Identify explicit shape spec list in the FORTRAN code
In summary, explicit shape spec list in FORTRAN code refers to the use of specific dimensions for arrays and variables in the code. This allows for easier management and manipulation of data, as well as more efficient memory usage. The explicit shape spec list includes the dimensions of each array and variable, as well as any constraints or conditions for their use. This feature is crucial in FORTRAN programming, as it helps to ensure the accuracy and effectiveness of the code.
anirudhnair
Identify "explicit shape spec list" in the FORTRAN code
Hi,
I'm trying to do some source code analysis using the ROSE compiler infrastructure on some of the kernels in NAS Parallel benchmark.
I get an error while parsing the Embarrassingly Parallel kernel. Digging further, I gathered that ROSE doesn't support Explicit Shape Spec List. I'm new to Fortran and don't quiet understand what an explicit shape spec list is.
I'm pasting the source code here. It would be great If someone could point me out to the part of the code having the spec list.
EP.f
<code>
! N A S P A R A L L E L B E N C H M A R K S 3.3 !
! E P !
! This benchmark is part of the NAS Parallel Benchmark 3.3 suite. !
! It is described in NAS Technical Reports 95-020 and 02-007 !
! Permission to use, copy, distribute and modify this software !
! for any purpose with or without fee is hereby granted. We !
! request, however, that all derived work reference the NAS !
! Parallel Benchmarks 3.3. This software is provided "as is" !
! without express or implied warranty. !
! Information on NPB 3.3, including the technical report, the !
! original specifications, source code, results and information !
! on how to submit new results, is available at: !
! http://www.nas.nasa.gov/Software/NPB/ !
! Send comments or suggestions to npb@nas.nasa.gov !
! NAS Parallel Benchmarks Group !
! NASA Ames Research Center !
! Mail Stop: T27A-1 !
! Moffett Field, CA 94035-1000 !
! E-mail: npb@nas.nasa.gov !
! Fax: (650) 604-3957 !
c---------------------------------------------------------------------
c
c Authors: P. O. Frederickson
c D. H. Bailey
c A. C. Woo
c R. F. Van der Wijngaart
program EMBAR
C
c This is the MPI version of the APP Benchmark 1,
c the "embarassingly parallel" benchmark.
c
c
c M is the Log_2 of the number of complex pairs of uniform (0, 1) random
c numbers. MK is the Log_2 of the size of each batch of uniform random
c numbers. MK can be set for convenience on a given system, since it does
c not affect the results.
implicit none
include 'npbparams.h'
include 'mpinpb.h'
double precision Mops, epsilon, a, s, t1, t2, t3, t4, x, x1,
> x2, q, sx, sy, tm, an, tt, gc, dum(3),
> timer_read
double precision sx_verify_value, sy_verify_value, sx_err, sy_err
integer mk, mm, nn, nk, nq, np, ierr, node, no_nodes,
> i, ik, kk, l, k, nit, ierrcode, no_large_nodes,
> np_add, k_offset, j
logical verified, timers_enabled
external randlc, timer_read
double precision randlc, qq
character*15 size
integer fstatus
integer t_total, t_gpairs, t_randn, t_rcomm, t_last
parameter (t_total=1, t_gpairs=2, t_randn=3, t_rcomm=4, t_last=4)
double precision tsum(t_last+2), t1m(t_last+2),
> tming(t_last+2), tmaxg(t_last+2)
character t_recs(t_last+2)*8
parameter (mk = 16, mm = m - mk, nn = 2 ** mm,
> nk = 2 ** mk, nq = 10, epsilon=1.d-8,
> a = 1220703125.d0, s = 271828183.d0)
common/storage/ x(2*nk), q(0:nq-1), qq(10000)
data dum /1.d0, 1.d0, 1.d0/
data t_recs/'total', 'gpairs', 'randn', 'rcomm',
> ' totcomp', ' totcomm'/
call mpi_init(ierr)
call mpi_comm_rank(MPI_COMM_WORLD,node,ierr)
call mpi_comm_size(MPI_COMM_WORLD,no_nodes,ierr)
root = 0
if (.not. convertdouble) then
dp_type = MPI_DOUBLE_PRECISION
else
dp_type = MPI_REAL
endif
if (node.eq.root) then
c Because the size of the problem is too large to store in a 32-bit
c integer for some classes, we put it into a string (for printing).
c Have to strip off the decimal point put in there by the floating
c point print statement (internal file)
write(*, 1000)
write(size, '(f15.0)' ) 2.d0**(m+1)
j = 15
if (size(j:j) .eq. '.') j = j - 1
write (*,1001) size(1:j)
write(*, 1003) no_nodes
1000 format(/,' NAS Parallel Benchmarks 3.3 -- EP Benchmark',/)
1001 format(' Number of random numbers generated: ', a15)
1003 format(' Number of active processes: ', 2x, i13, /)
open (unit=2,file='timer.flag',status='old',iostat=fstatus)
timers_enabled = .false.
if (fstatus .eq. 0) then
timers_enabled = .true.
