1MileCrash
- 1,342
- 41
F(x) always exists and is differentiable as long as f(x) is continuous.
Do you agree?
Do you agree?
paulfr said:No, you have it wrong
Continuity and Differentiability
D => C but the converse C => D is not true
y = |x| is continuous at x=0 but not Differentiable there.
A function is Continuous ...
Informally... if you can trace its graph without lifting your pencil
Formally ...if Limit f(x) as x-> a = f(a)
A function is Differentiable if
Informally... if it can be approximated linearly (by a tangent line) at the point in question
Formally... if the Limit of the definition exists
f ' (x) = Limit as dx -> 0 [ f(x+dx) - f(x) ] / dx
Existence and Differentiability are the same thing
If I understand what you're asking, there's no connection between the lower limit of integration and the arbitrary constant.1MileCrash said:Alrighty, another question on the same subject but not from the exam.
Of course the nonelementary antiderivatives inspired that question. Is the lower limit in the integral sign of a nonelementary antiderivative kind of like the + C arbitrary constant for elementary antiderivatives?
It is always a good practice to include your name and date on any exam paper to ensure proper identification and organization.
This depends on the instructions given by the exam. If it specifically states to use bullet points, then use them. Otherwise, it is best to write in complete sentences to fully explain your answer.
This also depends on the instructions given by the exam. If it allows for the use of abbreviations or acronyms, then it is acceptable to use them. However, it is best to avoid using them unless necessary to ensure clarity and understanding.
Again, this depends on the instructions given by the exam. If it explicitly states that outside sources or references are allowed, then it is acceptable to use them. However, if the exam is meant to test your own knowledge and understanding, it is best to avoid using outside sources.
Spelling and grammar are important in any written work, including exams. It is important to proofread your answers and make sure they are free of spelling and grammar errors to effectively communicate your ideas and earn full credit. However, minor errors may not significantly affect your overall grade as long as your answers are clear and well-supported.
