Ice pond with no friction -- how to get across?
In summary, the conversation discusses the use of mass and force to achieve acceleration in a frictionless environment. The laws of motion, specifically Newton's first and third laws, are related to this scenario. It is determined that a minimum force is needed for acceleration to occur and that exhaling is not an efficient method of propulsion. The use of hockey pucks is suggested as a more effective means of reaching a destination.
lola1227
25
You find yourself trapped in the middle of the icy pond. The ice is perfectly frictionless! Fortunately, you have a bucket of old hockey pucks with you (which you don't mind losing). How can you use these pucks to get you to shore? (use all of newton's 3 laws in your answer)
Newtons Law's
1: A body in motion will stay in motion and a body at rest will stay in rest unless acted upon by an external force
2: The force acting on an object is equal to the mass of the object times its acceleration (F=ma)
3: For every action there is an opposite and equal reaction
Would we use the mass of the bucket and pucks to get a higher acceleration?
I don't understand the use of the pucks in this question?
How would the three laws relate to this?
Yes, but how?
How much acceleration do you need? (Newton 1)
haruspex said:
Yes, but how?
we don't need a specific acceleration, mass or anything. no numbers are needed for this question. All that is needed is how we would use the hockey pucks and the laws to get to shore.
I am not asking for numbers, just a qualitative statement.
That's the key statement. Why?
You get moved back with the force? So, the action of throwing forward gives and equal and opposite reaction of you moving backwards (or vice versa) which leads you closer to shore. This correlates with Newton's third law?
And there's no friction acting in the way?
Likes berkeman
Enough acceleration to get mass moving? F=ma so, enough acceleration for the force to be great enough to move?
Right. Since there is no friction, it takes almost no force at all to get you there, it's just that more force will get you there faster. SO ... throw one puck and you get there in a while, throw them all one after another and you get there a lot more quickly.
How much is that? Is there a minimum?
Oh ok! Then the first law, since you're already moving with the force, since you're in motion you would stay in motion? and when starting off you're still so you would remain still, until you start throwing the hockey pucks (an external/unbalanced force) which is how Newtons first law comes into place?
Likes berkeman
Force has to be greater than 0? Because when we do f/m=a the force has to bigger than 0 to get an acceleration?
Likes hutchphd and berkeman
Yes. If the ice is completely frictionless you only need to get some movement.
No need to waste pucks andor buckets : turn head one way, inhale ; turn the other way, exhale.
It's largely irrelevant in which direction you face when inhaling as the air will stream in from all directions. Only exhaling will produce thrust. Exhaling is a really inefficient propulsion method, however, and clearly the problem statement asks about using hockey pucks.
Related to Ice pond with no friction -- how to get across?
1. How can someone cross an ice pond with no friction?
There are a few different methods that can be used to cross an ice pond with no friction. One option is to wear special shoes with spikes or crampons that can grip onto the ice. Another option is to use a sled or other object to slide across the ice. Some people may also choose to crawl or slide on their stomachs to reduce the amount of friction.
2. Is it possible to walk on an ice pond with no friction?
Yes, it is possible to walk on an ice pond with no friction, but it can be difficult and dangerous. As mentioned before, special shoes or equipment may be necessary to grip onto the ice. Additionally, it is important to move slowly and carefully to avoid slipping or falling.
3. What happens if someone falls on an ice pond with no friction?
If someone falls on an ice pond with no friction, they may slide or glide across the surface until they come to a stop. This can be dangerous, especially if the pond is large or there are obstacles in the way. It is important to be cautious and aware of one's surroundings when attempting to cross an ice pond with no friction.
4. Can someone use any type of object to slide across an ice pond with no friction?
Not all objects will work for sliding across an ice pond with no friction. Objects with a smooth, flat surface may work best, such as a sled or a piece of cardboard. It is important to test the object on a small section of the ice before attempting to use it to cross the entire pond.
5. How can someone safely stop while sliding on an ice pond with no friction?
To safely stop while sliding on an ice pond with no friction, it is important to have a plan in place before starting to slide. One option is to have a designated stopping point, such as a pile of snow or a designated area of rough ice. Another option is to have someone else ready to help stop the sliding person by catching them or using a rope to slow them down.