close(2)
endif
endif
call mpi_bcast(timers_enabled, 1, MPI_LOGICAL, root,
> MPI_COMM_WORLD, ierr)
verified = .false.
c Compute the number of "batches" of random number pairs generated
c per processor. Adjust if the number of processors does not evenly
c divide the total number
np = nn / no_nodes
no_large_nodes = mod(nn, no_nodes)
if (node .lt. no_large_nodes) then
np_add = 1
else
np_add = 0
endif
np = np + np_add
if (np .eq. 0) then
write (6, 1) no_nodes, nn
1 format ('Too many nodes:',2i6)
ierrcode = 1
call mpi_abort(MPI_COMM_WORLD,ierrcode,ierr)
stop
endif
c Call the random number generator functions and initialize
c the x-array to reduce the effects of paging on the timings.
c Also, call all mathematical functions that are used. Make
c sure these initializations cannot be eliminated as dead code.
call vranlc(0, dum(1), dum(2), dum(3))
dum(1) = randlc(dum(2), dum(3))
do 5 i = 1, 2*nk
x(i) = -1.d99
5 continue
Mops = log(sqrt(abs(max(1.d0,1.d0))))
c Synchronize before placing time stamp
do i = 1, t_last
call timer_clear(i)
end do
call mpi_barrier(MPI_COMM_WORLD, ierr)
call timer_start(1)
t1 = a
call vranlc(0, t1, a, x)
c Compute AN = A ^ (2 * NK) (mod 2^46).
t1 = a
do 100 i = 1, mk + 1
t2 = randlc(t1, t1)
100 continue
an = t1
tt = s
gc = 0.d0
sx = 0.d0
sy = 0.d0
do 110 i = 0, nq - 1
q(i) = 0.d0
110 continue
c Each instance of this loop may be performed independently. We compute
c the k offsets separately to take into account the fact that some nodes
c have more numbers to generate than others
if (np_add .eq. 1) then
k_offset = node * np -1
else
k_offset = no_large_nodes*(np+1) + (node-no_large_nodes)*np -1
endif
do 150 k = 1, np
kk = k_offset + k
t1 = s
t2 = an
c Find starting seed t1 for this kk.
do 120 i = 1, 100
ik = kk / 2
if (2 * ik .ne. kk) t3 = randlc(t1, t2)
if (ik .eq. 0) goto 130
t3 = randlc(t2, t2)
kk = ik
120 continue
c Compute uniform pseudorandom numbers.
130 continue
if (timers_enabled) call timer_start(t_randn)
call vranlc(2 * nk, t1, a, x)
if (timers_enabled) call timer_stop(t_randn)
c Compute Gaussian deviates by acceptance-rejection method and
c tally counts in concentric square annuli. This loop is not
c vectorizable.
if (timers_enabled) call timer_start(t_gpairs)
do 140 i = 1, nk
x1 = 2.d0 * x(2*i-1) - 1.d0
x2 = 2.d0 * x(2*i) - 1.d0
t1 = x1 ** 2 + x2 ** 2
if (t1 .le. 1.d0) then
t2 = sqrt(-2.d0 * log(t1) / t1)
t3 = (x1 * t2)
t4 = (x2 * t2)
l = max(abs(t3), abs(t4))
q(l) = q(l) + 1.d0
sx = sx + t3
sy = sy + t4
endif
140 continue
if (timers_enabled) call timer_stop(t_gpairs)
150 continue
if (timers_enabled) call timer_start(t_rcomm)
call mpi_allreduce(sx, x, 1, dp_type,
> MPI_SUM, MPI_COMM_WORLD, ierr)
sx = x(1)
call mpi_allreduce(sy, x, 1, dp_type,
sy = x(1)
call mpi_allreduce(q, x, nq, dp_type,
if (timers_enabled) call timer_stop(t_rcomm)
do i = 1, nq
q(i-1) = x(i)
enddo
do 160 i = 0, nq - 1
gc = gc + q(i)
160 continue
call timer_stop(1)
tm = timer_read(1)
call mpi_allreduce(tm, x, 1, dp_type,
> MPI_MAX, MPI_COMM_WORLD, ierr)
tm = x(1)
nit=0
verified = .true.
if (m.eq.24) then
sx_verify_value = -3.247834652034740D+3
sy_verify_value = -6.958407078382297D+3
elseif (m.eq.25) then
sx_verify_value = -2.863319731645753D+3
sy_verify_value = -6.320053679109499D+3
elseif (m.eq.28) then
sx_verify_value = -4.295875165629892D+3
sy_verify_value = -1.580732573678431D+4
elseif (m.eq.30) then
sx_verify_value = 4.033815542441498D+4
sy_verify_value = -2.660669192809235D+4
elseif (m.eq.32) then
sx_verify_value = 4.764367927995374D+4
sy_verify_value = -8.084072988043731D+4
elseif (m.eq.36) then
sx_verify_value = 1.982481200946593D+5
sy_verify_value = -1.020596636361769D+5
elseif (m.eq.40) then
sx_verify_value = -5.319717441530D+05
sy_verify_value = -3.688834557731D+05
else
verified = .false.
