I with this question about vectors
  • Thread starter Thread starter lioric
    Vector Vectors
The discussion revolves around solving a vector problem involving two boats, P and Q, with specific initial positions and velocities. Participants emphasize the importance of using vector diagrams to clarify the problem, particularly in understanding the direction "northeast." The calculations for the positions of both boats over time are discussed, with a focus on determining when Q is northeast of P. There are multiple requests for clarification and corrections regarding arithmetic mistakes in the calculations, highlighting the complexity of the problem. Ultimately, the resolution hinges on correctly expressing the relative positions of the boats as functions of time to find the desired intersection point.
  • #51
OK. So what, if any, value of ##t## makes Q-P point NE? That answer is the solution to your problem. Although the problem may want to know what time of day is it, given it started at noon.
  • #52
Multiply by sin45?
  • #53
lioric said:
Multiply by sin45?
That answer makes no sense at all. You are asked for a value of ##t## and you reply "multiply by sin45".
  • #54
sorry
well in order to be 45 degrees Q has to have the same amount of x and y values away from P
eg: if Q if 3i away from Q it should also have 3j away from P
But you have to understand this that I'm trying but I don't know how to use this information to find a t value for this problem
I do understand that Q-P was to find the distance between P and Q at a certain time t
But I don't know how to find t when Q is 45 degrees to P
I'm just having this problem because I'm not used to doing vector type questions.
If it was simple distance and time I could cope.
So please lend me a hand
Thanks to you I can this far and I really appreciate it
  • #55
From post #42:
lioric said:
Now Q-P
lioric said:
(2+t)i + (10t-15)j
From post #43:
LCKurtz said:
Yes. Finally! Now, for what t does that point northeast? What do you require about the components for a vector to point northeast?
What relationship has to exist between the i and j coordinates for a vector to point northeast?
  • #56
Mark44 said:
From post #42:From post #43:
They have to be positive and same magnitude
  • #57
You could have answered that way back when I asked it in post #43.
So, what value of ##t##, if any, makes that happen for Q-P?
  • #58
From post #42:
lioric said:
Now Q-P
(2+t)i + (10t-15)j
So what do you get?
  • #59
Mark44 said:
From post #42:So what do you get?
Ok I get what your saying
As I mentioned before I'm having such a hard time due to vector with i & j form
I know if it's pointing to NE the values have to be positive and same
I just don't know how to change it or in other words the proper way to do the sum when it comes to vectors
I'm not clear about the "protocol " to change the i and j in relation with time
  • #60
Put ##t=1## in your vector. Does it point NE? How about ##t = 2## or ##t=3## etc. The question is, is there any value of ##t## that gives a vector that points NE.
  • #61
I get it now
I have to find out by changing t which changes the values inside the bracket
Hence giving magnitude to i & j
I completely understand
Thank you very much
(2+t)i + (10t-15)j
2+t=10t-15
t-10t=-2-15
-9t=-17
t=-17/-9
t=1.889
  • #62
So that's 1hr 53min 20sec past noon
Thank you very much
And thank you for being so patient with me
  • #63
You are welcome. I'm curious what math courses you have had or are taking now.
  • #64
Non actually
I just find questions here and there and try to attempt them
