Ideal gas-thermodynamics, thermal equilibrium
In summary, the conversation discusses the problem of finding the final temperature and total change in energy of a combined system consisting of two ideal gases separated by a partition. The gases are in thermal contact and have different values for the number of molecules, volume, temperature, and specific heat per molecule at constant volume. The final temperature is found to be (T2+T1)/2 when N1=N2, V1=V2, and Cv1=Cv2. The conversation also delves into finding the total change in energy and a quantity A, with the help of the differential change equation dH=dU+Vdp and dA=(dU+pd
oxman
Two ideal gases are separated by a partition which does not allow molecules to pass from one volume to the other. Gas 1 has: N1, V1, T1, Cv1 for the number of molecules, volume it occupies, temperature in kelvin, and specific heat per molecule at constant volume respectively. Gas 2 has: N2, V2, T2, Cv2. The two gases are in thermal contact and reach a final temperature
a) find the final temperature and the total change in energy of the combined system. Check your answer for the final temperature when N1=N2, V1=V2. Cv1=Cv2
b)Evaluate the total change ina quantity H whose differential change is dH=dU+Vdp for each component and for the entire system
c)evaluate the total change in a quantity A whose differential change is dA=(dU+pdV)/T for each component and for the entire system
U=NVCvdT
I already solved for the final temperature for part a, and when evaluated at equal N and V i got Tf=(T2+T1)/2
i am having trouble finding b and c
Note that the volume of each component as well as the entire system is constant. That means ## \frac p T = k = const ##. Use this to express both differential quantities via ## dT ##, then integrate, using the results of a) for the limits.
thanks voko, ur the man, i solved a and b since I've posted this however, i have yet to solve c, one of the TAs told me that the value "pdV" goes to 0 in the expression dA=(dU+pdV)/T however from here i am lost. i know that dQ=dU+dW and if pdV= 0 than dQ=dU, and i know that dQ=CvdT...but he said something about how this is path dependent and i need to prove that, any help?
Since ##U = cT##, where ##c## is some constant, ##dU = c dT##. ## p dV ## is indeed zero because the volume does not change. So all you have is ## dA = \frac {dU} T = \frac {c dT} T ##. I am sure you can integrate that.
thanks again voko for being the man, i did do that and i got, A=Cvln(Tf/T1) however my TA said that regardless since heat and work are path dependent i need to prove that dU=cdT since that is only applicable at certain times he said...
In #1, you gave the full expression for U. Differentiate it, paying attention to the conditions of the problem.
well in step (a) i got, Tf=(N1Cv1T1+T2Cv2N2)/(N1Cv1+N2Cv2), and for dU1=N1Cv1(Tf-T1) dU2=N2Cv2(Tf-T2)
dU=N1Cv1(Tf-T1)+N2Cv2(Tf-T2)
From here i can see there is no volume dependence, but I am not quite sure
Even if there were a volume dependence, it would not matter: all volumes are constant in this problem.
gotcha, thanks
If i wanted to solve dA=dU/T is there a way to do it without using CvdT=dQ
could i perhaps do:
dA1=dU1/T=N1Cv1dT/T then take the integral from T1 to Tf, and then do the same for dA2 and then add the two together?
That's exactly how you should solve this. All that alphabetical soup before dT/T is the constant c I mentioned earlier.
oh ok thanks alot,
essentially i will get A=A1+A2
= c1(ln(Tf/T1)+c2ln(Tf/T2) where Tf=(c1T1+c2T2)/(c1+c2)
seems ugly, but there's got to be some way in which i can clean it up
i can't say c1=c2=c can i? because N1 doesn't equal N2
That is right, they are different. All of the gas constants in this problem seem to be different.
Ok,
so final answer i should get
A=c1ln((c1T1+c2T2)/(c1+c2)-T1)+c2ln((c1T1+c2T2)/(c1+c2)-T2)
i don't see a way to break this up further or clean it up other than writing it as ln(Tf/T)
thanks again for being so helpful, you truly are the man
You are welcome.
Your TA couldn't have meant that. He must know that for an ideal gas, dU is always equal to CvdT.
thats what i thought, I think he might have not realized that it said ideal gases in the problem
Related to Ideal gas-thermodynamics, thermal equilibrium
1. What is an ideal gas in thermodynamics?
An ideal gas is a theoretical concept in thermodynamics that describes a gas at low pressure and high temperature, where the gas particles are assumed to have zero volume and do not interact with each other. This simplifies calculations and allows for the use of the ideal gas law.
2. What is thermal equilibrium?
Thermal equilibrium is a state in which two or more systems are at the same temperature and there is no net transfer of heat between them. This means that the systems have reached a balanced state where the rate of energy transfer is equal in both directions.
3. How is thermal equilibrium achieved?
Thermal equilibrium can be achieved through various methods, such as bringing the systems into contact with each other, using a heat reservoir, or by insulating the systems. In all cases, the systems will eventually reach the same temperature and thermal equilibrium will be achieved.
4. What is the significance of thermal equilibrium in thermodynamics?
Thermal equilibrium is an important concept in thermodynamics because it allows for the analysis and prediction of the behavior of systems in equilibrium. It also helps in understanding the flow of heat and energy between systems, which is crucial in many industrial and scientific applications.
5. Can thermal equilibrium be broken?
Yes, thermal equilibrium can be broken if there is an external influence such as a change in temperature or pressure. This will result in a transfer of heat between the systems until a new state of thermal equilibrium is reached. However, in a closed system, thermal equilibrium cannot be broken as there is no external influence.
