I with this question about vectors
In summary: That and the now changed original position of Q. So now you can show us how you calculate Q and P's positions at time t. Then think about what must be true about Q-P for Q to be northeast of P at time t.
  • #36
Are you asking me to subtract the new coordinates of P and Q or the initial coordinates given in the question?
  • #37
lioric said:
I m very confused
In post #25 it seems that the vectors are in the format that you asked (...)i+(...)j and you asked me to simply them. So I expanded them and now your asking me to revert them back again.
OK, never mind about the i and j comments.
This thread is getting very jumbled. There are multiple arithmetic errors and/or typos. In post #25 you have an arithmetic mistake in the new position of P. Then in post #32 you carried the same mistake through. Also in post #32 you dropped the ##t## in the calculation of Q-P, as I told you in post #33. Fix those. Once you finally get Q-P correct, with a ##t## in it, it is a simple one more step to finish your problem.
  • #38
That's what I was clarifying in post 36
The initial P and Q position vectors given in the question has no t in it
So which P and Q are you referring to?
Is it the answers on post 25?
  • #39
Think about the problem you are trying to solve. You are given original positions P and Q and their velocities. They are moving. Then you are asked at what time ##t## is Q northeast of P. So you need their positions at time ##t## don't you? So you need to know for what ##t## does Q-P point northeast. Fix your arithmetic and show Q-P as a function of ##t## and you are almost done.
  • #40
Ok
Let's think here
I'm just trying to clear my confusion please do tell if I'm thinking right
Let's keep the vector situation and go to a simpler linear one
Let's say P is on (1,1) on a grid
And Q is on ( 5,-5) on the same grid
P is moving on positive x-axis (to the right) at let's say 1 unit/s
And Q is moving in the positive y-axis (upward) 1 unit/s
Let's say the question is asking to find the time that P moves east of Q
Is this the same or similar sort of thing?
  • #41
lioric said:
Ok
Let's think here
I am not going to go off on another tangent with you. You have understood the problem well enough to draw a picture long ago in post #19. Just finish the problem as I have suggested to you.
  • #42
If I understood I wouldn't ask
But from what I have gathered and from the things you have asked me to do this is what I came up with
P initial position (i +7j) velocity (5i-5j)
Q initial position (3i-8j) velocity (6i+5j)
P new position
(i +7j)+(5i-5j)t.
(1+5t)i + (7-5t)j
Q new position
(3i-8j)+(6i+5j)t
(3+6t)i +(5t-8)j
Now Q-P
(3+6t)i + (5t-8)j - [ (1+5t)i + (7-5t)j ]
(3+6t)i + (5t-8)j - (1+5t)i - (7-5t)j
(3+6t)i + (5t-8)j +(-1-5t)i +(-7+5t)j
(3-1+6t-5t)i + (5t+5t-8-7)j
(2+t)i + (10t-15)j
Is this what you asked?
  • #43
Yes. Finally! Now, for what ##t## does that point northeast? What do you require about the components for a vector to point northeast?
  • #44
It should point to somewhere in the first quadrant meaning it should not have a bearing exceeding 90 degrees
  • #45
I would assume in this problem that the meaning of northeast means exactly northeast, that is midway between north and east.
  • #46
So that means as I said before bearing of 45 degrees
  • #47
Yes. And the question asks at what time does that happen? So...
  • #48
We have to find the time taken to make 45 degrees between P and Q
But I don't know how
  • #49
Do you know how to tell if any vector points NE? Which, if any, of the following vectors point NE?
3i - 5j
2i +3j
-i - 2j
3i + 3j
i - j
-2i + 2j
Explain how you can tell.
  • #50
3i - 5j
2i +3j
-i - 2j
3i + 3j
i - j
-2i + 2j
Ya the 3i+3j
It means the position is 3,3 on an x,y axis
The gradient of that would be 1 and that gives a 45 degrees
  • #51
OK. So what, if any, value of ##t## makes Q-P point NE? That answer is the solution to your problem. Although the problem may want to know what time of day is it, given it started at noon.
  • #52
Multiply by sin45?
  • #53
lioric said:
Multiply by sin45?
That answer makes no sense at all. You are asked for a value of ##t## and you reply "multiply by sin45".
  • #54
sorry
well in order to be 45 degrees Q has to have the same amount of x and y values away from P
eg: if Q if 3i away from Q it should also have 3j away from P
But you have to understand this that I'm trying but I don't know how to use this information to find a t value for this problem
I do understand that Q-P was to find the distance between P and Q at a certain time t
But I don't know how to find t when Q is 45 degrees to P
I'm just having this problem because I'm not used to doing vector type questions.
If it was simple distance and time I could cope.
So please lend me a hand
Thanks to you I can this far and I really appreciate it
  • #55
From post #42:
lioric said:
Now Q-P
lioric said:
(2+t)i + (10t-15)j
From post #43:
LCKurtz said:
Yes. Finally! Now, for what t does that point northeast? What do you require about the components for a vector to point northeast?
What relationship has to exist between the i and j coordinates for a vector to point northeast?
  • #56
Mark44 said:
From post #42:From post #43:
They have to be positive and same magnitude
  • #57
You could have answered that way back when I asked it in post #43.
So, what value of ##t##, if any, makes that happen for Q-P?
  • #58
From post #42:
lioric said:
Now Q-P
(2+t)i + (10t-15)j
So what do you get?
  • #59
Mark44 said:
From post #42:So what do you get?
Ok I get what your saying
As I mentioned before I'm having such a hard time due to vector with i & j form
I know if it's pointing to NE the values have to be positive and same
I just don't know how to change it or in other words the proper way to do the sum when it comes to vectors
I'm not clear about the "protocol " to change the i and j in relation with time
  • #60
Put ##t=1## in your vector. Does it point NE? How about ##t = 2## or ##t=3## etc. The question is, is there any value of ##t## that gives a vector that points NE.
  • #61
I get it now
I have to find out by changing t which changes the values inside the bracket
Hence giving magnitude to i & j
I completely understand
Thank you very much
(2+t)i + (10t-15)j
2+t=10t-15
t-10t=-2-15
-9t=-17
t=-17/-9
t=1.889
  • #62
So that's 1hr 53min 20sec past noon
Thank you very much
And thank you for being so patient with me
  • #63
You are welcome. I'm curious what math courses you have had or are taking now.
  • #64
Non actually
I just find questions here and there and try to attempt them
