Ranku
- 422
- 18
Is it possible to identify a volume of space, observationally/statistically, that represents the 85:15 % ratio of dark matter and matter?
Vanadium 50 said:What is wrong with "the visible universe" as the nswer to this question? It sounds like you have something in mind that remains unstated.
Ranku said:I was wondering suppose dark matter is lighter than matter
The way I am looking at it is this: Since we know the proportion of dark matter to matter in the universe, and if we were able to have a volume of space that is representative of the dark matter-matter ratio, then measuring the gravity of the proportion of matter we compare it with the gravity of the proportion of dark matter and see if the gravity of dark matter matches the gravity expected of the proportion of dark matter. If it is less, then that would mean that dark matter is lighter than matter.Vanadium 50 said:A kilogram of dark matter is no lighter than a kilogram of hydrogen.
The argument seems a bit circular to me.Ranku said:The way I am looking at it is this: Since we know the proportion of dark matter to matter in the universe, and if we were able to have a volume of space that is representative of the dark matter-matter ratio, then measuring the gravity of the proportion of matter we compare it with the gravity of the proportion of dark matter and see if the gravity of dark matter matches the gravity expected of the proportion of dark matter. If it is less, then that would mean that dark matter is lighter than matter.
This approach however requires that determining the proportion of dark matter in the universe is derived independently of its gravity. It seems one way to do this would be by subtracting the proportion of matter and dark energy from Ω = 1.
Which is why I mentioned: This approach however requires that determining the proportion of dark matter in the universe is derived independently of its gravity. It seems one way to do this would be by subtracting the proportion of matter and dark energy from Ω = 1.collinsmark said:The argument seems a bit circular to me.
We estimate the proportion of (baryonic) matter to dark matter by their gravitational influence. Your statement, "since we know the proportion of dark matter to matter" is already based on gravitational influence.
Just as we have particle species which are heavier or lighter than other particle species, similarly we may wonder if dark matter is the lightest freely existing particle species. That’s all I’m saying.Vanadium 50 said:I don't understand what you are saying. But you can't say dark matter if lighter or heavier than ordinary matter. You can say you have more or less of it.
Do you think that 85% of all particles are dark particles? When scientists say 85%, they are talking about mass.Ranku said:Just as we have particle species which are heavier or lighter than other particle species,
The OP was about how to observationally determine the proportion of dark matter and matter. When you sensed something is ‘unstated’, I explained I was exploring how to observationally determine if dark matter might be lighter than matter.Vanadium 50 said:That's not what your OP said. I think you need to work harder on clarifying exactly what you are asking.
And it's not, in either sense of the word.Ranku said:I explained I was exploring how to observationally determine if dark matter might be lighter than matter.
As I clarified later in the thread, I meant lighter in the sense of dark matter being a lighter species of particles. Thus, even though the total mass of dark matter is more than matter, that mass can be constituted of a lighter species of particles.Vanadium 50 said:And it's not, in either sense of the word.
A kilogram is a kilogram
The total mass in dark matter is larger than the total mass of luminous matter.
But note that if you do have such rotation curve, you might, in the case of spherical cow, simply convert this graph into graph of dark and light matter density, and their ratio!anorlunda said:I'm not sure about that exact number, but the whole idea of dark matter came from observations of the rotation rates of galaxies and galaxy clusters.
Rotation curve of a typical spiral galaxy: predicted (A) and observed (B). Dark matter can explain the 'flat' appearance of the velocity curve out to a large radius.
Vanadium 50 said:OK, "Maybe". But your questions are moving all over the place.
We have an observationally supported, although model dependent, estimate of the proportions of baryonic matter mass-energy, dark matter mass-energy, and dark energy mass-energy as a proportion of total mass-energy density in the universe.Ranku said:The OP was about how to observationally determine the proportion of dark matter and matter. When you sensed something is ‘unstated’, I explained I was exploring how to observationally determine if dark matter might be lighter than matter.
I guess, on hindsight, if you simply flip the line of questioning, it becomes more logical. But then again that’s why it’s called hindsight![]()
Is dark matter "assumed to gather into clumps" or "observed to gather into clumps"?ohwilleke said:in efforts to determine the properties of dark matter from things like galaxy and galaxy cluster dynamics, dark matter particle mass doesn't matter much.
Instead, the property of dark matter that drives galaxy and galaxy cluster dynamics is mean dark matter particle velocity. High velocity dark matter particles are called "hot dark matter" and has been ruled out as an important component of dark matter. "Cold dark matter" particles are dark matter particles with a much lower velocity. "Warm dark matter" particles are much closer to cold dark matter particles than to hot dark matter but a little higher in velocity (and has a smaller mass that gives it quantum mechanical interactions not found in more massive dark matter particles).
