Idea for Aqueous Homogeneous Reactor
In summary, An Aqueous Homogeneous Reactor (AHR) is a type of nuclear reactor that uses a homogeneous mixture of nuclear fuel and coolant. The fuel is dissolved in the coolant, typically water, and there is no solid fuel present in the reactor core. AHRs work by using a solution of fuel and coolant that is circulated through the reactor core, with the heat from the fission reactions being used to generate electricity. They have advantages such as being able to use a wider range of fuels and operating at lower pressures and temperatures, but also face challenges with radioactive waste management and maintaining stability. Currently, there are no AHRs in commercial operation, but there have been research and experimental AHRs in the past, such
Ahmed Shaker
How would a super-critical heavy water cooled and moderated two fluid aqueous homogeneous reactor with nitrate fuel work?
Silicon carbide or alumina can be used as cladding for the internal seed core and blanket walls, with the silicon carbide on the blanket wall cladding stainless steel and the silicon carbide on the the seed walls covering Zircaloy.
The nitrate base should remove the corrosion issues of sulfate fuel solutions, and allow thorium as thorium nitrate solution to be held in the blanket instead of being suspended as oxide particles.
So how would this reactor fare in terms of economics and lifetime?
You don't need to bend over backwards for this, just curious.
There are many problems with your idea. Mainly that it is the most nightmarish combination of engineering and nuclear conditions one could possibly imagine for any reactor design while offering no advantage over other designs.
As a fellow forum user, I am not an expert in nuclear reactor design, but I can offer some insights based on my understanding of the concept you described.
Firstly, the use of super-critical heavy water as a coolant and moderator is a relatively new concept that is still being researched and developed. This type of reactor is expected to have higher thermal efficiencies and better neutron economy compared to traditional light water reactors, which could potentially lead to lower operating costs and longer lifetimes.
The use of nitrate fuel also has its advantages, as it eliminates the corrosion issues associated with sulfate fuel solutions. Additionally, the use of thorium as a fuel source is promising as it is more abundant and potentially more efficient than uranium.
However, the use of silicon carbide and alumina as cladding materials may increase the initial construction cost of the reactor. These materials have high melting points and are more difficult to work with, which could also increase maintenance costs over the lifetime of the reactor.
Overall, it is difficult to predict the economics and lifetime of this type of reactor without more detailed information and data. It will likely depend on factors such as construction and operation costs, fuel availability and prices, and regulatory considerations.
In conclusion, while the concept of a super-critical heavy water cooled and moderated two fluid aqueous homogeneous reactor with nitrate fuel shows potential, further research and development is needed to fully understand its economic viability and lifetime.
Related to Idea for Aqueous Homogeneous Reactor
1. What is an Aqueous Homogeneous Reactor?
An Aqueous Homogeneous Reactor, also known as an AHR, is a type of nuclear reactor that uses a homogeneous mixture of nuclear fuel and coolant. This means that the fuel is dissolved in the coolant, typically water, and there is no solid fuel present in the reactor core.
2. How does an Aqueous Homogeneous Reactor work?
An AHR works by using a solution of fuel and coolant that is circulated through the reactor core. The fuel undergoes nuclear fission, releasing energy and creating new elements. The heat from the fission reactions is used to heat the coolant, which is then used to generate steam to power a turbine and produce electricity.
3. What are the advantages of using an Aqueous Homogeneous Reactor?
One advantage of AHRs is that they can use a wider range of fuels, including thorium, which is more abundant than uranium. They also operate at lower pressures and temperatures compared to traditional nuclear reactors, making them potentially safer and less expensive to build and maintain.
4. What are the potential challenges of using an Aqueous Homogeneous Reactor?
One challenge of AHRs is that they produce a higher amount of radioactive waste compared to other types of reactors. The waste is also more difficult to handle and store due to the liquid form. There may also be challenges with maintaining the stability of the homogeneous mixture and controlling the nuclear reactions.
5. Are there any Aqueous Homogeneous Reactors currently in operation?
Currently, there are no AHRs in commercial operation. However, there have been several research and experimental AHRs built and operated in the past. One notable example is the Molten Salt Reactor Experiment (MSRE) that operated in the 1960s and used a molten salt mixture as the fuel and coolant.
  • Nuclear Engineering
9K
