenses. The primary lens is the most critical piece of a telescope and interchangeable lenses are just asking to get damaged. In addition, it would be tough to securely mount them and keep them properly aligned, while keeping them interchangeable.
I don't really see an advantage for interchangeable lenses over just having two fully separate optical tubes - and that has some big advantages, such as the ability to autoguide when you piggyback them.
I just bought a big SCT - they are pretty versatile in that you can shorten the focal length by adding a focal reducer or lengthen it by adding a Barlow. But for short focus deep-sky, I'll likely end up piggybacking a refractor on it.
Russ is right. I owned a series of telescopes over the years, but about 20 years ago I decided to optimize, and I bought an Astro-Physics 6" f:8 APO refractor for a main scope and a Vernonscope 80mm f:5.6 APO as a finder/guidescope. Of course that 'scope can be used on it's own, too, if I don't feel like hauling out the "big gun". I have 6" Schmidt-Newtonian for really wide-field stargazing, but sold my catadioptic scopes. I am hooked on refractors. You might wonder how I can use such a short APO as a guidescope, but it's pretty easy with a well-mounted Barlow and a short f/l guiding ocular. Of course, when you put in the 2" mirror diagonal and a 55mm 2" ocular, that little scope is a wide-field wonder. The cost of a refractor is mostly in the objective, not the tube and focusser, so it won't cost you much more to have two entire optical tube assemblies AND you can use them together if you choose them properly. Then, spec out a mount that will support the weight of both of them securely.
FAQ: I want to build my telescope any advice ?
What materials do I need to build a telescope?
To build a telescope, you will need a primary mirror, secondary mirror, eyepiece, focuser, telescope tube, and mount. You can purchase these materials or make them yourself with proper tools and knowledge.
What type of telescope should I build?
The type of telescope you should build depends on your intended use and budget. Refracting telescopes use lenses and are good for viewing planets, while reflecting telescopes use mirrors and are better for deep space objects. Dobsonian telescopes are a popular DIY option due to their simplicity and affordability.
Do I need any special tools to build a telescope?
Yes, building a telescope requires some specialized tools such as a hacksaw, drill, files, and a mirror grinding kit. You may also need a level, ruler, and other basic tools for construction.
How difficult is it to build a telescope?
Building a telescope can be a challenging but rewarding project. It requires precision and attention to detail, as well as some basic knowledge of optics and mechanics. However, with proper research and guidance, anyone can successfully build a telescope.
Where can I find resources and advice for building a telescope?
There are many online resources and forums dedicated to telescope making, where you can find step-by-step guides, tutorials, and advice from experienced telescope builders. You can also join a local astronomy club or attend workshops and classes to learn more about telescope making.
