Ideal Rings - Abstract Algebra
In summary: So, a+b is an element of (I+J) since I+J is an ideal of (R+I,+,\cdot).For (ii) part 2, recall that if a and b are elements of J, then a+b is an element of J since J is ideal. So, ar+ra is an element of (I+J) since J is ideal and ar+ra is an element of I since a and b are elements of I.
golfgreen99
Suppose R is a ring and I,J is an ideal to R.
Show (i) I+J is ideal to R. (ii) I union J is ideal to R.
none
Can you show that you've attempted it?
Here is what I have (I think I have (ii)):
(i)
Part 1: Clearly if a,b are elements of I, then a+b are elements of I (since I is ideal to R) and if a,b are elements of J then a + b are elements of J (since J is ideal to R)
If we have one element from each ideal, say a element of I/b element of J, then we must show a+b is an element of (I+J).
a+b is an element of R since a,b is an element of R and R is closed.
Part 2: Let a be an element of (I + J) and r is an element of R.
Then if a is an element of I, ar is an element of I and ra is an element of I since I is ideal.
Similarly, if a is an element of J, ar is an element of J and ra is an element of J since I is ideal.
In either case, ar is an element of (I + J) and ra is an element of (I + J)
(ii)
Part 1: Assume a, b are elements in I union J.
Then a + b is an element of I since I is ideal and a + b is an element of J since J is ideal.
Then a + b is in both I and J and therefore a + b is an element of I union J.
Part 2: Assume a is and element of (I union J) and r is an element of R.
Then, ar is an element of I and ra is and element of I since I is ideal.
Similarly, ar is an element of J and ra is an element of J since J is ideal.
So, ar is an element of (I union J) and ra is an element of (I union J)
you'll also need to show that I+J and [tex]I\cup J[/tex] are closed under multiplication and subtraction (in fact addition follows from subtraction).
For (i) part 1, it might help to recall that since [tex](I,+,\cdot)[/tex] is an ideal of [tex](R,+,\cdot)[/tex], [tex](I,+)[/tex] is a normal subgroup of [tex](R,+)[/tex] (since [tex](R,+)[/tex] is abelian). Simlarly for J.
FAQ: Ideal Rings - Abstract Algebra
What is an ideal ring?
An ideal ring is a mathematical structure that consists of a set of elements, a binary operation, and two additional operations, addition and multiplication. It is a generalization of a ring, which is a structure that satisfies certain algebraic properties. The defining characteristic of an ideal ring is that it contains a subset of elements that are closed under multiplication by any element in the ring. This subset is called an ideal and plays an important role in the structure and properties of the ring.
How are ideal rings used in abstract algebra?
Ideal rings are an important concept in abstract algebra because they allow us to study the properties of rings and their elements in a more general and abstract way. They provide a framework for understanding and proving theorems about rings, and many important results in algebraic structures, such as commutative rings and fields, can be derived from the properties of ideal rings.
What are the properties of an ideal ring?
Some of the key properties of an ideal ring include closure under addition and multiplication, associativity and commutativity of addition and multiplication, distributivity of multiplication over addition, and the existence of a multiplicative identity. Additionally, an ideal ring must satisfy the ideal property, which means that for any element in the ideal and any element in the ring, their product is also in the ideal.
How do you determine if a ring is an ideal ring?
To determine if a ring is an ideal ring, you must first check if the ring satisfies the properties of a ring, such as being closed under addition and multiplication. Then, you must check if there is a subset of elements that is closed under multiplication by any element in the ring, which would make it an ideal. If both of these conditions are met, then the ring is an ideal ring.
What is the relationship between ideal rings and quotient rings?
Quotient rings are a type of ideal ring where the elements of the ideal are used to define the equivalence classes of the quotient structure. This means that the elements of the quotient ring are the cosets of the ideal. Quotient rings are useful for understanding the structure of ideal rings and can help simplify calculations and proofs involving ideal rings.
