Ideal gas law, Find the Temperature of the container?
In summary: Good job!In summary, the problem involves a cylindrical container with a lid held in place by atmospheric pressure. The lid is pulled off with a force of 220N at an atmospheric pressure of 101kPa. To find the temperature of the enclosed gas, we need to consider the forces acting on the lid and use the ideal gas law (PV=nRT). Using a free body diagram, we can identify the atmospheric pressure and the pressure of the gas inside the container. By applying the force equilibrium equation, we can calculate the pressure of the gas on the lid. We can then use the ideal gas law to find the number of moles of gas. Finally, we can plug these values into the ideal gas law to find the temperature
sliperyfrog
27
[/B]
There is a lid on a .25m diameter, .30m tall cylindrical container enclosing .021kg of air. The lid is held in place solely by atmospheric pressure. It take 220N of force to pull of the lid at an atmospheric pressure of 101kPa. What is the Temperature of the enclosed gas.
PV =nRT
So got the volume of the container by doing .3m * pi * (.25m/2)^2 which is .0147m^3 than I got the density of the container doing (.021kg/.0147m^3) = 1.43kg/m^3
At this point I am lost I don't understand what to do with the 220N force on the lid or how to get the pressure of the inside of the container.
Hello and welcome to PF!
It will help to identity all forces acting on the lid (including the directions of these forces).
The only force on the lid is the atmospheric pressure which makes a 220N force downwards on the container. I don't understand how that helps find the temperature of the gas.
There can't be just one force on the lid. Otherwise, it would be accelerating . Actually, there are three forces acting on the lid, and the gas is at a pressure below atmospheric pressure. Can you identify the 3 forces from a free body diagram?
How would there be three forces Ii the lid is held in place solely by atmospheric pressure, wouldn't the only the only to force be the atmospheric pushing down on the lid and the pressure inside pushing upward to keep it in place.
The problem statement isn't very clear. What they mean is that the lid is like a piece of rigid cardboard sitting on top of the rim of the cylinder, and held in place by atmospheric pressure. The pressure inside the cylinder is less than atmospheric, so the rim of the cylinder is pushing upward on the lid. So there are initially three forces acting on the lid: atmospheric pressure pushing down, the gas pressure inside the cylinder (less than atmospheric) pushing up, and the rim of the cylinder pushing up.
When you apply an additional upward force of 220 N, you are just able to separate the lid from the rim. This tells you that the rim force on the lid initially was 220 N.
But, how is the force on the lid connect to temperature of the gas inside the container? I can't use PV=nRT because I don't know the moles or pressure of the gas. I don't see a way to get the pressure of the gas and getting to moles is probably not possible.
You can get the pressure from the information I discussed. If the net downward force exerted by the atmosphere on the lid is equal to the atmospheric pressure times the cross sectional area of the cylinder and the upward force exerted by the rim of the cylinder on the lid is 220 N, what is the upward force exerted by the gas on the lid (neglecting the weight of the lid, and assuming it is in force equilibrium)? What is the pressure exerted by the gas on the lid?
Regarding the number of moles of gas, what do the words ".021kg of air" mean to you?
So the cross sectional area of the cylinder is pi * (.25 m/2)^2 = .0491 m^2
So the net downwards force is .0491 m^2 * 101000 Pa = 4959 N
So would the upwards force = 4959 N - 220 N = 4739 N ?
If that is the case then the pressure by the gas would be 4759N / .0491 m^2 =96920 Pa
For the moles should i just assume the molar mass of the air is 28.9 g/mol
So the moles= 21/28.9 = .727 mol
And answer to the problem would just be plugging it into the formula which is (96920)(.0147) = (.727)(8.314)T
T = 235.7 K
I haven't checked your arithmetic, but your methodology is definitely correct.
Related to Ideal gas law, Find the Temperature of the container?
1. What is the ideal gas law?
The ideal gas law is a mathematical equation that describes the relationship between the pressure, volume, temperature, and number of moles of a gas. It is written as PV = nRT, where P is pressure, V is volume, n is the number of moles, R is the gas constant, and T is the temperature.
2. How is the ideal gas law used to find the temperature of a container?
The ideal gas law can be rearranged to solve for temperature, T = PV/nR. This means that by knowing the pressure, volume, and number of moles of a gas in a container, we can calculate the temperature of the gas.
3. What units should be used in the ideal gas law equation?
The ideal gas law equation can be used with any consistent units, as long as they are all the same for each variable. However, for convenience, it is often used with pressure in atmospheres (atm), volume in liters (L), number of moles (n), and temperature in Kelvin (K).
4. Is the ideal gas law applicable to all gases?
The ideal gas law is a theoretical model that applies to all gases, but it is most accurate for gases that are at low pressures, high temperatures, and have small intermolecular forces. In real-world situations, gases may deviate from ideal behavior.
5. What are some practical applications of the ideal gas law?
The ideal gas law is used in many scientific and engineering fields, such as chemistry, physics, and thermodynamics. It is used to calculate the behavior of gases in various systems, such as in chemical reactions, weather forecasting, and gas turbine engines. It is also used in everyday applications, such as in the production of compressed air and in the design of gas storage containers.
9K
