I with a Hooke's law experiment I did
In summary, the conversation discusses an experiment where the stretch of a spring was measured with the addition of masses in increments of 50g. The resulting graph of Force against length stretched does not go through the origin and is not linear for forces below 1N. The goal is to prove F=kx and calculate the spring constant k. Suggestions are given for finding the slope of the linear line and addressing non-linear data points. Feedback is given on the accuracy of the experiment, including a correction to the axis label and the importance of interpreting the slope correctly.
addy360
I did an experiment where I measured the stretch on a spring from its initial position when masses were added on the end of it, in increments of 50g. I plotted a graph of Force against length stretched and the graph does not go through the origin, or at least it is not linear for forces below around 1N.
My problem is I want to prove F=kx, so I need to calculate the gradient of a linear line which goes through the origin to get the spring constant k, though if you just look at the linear part of my graph it has a F intercept of 1, so I get F=kx+1.. just a little confused on how to get the spring constant, anybody out there know how to help out?
Here is a table with my data and my graph:
http://imgur.com/a/vJUi0
thanks!
You need to find some way to estimate the slope from the data of course.
Normally you'd look for a "best fit" line.
If the data is obviously non-linear for small forces, perhaps it is not obeying Hook's law in that part and you can safely ignore those points? It will depend on your course.
If you ignore them - will the best-fit line go through the origin?
Usually is the theory says a line will go through the origin and the data does not, though, it means there is some systematic error in the measuring process. This can come from badly calibrated equipment or incomplete control over variables.
[looking at your data]
Your work is very good - you have mislabelled the vertical axis though ... what you have plotted is the mass vs extension ... so the theoretical equation for your line should be m=(k/g)x (why?) [hmmm... unless you are using g=10N/kg?]
It looks like the first couple of masses were needed to knock out the kinks in the spring and your offset just reflects that this is not an ideal spring. You'll need to make a note about why you are neglecting the earlier points.
You did avoid a number of mistakes that people usually make - like you did not force the line through the origin (very good), you did not use any of your data points to compute the slope (excellent) and you did put your working on the graph itself (good).
You need to correct that axis label (if needed) and add a title. Make sure you correctly interpret the slope.
thank you for your feedback! but I plotted force on the vertical axis, which I got from multiplying the masses by the acceleration of gravity (F=ma). What leads you to think I plotted mass?
For F=1N for m=0.1kg, you must have used g=10N/kg ... that's OK.
I'm used to 9.8N/kg... your value of k will be out but the important lesson is about the linearity.
No worries.
BTW: you could have plotted m vs x and still found the slope as k/g then multiplied by g to get k.
FAQ: I with a Hooke's law experiment I did
1. What is Hooke's law and how does it relate to your experiment?
Hooke's law is a principle in physics that describes the relationship between the force applied to an object and the resulting displacement of the object. In our experiment, we used Hooke's law to determine the spring constant of a spring by measuring the force required to stretch the spring a certain distance.
2. What materials and equipment did you use in your experiment?
We used a spring, a ruler, a weight scale, and various weights in our experiment. The spring was attached to a fixed surface, and the weights were added to one end of the spring while the other end was held in place. The ruler was used to measure the displacement of the spring, and the weight scale was used to measure the force applied to the spring.
3. What were the steps you followed in your experiment?
The steps we followed were:
  1. Set up the equipment and materials as described above.
  2. Add different weights to the spring and measure the resulting displacement of the spring.
  3. Record the force and displacement values for each weight added.
  4. Plot the force vs. displacement values on a graph.
  5. Calculate the slope of the graph, which is equal to the spring constant.
4. What were your results and how did they compare to the expected outcome?
Our results showed a linear relationship between force and displacement, as expected by Hooke's law. The slope of our graph gave us the spring constant, which was within the expected range for the type of spring we used. However, there may have been some experimental errors that affected our results.
5. What are the applications of Hooke's law in real life?
Hooke's law has many practical applications, including in the design of springs for various mechanical systems such as car suspensions, door hinges, and mattresses. It is also used in the construction of buildings and bridges to ensure they can withstand certain levels of stress and strain. Other applications include in medical devices, such as prosthetic limbs and braces, and in the field of material science to study the behavior of different materials under stress.
