Ice Skating conservation of momentum (conceptual problem)
In summary, the skaters have different masses and move in opposite directions with different speeds. Their skates are identical, so any kinetic frictional forces acting on them can be ignored. Once they separate, the magnitudes of their accelerations are equal and skater 1 glides twice as far as skater 2.
Physicscct
Two ice skaters have masses m1 and m2 and are initially stationary. Their skates are identical. They push against one another, as in Figure 7.11, and move in opposite directions with different speeds. While they are pushing against each other, any kinetic frictional forces acting on their skates can be ignored. However, once the skaters separate, kinetic frictional forces eventually bring them to a halt. As they glide to a halt, the magnitudes of their accelerations are equal, and skater 1 glides twice as far as skater 2. What is the ratio m1/m2 of their masses?
m1v1 + m2v2 = m1vo1 + m2vo2
v = x/t
At the beginning, the skaters are stationary:
m1v1 + m2v2 = m1(0 m/s) + m2(0 m/s)
since distance has doubled for skater 2:
m1(x/t) + m2(2x/t) = 0 N(s)
Factoring out velocity
(x/t)(m1 + 2m2) = 0
Therefore, m1/m2 = 1/2
What did I miss?
Physicscct said:
What did I miss?
Is momentum conserved when the external force of friction acts on the skaters? You are told that the magnitude of the skaters' acceleration is the same. Is that important?
For future reference: If you cite a figure, please post it.
Same t?
Yes, momentum is always conserved. I don't know how acceleration is useful though, other than proving that the force of friction on each person is different.
haruspex said:
Same t?
They have different times to come to a stop, as haruspex helped me realize. I just don't know the relationship between both times.
Would it be a 2:1 relationship based on the 2x displacement?
That would mean that m1/m2 = 1
Momentum is not conserved when there are external forces acting on the center of mass. Here, friction is an external force acting on the CM, therefore momentum is not conserved.
Why? Write some equations down. First you need to figure out the ratio of the speeds of the two skaters. You are supposed to neglect friction as the two push against each other, therefore the net force acting on one skater is the force exerted by the other skater. How can you use this fact to find the skaters' ratio of speeds at the time they separate?
It's a matter of using the equation that has the right combination of variables.
Of distance, acceleration, time, initial velocity and final velocity, which are you trying to find and which three do you know? Pick the SUVAT equation with those four.
Related to Ice Skating conservation of momentum (conceptual problem)
1. How does the conservation of momentum apply to ice skating?
The conservation of momentum states that the total momentum of a system remains constant in the absence of external forces. In the case of ice skating, the skater's momentum is conserved as they glide across the ice. This means that the skater's initial momentum before pushing off is equal to their final momentum after they have completed their movement.
2. Why is it easier to turn while ice skating compared to walking?
When walking, we use friction between our feet and the ground to push off and change direction. However, when ice skating, there is very little friction between the skates and the ice. This means that the skater can easily change direction by applying a force in the desired direction, without the resistance of friction.
3. How does the law of conservation of momentum explain the movement of a spinning skater?
The law of conservation of momentum applies to spinning skaters as well. When a skater performs a spin, they are redistributing their mass closer to the axis of rotation, causing their moment of inertia to decrease. This results in an increase in their angular velocity, while their linear velocity remains constant, thus conserving their momentum.
4. Can the conservation of momentum be broken while ice skating?
No, the conservation of momentum is a fundamental law of physics that applies to all systems. While external forces can affect the momentum of a skater, the total momentum of the skater and the ice they are skating on will always remain constant.
5. How does the conservation of momentum apply to a collision between two ice skaters?
In a collision between two ice skaters, the total momentum of the system will remain constant. This means that the sum of the initial momentums of the two skaters will be equal to the sum of their final momentums after the collision. This can explain why one skater may experience a change in direction or velocity after colliding with another skater.
