Ideas in physics used for creating art
In summary, the conversation revolved around finding ways to incorporate physics and astronomy into music composition. The original poster was looking for ideas on how to translate physical phenomena into musical parameters, such as sound, form, and spatial design. Some suggestions were to use probability distribution behaviors, movement in particles, and formal musical elements modeled after natural phenomena. Other ideas included using electronics, acoustics, and human vocals to interpret physical phenomena into music. There were also suggestions to use technology, such as webcams and software, to decode and transform sounds into visible patterns and vice versa. The conversation also touched on the limitations and arbitrary nature of the connection between physics and music, as well as examples of artists who have successfully incorporated physics into their work.
dariushde
Summary:: I'm looking for physical models/phenomena that can be replicated in the art of creating sound/music.
Hey everyone,
I'm an experimental music composer/researcher who just got addicted to watching Youtube videos on quantum physics. The entire field absolutely fascinates me now. The first idea that blew my mind and made me see the relation between these ideas and music was "Wave-particle duality." As you might know, experimental sound designers often synthesize new sounds by designing the waveform from scratch (wavetable synthesis).
I'm looking for ideas that can be translated to musical parameters such as sound, form, spatial design and so on. What do I mean by this? Let me give you some examples:
1) Interesting probability distribution behavior that can be translated into sound waveforms and translated to music
2) peculiar movement in particles/atoms/etc. that can be translated into the sound's position in space (moving left/right/front/back)
3) formal musical elements that can be modeled after a natural phenomena (as an example: density of a musical phrase in terms of energy can be modeled after element x in the universe/atomic behavior/etc.)
I understand there can be hundreds of ways I can pose this question, but hopefully you get the idea! I would highly appreciate your input and ideas and I'll post my musical findings in this forum as time goes on.
Looking forward to reading your ideas.
David Hykes and the Harmonic Choir use electronics, acoustics, human vocals and percussion instruments to interpret physical phenomena such as electromagnetic radiation from the Sun into pleasing music.
As a visual artist/hobbyist in acrylic paints I borrow from geography to produce 'seascapes' and from astronomy to invent fanciful 'spacescapes'; the latter often depicting comets within our solar system.
Likes dariushde and berkeman
Thank you for your great reply. What I'm looking for involves a more direct relationship with physics/astronomy. Let's say we have the following distribution table:
Well, one way of thinking of this musically is translating the probability waveforms into audio waveforms and designing a sound with it. This'll create a direct connection between a physical observation and a musical sound... Does that make sense? This is just one example, of course. I'm just not well versed enough in this topic to think of other ways these ideas can be translated into music in some way shape or form, and not only just sound (as I said before, maybe the ideas can be applied to the length of a musical section, a phrase or something else).
You are only limited by your creativity - but then whatever will be produced won't have much to do with the original physics, just like Holst's Neptune has nothing to do with planet itself.
Likes 256bits and sophiecentaur
Obviously I understand that the resulting sound won't have anything to do with physics; but there will be an abstract connection between the sounds created and physics. It is arbitrary, but so is everything else in life; therefore I don't buy that argument.
I'm simply looking for some inspiration in the field of physics for my work of art. In my world these inspirations give meaning to the work of art. Thank you for your comment though.
  • Skeptical
Likes Hornbein and 256bits
Likes dariushde
Without knowing your media of expression assume sound/music in your original post limits outputs to the normal range of human hearing. In a minimal form you could sample a waveform then translate the wavelengths into the audible spectrum. The directors of the movie "Contact" apply a similar method to translate radio wavelengths into audio so that the blind astrophysicist can listen/see the alien signal.
You could locate physical phenomena such as the recent Pacific Island volcanic eruption that emit detectable sound waves then weave samples into your musical composition. This updating Washington Post article emphasizes visual evidence of the eruption such as photographs from orbit but many other measurements including seismographs and sound recordings are available from many sources including Physics Forums.
https://www.physicsforums.com/threa...tonga-hunga-ha-apai-volcano-eruption.1011299/
Some science articles refer to numerous lightning strikes instigated by volcanic debris blown high into the atmosphere. Imagine the thunder resulting from that lightning synthesized via electronic or real drumskins. Walt Disney interpreted volcanic eruptions mixed with his memories of WWI cannon fire in the soundtrack to "Fantasia".
The PF electronic engineering subforum contains several threads on designing circuits that generate audio signals from a variety of sources including Moog synthesizers, theremins, ring modulators and electronic musical instruments. This thread describes several musical albums using Moog's technology. That same forum contains comparisons of musical and mathematical forms.
Consider also expressing probability distributions and mathematical sequences as extended intervals between sounds and as signal modifications such as phase shifts, phase modulation, reverb, fuzz and similar distortion.
Likes dariushde
robphy said:
This is such a detailed and wonderful response, I really appreciate it. Thank you.
Likes berkeman and Klystron
Fantastic. Thank you! Probability distributions are definitely something that can be translated into sound and musical form successfully. Could you please point me towards an article/book that contains a healthy amount of probability distributions for me to model after? Thanks again for your response.
Likes Klystron
Glad you found value in the responses. Sorry that my favorite math textbooks are way out of date.
Suggest you ask for textbook and educational video suggestions in the Science Education and/or Mathematics forums. Pulldown the 'Forums' button on top. State your current level of math knowledge -- algebra, statistics, calculus, etc. -- your objectives, such as "develop statistical models for writing music", and a brief overview of your (non-homework) applications.
Amazon contains a plethora of math textbooks. I used keywords 'statistics', 'probability', 'finite mathematics' and 'discrete mathematics' textbooks. Probability distributions are explained in most undergraduate mathematics textbooks.
PF has other forums apropos to your applications including 'Art, Music, History and Linguistics' and 'Set Theory, Logic, Probability and Statistics' depending on your education and interests. Many members teach mathematics, some are also advanced musicians. Try searching (button on right side) for threads of interest and look beneath responses for lists of related threads (see below).
Then I think you would like this video a lot: :smile:
(the uncertainty principle in quantum physics demonstrated with the help of a sound of a guitar)
The Uncertainty Principle and Waves - Sixty Symbols​
I also remember that many years ago I stumbled upon a sound/music software effect that was allegedly based on some quantum physics, weirdly enough. I'll see if I can find it online, and post here if I find it. :smile:
Edit: I found it, but it was not a standalone effect, but impulses for convolution reverbs:
(it seems the impulses are not downloadable, but there are some samples on the page)
The Quantum Hall Effects - impulse responses from nanospace for convolution reverb
https://www.dubbhism.org/2008/11/quantum-hall-effects-impulse-responses.html
FAQ: Ideas in physics used for creating art
What are some examples of ideas in physics used for creating art?
There are many examples of how artists have incorporated ideas from physics into their work. Some examples include using the principles of light and color to create optical illusions, using the concept of gravity to create sculptures that appear to defy it, and incorporating mathematical patterns and fractals into artwork.
How does the study of physics influence the creation of art?
The study of physics can influence the creation of art in many ways. It can provide inspiration and new ideas for artists, as well as a deeper understanding of the world around us. It can also provide practical knowledge and techniques, such as how to manipulate light and create visual illusions.
What role does physics play in the creation of digital art?
Physics plays a significant role in the creation of digital art. Many digital art forms, such as animation and video games, rely on physics engines to create realistic movements and interactions. Artists also use physics simulations to create dynamic and fluid visuals.
How can understanding physics enhance the appreciation of art?
Understanding physics can enhance the appreciation of art by allowing viewers to better understand the technical aspects of an artwork. This can deepen their understanding and appreciation of the artist's skill and creativity. It can also provide a new perspective on the artwork, as viewers can interpret it through the lens of scientific principles.
What are some potential future developments in the intersection of physics and art?
As technology and scientific understanding continue to advance, there are endless possibilities for the intersection of physics and art. Some potential future developments could include the incorporation of virtual and augmented reality technologies into art, the use of advanced materials and tools in art-making, and the creation of interactive and immersive art experiences through the use of physics simulations.
12K
9K