endif
if (verified) then
sx_err = abs((sx - sx_verify_value)/sx_verify_value)
sy_err = abs((sy - sy_verify_value)/sy_verify_value)
verified = ((sx_err.le.epsilon) .and. (sy_err.le.epsilon))
endif
Mops = 2.d0**(m+1)/tm/1000000.d0
write (6,11) tm, m, gc, sx, sy, (i, q(i), i = 0, nq - 1)
11 format ('EP Benchmark Results:'//'CPU Time =',f10.4/'N = 2^',
> i5/'No. Gaussian Pairs =',f15.0/'Sums = ',1p,2d25.15/
> 'Counts:'/(i3,0p,f15.0))
call print_results('EP', class, m+1, 0, 0, nit, npm,
> no_nodes, tm, Mops,
> 'Random numbers generated',
> verified, npbversion, compiletime, cs1,
> cs2, cs3, cs4, cs5, cs6, cs7)
endif
if (.not.timers_enabled) goto 999
do i = 1, t_last
t1m(i) = timer_read(i)
end do
t1m(t_last+2) = t1m(t_rcomm)
t1m(t_last+1) = t1m(t_total) - t1m(t_last+2)
call MPI_Reduce(t1m, tsum, t_last+2, dp_type, MPI_SUM,
> 0, MPI_COMM_WORLD, ierr)
call MPI_Reduce(t1m, tming, t_last+2, dp_type, MPI_MIN,
call MPI_Reduce(t1m, tmaxg, t_last+2, dp_type, MPI_MAX,
if (node .eq. 0) then
write(*, 800) no_nodes
do i = 1, t_last+2
tsum(i) = tsum(i) / no_nodes
write(*, 810) i, t_recs(i), tming(i), tmaxg(i), tsum(i)
end do
endif
800 format(' nprocs =', i6, 11x, 'minimum', 5x, 'maximum',
> 5x, 'average')
810 format(' timer ', i2, '(', A8, ') :', 3(2x,f10.4))
999 continue
call mpi_finalize(ierr)
end
</code>
mpinpb.h
<code>
include 'mpif.h'
integer me, nprocs, root, dp_type
common /mpistuff/ me, nprocs, root, dp_type
</code>
npbparams.h
<code>
c NPROCS = 8 CLASS = D
c
c
c This file is generated automatically by the setparams utility.
c It sets the number of processors and the class of the NPB
c in this directory. Do not modify it by hand.
c
character class
parameter (class ='D')
integer m, npm
parameter (m=36, npm=8)
logical convertdouble
parameter (convertdouble = .false.)
character*11 compiletime
parameter (compiletime='14 Aug 2013')
character*5 npbversion
parameter (npbversion='3.3.1')
character*6 cs1
parameter (cs1='mpif77')
character*9 cs2
parameter (cs2='$(MPIF77)')
character*23 cs3
parameter (cs3='-L/usr/lib/openmpi/lib ')
character*26 cs4
parameter (cs4='-I/usr/lib/openmpi/include')
character*2 cs5
parameter (cs5='-O')
character*2 cs6
parameter (cs6='-O')
character*6 cs7
parameter (cs7='randi8')
</code>
The source code is also available at http://www.nas.nasa.gov/publications/npb.html
Thanks,
Anirudh
Technology news on Phys.org
It's hard to read your code. I would suggest that you re-post the code and use the [/CODE] tags to preserve the original indentation.
Also, post any compiler error messages about the 'explicit shape spec list'. AFAIK, an explicit shape spec list refers to an array variable where the dimensions are fixed, e.g. ARRAY (3,3).
Related to Identify explicit shape spec list in the FORTRAN code
1. What is the purpose of identifying explicit shape spec list in FORTRAN code?
The purpose of identifying explicit shape spec list in FORTRAN code is to specify the dimensions of arrays and variables. This is essential for the compiler to allocate the necessary memory and for the code to run correctly.
2. How do I identify the explicit shape spec list in FORTRAN code?
To identify the explicit shape spec list in FORTRAN code, you need to look for the DIMENSION statement. This statement declares the dimensions of arrays and variables and must be placed before the first executable statement in the program.
3. Can I change the explicit shape spec list in FORTRAN code?
Yes, you can change the explicit shape spec list in FORTRAN code, but it must be done carefully. Any changes to the dimensions of arrays and variables can affect the functionality of the code. It is important to understand the implications of changing the explicit shape spec list before making any modifications.
4. What happens if I do not identify the explicit shape spec list in FORTRAN code?
If you do not identify the explicit shape spec list in FORTRAN code, the compiler will assume the default dimensions for arrays and variables. This can lead to unexpected results and errors in the code. It is important to explicitly declare the dimensions to ensure the code runs correctly.
5. Are there any best practices for identifying explicit shape spec list in FORTRAN code?
Yes, there are some best practices for identifying explicit shape spec list in FORTRAN code. It is recommended to declare the dimensions of all arrays and variables at the beginning of the code, using the DIMENSION statement. It is also important to use meaningful and consistent names for arrays and variables to improve code readability.
