oneamp
- 219
For microwave. Is it any insulator? Rubber will work?
oneamp said:Thanks for the link jedishrfu. Adjent (or another): are you sure that the shape of the reflector changes 'beam shape'? What are the benefits of various beam shapes? I think the shape just satisfies practical physical constraints (ability to pack it up into a small container, for example), after a certain multiple of wavelength.
oneamp said:Off center for casegranian I think. Maybe I misspelled that. But, what does the beam have to do with the shape of the dish?
The ideal material for a parabolic reflector is one that has a high reflectivity and is able to maintain its shape and smoothness over time. Examples of materials commonly used for parabolic reflectors include aluminum, silver, and gold.
The material of a parabolic reflector greatly affects its performance because it determines the reflectivity and durability of the reflector. A highly reflective material will result in a brighter and more focused reflection, while a durable material will ensure the reflector maintains its shape for optimal performance.
Materials that are not highly reflective or are easily tarnished or corroded should be avoided for parabolic reflectors. This includes materials like copper or steel, which have lower reflectivity and are more prone to tarnishing or rusting.
The right material for a parabolic reflector depends on the specific requirements of your application. Factors to consider include the desired reflectivity, durability, and cost. It is recommended to consult with a materials expert or conduct testing to determine the best material for your needs.
Yes, it is possible to combine different materials to create an ideal parabolic reflector. For example, some reflectors may use a base material with high strength and durability, such as aluminum, and then have a thin layer of a more reflective material, like silver or gold, applied on top. This allows for both durability and high reflectivity in one reflector.