The LambdaCDM Model of Cosmology doesn't really make a distinction between Warm Dark Matter and Cold Dark Matter. Both fit that model's definition of Cold Dark Matter.
There are lots of ways that dark matter could have hypothetically been created. One of the most popular theories is called "thermal freeze out" which hypothesizes that there is a statistical relationship between the mass of a dark matter particle and the temperature at which it "freezes out" as the average temperature of the universe falls after the Big Bang as the universe expands. In a thermal freeze out scenario particles with a mass that causes them to freeze out at a particular temperature acquire their mean velocity at the mean velocity of particles at that temperature.
In a thermal freeze out scenario, cold dark matter has particle masses of ca. 10 GeV to 1000 GeV, warm dark matter has particle masses of ca. 1 keV to 10 keV, and hot dark matter has a mass on the same order as neutrinos or less.
Dark matter candidates with particle masses of less than warm dark matter that nonetheless have warm dark matter or cold dark matter mean velocities (like axion-like particles) are hypothesized to come into being by means other than thermal freeze out, often with these particles being continually created and destroyed in a dynamic equilibrium.
Unlike dark energy, dark matter is assumed to gather into clumps, although not as tightly as baryonic matter does. In the dark matter hypothesis, galaxies, galaxy clusters, and cosmic scale strings of baryonic matter between galaxies arise from baryonic matter being drawn into halos of dark matter.
The inferred proportion of baryonic matter mass to dark matter mass that is observed, however, is not uniform even setting aside the large "voids" in space with very little ordinary baryonic matter or dark matter of any kind.
Generally speaking, the dark matter proportion by mass of the total mass of the system is lowest in elliptical galaxies (with the least inferred dark matter in the most spherical elliptical galaxies and the most in the least spherical ones), is higher in typical spiral galaxies, and is higher still in low surface brightness dwarf galaxies and in galaxy clusters, although there are also a small number of dwarf galaxies for which one can infer from their dynamics that they have little or no dark matter.
Do we see observational evidence of this exponential dependency?snorkack said:If dark matter were ideal gas of constant temperature and molecular mass - that is, if the mean dark matter particle velocity were a constant - the density of dark matter should have exponential dependency on the local gravitational potential.
The inferred distribution of dark matter from observations, unlike dark energy, is clumpy as opposed to uniform across all volumes of space.snorkack said:Is dark matter "assumed to gather into clumps" or "observed to gather into clumps"?
Once you have converted the rotation curve into actual density distribution, how about density as a function of local gravitational potential?
The rotation curve does give you both the local total density (and thus local dark matter density after subtracting the light matter density) and the local potential (not relative to infinity, because that depends on the unobserved mass outside the curve, but relative to anywhere else inside the curve). When you plot the dependence of local dark matter density on local gravitational potential, does the mean dark matter velocity stay constant inside same galaxy and between galaxies, or does it vary?
Evidence of small-scale power suppression could, for example, suggest that dark matter is warmer (i.e., not nonrelativistic) during structure formation, is not collision-less, is wavelike rather than particle-like, or underwent non-trivial phase transitions in the early Universe.
Matter is anything that has mass and takes up space. It includes all the visible objects in the universe, such as stars, planets, and galaxies. Dark matter, on the other hand, is a type of matter that does not emit or absorb light, making it invisible to telescopes. It is thought to make up about 85% of the total matter in the universe.
Scientists use a variety of methods to estimate the proportions of matter and dark matter in the universe. One method is to study the rotation of galaxies and how they are affected by the gravitational pull of surrounding matter. Another method involves studying the cosmic microwave background radiation, which can provide clues about the distribution of matter in the early universe.
Understanding the proportions of matter and dark matter in the universe is crucial for understanding the structure and evolution of the universe. It can also help us better understand the role of dark matter in the formation of galaxies and the large-scale structure of the universe.
Scientists have not yet directly observed dark matter, so they use indirect methods to identify its presence. These methods include studying the gravitational effects of dark matter on visible matter, observing the bending of light around massive objects, and detecting high-energy particles that may be produced by dark matter interactions.
Currently, there is no known way to detect or create dark matter in a laboratory setting. However, scientists are conducting experiments using particle accelerators to try and produce dark matter particles and study their properties. These experiments could potentially provide more insight into the nature of dark matter.
