MHB Ideals of a Residue Class Ring- Ring Isomorphism
Math Amateur
MHB
I am reading R. Y. Sharp: Steps in Commutative Algebra.
In Chapter 2: Ideals on page 32 we find Exercise 2.40 which reads as follows:
Let I, J be ideals of the commutative ring R such that $$ I \subseteq J $$.
Show that there is a ring isomorphism
$$ \xi \ : (R/I) \ / \ (J/I) \to R/J $$
for which
$$ \xi ((r + I) + J/I ) = r + J $$ for all $$r \in R$$.
Can someone please help me get started on this exercise.
Also ... problem ... considering J/I ... for a factor ring, J is usually a ring, so what does J/I mean? I assume that since ideals are subgroups under addition, then we can make sense of this by interpreting J/I as a factor group ... Is this the case ... can someone please confirm that my view on this matter is valid ...
As indicated above i would be grateful for some help to get started ...
Peter
This is also known as "The Second Isomorphism Theorem" and is a direct analogue of a similar result for groups.
If $J$ is a subring of $R$ containing an ideal $I$ of $R$, it is clear to see that $I$ is also an ideal of $J$. So, yes, $J/I$ is just a "smaller" factor ring, and it should be clear that it is a subring of $R/I$.
You see, every ideal IS a subring (if one stipulates that subrings need not contain unity):
Recall that a subring has to be closed under multiplication. Well if $a\in J$, and $x \in J$, then a fortiori (loosely translated: "all the more so", literally, "from the stronger" an abbreviation of "a fortiori argumento" -from the stronger argument), $a \in R$, and since $J$ is an ideal, $ax \in J$, hence $J$ is closed under multiplication.
However, a subring need not be an ideal: consider the ring $\Bbb Z \times \Bbb Z$ with the multiplication:
$(a,b)(a',b') = (aa',bb')$.
The set $\Delta \Bbb Z = \{(k,k)\}$ is a subring of $\Bbb Z \times \Bbb Z$, but it is NOT an ideal; Let $a,k \neq 0$, then:
$(a,0)(k,k) = (ak,0) \not \in \Delta \Bbb Z$.
Now, we are already given a definition of $\xi$, but as with any mapping defined on a quotient ring via elements of the ring, we must ensure that it is "well-defined", i.e; that it is constant on any coset. Because $\xi$ is defined on a "coset of a coset" we have to do this TWICE:
First: suppose $(r + I) + J/I = (r' + I) + J/I$ (as cosets in $(R/I)/(J/I)$).
This means that $(r + I) - (r' + I) \in J/I$
But also: in $J/I$, we have:
$(r + I) - (r' + I) = (r - r') + I$
so if this coset is in $J/I$, we must have that $r - r' \in J$, so $r + J = r' + J$ in $R/J$.
But THAT means that $\xi((r+I) + J/I)) = r + J = r' + J = \xi((r'+I) + J/I)$
whenever $(r + I) + J/I = (r' + I) + J/I$, that is: $\xi$ is well-defined.
It is then trivial that $\xi$ is surjective, since for every $r + J \in R/J$, we have the pre-image:
$(r + I) + J/I$ in $(R/I)/(J/I)$ (use the same $r$).
It, of course, remains to be seen that $\xi$ is a ring-homomorphism, which I leave to you.
I will address one final point, the kernel of $\xi$. This is, by definition:
$\{(r + I) + J/I \in (R/I)/(J/I): \xi((r + I) + J/I) = J\}$.
Since $r + J = J \iff r \in J$, this is the set:
$\{(r + I) + J/I: r \in J\}$, and this means $r+I \in J/I$, whence:
$\text{ker}(\xi) = \{J/I\}$, the 0-element of $J/I$.
Here is a painfully worked-out example:
Let $R = \Bbb Z$ and let $I = (12), J = (3)$.
Using the canonical isomorphism:
$\Bbb Z/(12) \cong \Bbb Z_{12}$ let's look at what $J/I$ is, explicitly.
To simplify the notation, we will use $[k]_{12}$ for the image of $k$ in $\Bbb Z_{12}$
under the canonical isomorphism.
Then $J/I = {[k]_{12} \in \Bbb Z_9: 3|k} = \{[0]_{12},[3]_{12},[6]_{12},[9]_{12}\}$
Then the possible cosets are:
$[0]_{12} + J/I = J/I = \{[0]_{12},[3]_{12},[6]_{12},[9]_{12}\}$
$[1]_{12} + J/I = \{[1]_{12},[4]_{12},[7]_{12},[10]_{12}\}$
$[2]_{12} + J/I = \{[2]_{12},[5]_{12},[8]_{12},[11]_{12}\}$
(we could, if we so chose, simply this notation even further by representing these cosets with double brackets: $[[k]]$, meaning first we reduce $k$ mod 12, and then reduce the resulting "integer" again mod 3 -this works on the entire cosets because 3|12, which is exactly the necessary condition we must have for (12) to be a ideal contained in (3)).
Here, our isomorphism is:
$\xi([k]_{12} + J/I) = [k]_3$
(which makes sense: $J/I$ is a finite subring of order 4, so the quotient should have order 12/4 = 3).
Sometimes this theorem is called the "freshman's theorem": you just "cancel the $I$'s".
Thanks for the help Deveno!
Just carefully working through this now.
Peter
Thread 'Derivation of equations of stress tensor transformation'
Hello ! I derived equations of stress tensor 2D transformation. Some details: I have plane ABCD in two cases (see top on the pic) and I know tensor components for case 1 only. Only plane ABCD rotate in two cases (top of the picture) but not coordinate system. Coordinate system rotates only on the bottom of picture. I want to obtain expression that connects tensor for case 1 and tensor for case 2. My attempt: Are these equations correct? Is there more easier expression for stress tensor...
