balraj
- 1
Sir, I want to make a brushless motor out runner type. Body is 2.5 thick with 25 cm outer dia. It's weight is 25kg. Shaft of stator is 4cm in dia. How much watt is required for rotating this outer body at speed of 12000 rpms.
A brushless motor uses a series of permanent magnets on the rotor and electromagnets on the stator to generate motion. Unlike traditional motors with brushes, brushless motors use electronic commutation to switch the electromagnets on and off, resulting in a more efficient and reliable design.
Brushless motors have several advantages over traditional motors with brushes. They are more efficient, have a longer lifespan, and require less maintenance. They also have a higher power-to-weight ratio and can operate at higher speeds.
The materials needed to make a brushless motor include permanent magnets, electromagnets, a rotor, a stator, bearings, and a controller. The exact materials and specifications may vary depending on the specific design and application of the motor.
Yes, it is possible to make a basic brushless motor at home with the right materials and tools. However, it requires advanced knowledge and skills in electrical and mechanical engineering. It is recommended to consult professional resources and follow safety protocols when attempting to make a brushless motor at home.
Brushless motors are commonly used in a variety of applications, including electric vehicles, drones, power tools, household appliances, and industrial machinery. They are also becoming increasingly popular in robotics and automation due to their efficiency and precision.
