Platoon88
- 3
Hi,
Might sound like a homework problem but since it isn't I posted it here.
I currently live in a small 22m^2 student apartment. Heating is included in the rent, in the shape of a basic water radiator located below the window towards the wall (dont worry, there is nothing standing towards it preventing the air from circulating). Me, and several others do however find that during the winter it gets too cold, the landlords reply is that we should put on a second pullover...
Adding an electrical radiator would work, but since the water radiator is designed to only keep the surrounding temperature around the radiator at a certain level, me increasing it would force me to pay the entire heating bill (plus the one for the water radiator which is the same for everyone, included in the rent).
As I am studying towards a msc I have had a few courses in heat transfer, thermodynamics etc.
I know that increasing the air flow increases the heat transfer coefficient etc. Would it be possible to fool the water radiator to believe that the room is colder than it actually is by placing a fan that blows air through the water radiator (it doesn't really look like this, but close enough http://tinyurl.com/cz6uqtn as you see it is "open" on the sides allowing me to blow air "through" it). By this I would force the radiator to put out more heat.
Hypothesis:
1, The warm air would spread better around the room which is good (on the landlords HP it says that the radiator might experience the room temperature warmer than it is if the air circulation is bad)
2, I would replace the warm air from inside the radiator faster with colder air fooling the settings of the radiator (I have no extensive experience with radiators but one would think that they are designed to "believe" that the room temperature is X when the temperature inside the radiator is X+Y)
3, The higher heat transfer coefficient would remove heat from the radiator itself faster
Possible Problem: I do not know where the "sensors" are located
Question: What do you think? Will a basic fan (think the big ones you have on your desktop in the summers) make any difference? Just a few degrees or even a single degree would be wonderful.
The electricity cost for keeping the fan running is irrelevant.
Thank you for reading, hopefully someone has encountered a similar problem or perhaps knows anyway. In worst case I'll take it up with the professor :D
Hypothesis:
