Identical Hollow and Solid Spheres
In summary, an experiment can be done to determine whether a sphere is hollow or solid by allowing the spheres to roll down an incline and observing the differences in their translational velocities at the bottom. This is because a solid sphere, with its smaller moment of inertia, will have more rotational potential energy and less translational kinetic energy than a hollow sphere, causing it to reach the bottom at a lower velocity. This can be illustrated through the conservation of energy equation and holding another variable constant, such as the spheres' velocities.
cassie123
Two spheres look identical and have the same mass. However, one is hollow and the other is solid. Describe an experiment to determine which is which.
mgh= ½ m v^2 + ½ I ω^2
where I= 2/3 mr2 for a hollow sphere
I=2/5 mr2 for a solid sphere
You could allow the two spheres to roll an identical incline from rest. For both spheres, the gravitational potential energy will be transformed to both rotational kinetic energy and translational potential energy when they reach the base.
Since a solid sphere has a smaller moment of inertia, it is less resistant to rotation. More of the original gravitational potential energy will be converted into rotational potential energy for the solid sphere than for the hollow sphere. Thus, the hollow sphere must have more translational kinetic energy and will reach the bottom at a greater translational velocity than the solid sphere will.
Logically I believe that the solid sphere should go faster.. so I am not confident in my logic above.
Could you also argue that the at the moment released from rest the solid sphere will begin to rotate to fall down the incline before the hollow sphere due to the differences in inertia?
Think over this again.
If the solid sphere has a smaller moment of inertia, will its rotational energy be higher or lower than that of the hollow sphere, if they are rolling at the same rate?
Say sphere A will have a lower rotational energy than sphere B when rolling at the same rate, and both have the same mass. Given the same energy input to both, what can we then say about which one must be rolling faster?
Based on the equation for the conservation of energy: if a solid sphere has a smaller moment of inertia it will then have a lower rotational energy than a hollow sphere. So, the solid sphere must have a higher translational energy and reach the bottom at a higher velocity.
Better?
Better?
If the spheres have the same velocity then the one with the higher moment of inertia will have the higher rotational kinetic energy, right?
But they do not have the same velocity. The proposed experiment only works if their velocities are different. Instead, something else is being held constant.
Related to Identical Hollow and Solid Spheres
1. What is the difference between a hollow and solid sphere?
A hollow sphere is a 3-dimensional shape with a hollow center, while a solid sphere is completely filled with a material. In other words, a solid sphere has a uniform density throughout, while a hollow sphere has a varying density.
2. How do the properties of a hollow and solid sphere differ?
The properties of a hollow sphere, such as volume, surface area, and moment of inertia, differ from those of a solid sphere due to the difference in their internal structure. A solid sphere has a greater mass and moment of inertia compared to a hollow sphere with the same outer dimensions.
3. What are some real-life examples of identical hollow and solid spheres?
Some examples of identical hollow and solid spheres can include a tennis ball and a baseball, or a basketball and a medicine ball. These objects have the same outer dimensions but differ in their internal structure.
4. How are hollow and solid spheres used in engineering and science?
Hollow and solid spheres have many practical applications in engineering and science, such as in structural design, heat transfer, and fluid dynamics. They are also commonly used in experiments and simulations to study the behavior of materials under different conditions.
5. What are some advantages and disadvantages of using hollow and solid spheres?
The main advantage of using hollow and solid spheres is their versatility and wide range of applications. Hollow spheres can also be lightweight while still maintaining strength, making them useful in aerospace and automotive industries. However, a disadvantage is that the production of perfectly identical hollow and solid spheres can be challenging and expensive. Additionally, the varying density of a hollow sphere can affect its structural integrity in certain scenarios.
