Identify the quadratic form of the given equation
In summary, the conversation is about solving a problem that involves identifying a quadratic form and plotting it. The process involves converting the equation into a matrix form, using the Principal Axes Theorem to find the eigenvalues and eigenvectors, and then forming a diagonalized matrix. However, there may be errors in the calculations and it is recommended to use a computer program like Mathematica for accuracy. The final equation may result in a two-dimensional object, such as a cylinder in this case. It is important to normalize the eigenvectors before forming the matrix P.
lesdes
<Moderator's note: Moved from a technical forum and thus no template.>
Hello I am given the following problem to solve.
Identify the quadratic form given by ##-5x^2 + y^2 - z^2 + 4xy + 6xz = 5##.
Finally, plot it.
I cannot seem to understand what I have to do. The textbook chapter on quadratic forms simply just forms the matrix of the given equation. Is that what I am expected to do?
It would be nice if someone could point me in the correct direction or link me to a relevant document/article.
Finally, plot it.
I assume you should say what it is: a hyperboloid, a sphere or whatever which form it has. The matrix is a first step, to bring it into a form without mixed terms is the next.
Likes lesdes
Okay so let's see if I am on the right path. What I have done is that I have written ##−5x2+y2−z2+4xy+6xz=5## in the form
(x y z)
\begin{pmatrix}
-5 & 2 & 3 \\
2 & 1 & 0 \\
3 & 0 & -1
\end{pmatrix}
\begin{pmatrix}
x \\
y \\
z
\end{pmatrix}
= 5
as suggested by the book:
is then
Next, I used the Principal Axes Theorem
and formed the determinant
\begin{vmatrix}
-5 -\lambda & 2 & 3 \\
2 & 1 -\lambda & 0 \\
3 & 0 & -1 -\lambda
\end{vmatrix}
which then gives the eigenvalies ##\lambda_1 = -7##, ##\lambda_2 = 2## and ##\lambda_3 = 0##. Then, the eigenvectors are ##\vec v_1 = (-4, 1, 2)##, ##\vec v_2 = (1, 2, 1)##, and ##\vec v_3 = (1, -2, 3)##. Then, I formed the matrix
P =
\begin{pmatrix}
-4 & 1 & 1 \\
1 & 2 & -2 \\
2 & 1 & 3
\end{pmatrix}
Then, I calculated ##P^{T}AP## such that
\begin{pmatrix}
-147 & 0 & 0 \\
0 & 12 & 0 \\
0 & 0 & 0
\end{pmatrix}
And finally,
(x_1 y_1 z_1)
\begin{pmatrix}
-147 & 0 & 0 \\
0 & 12 & 0 \\
0 & 0 & 0
\end{pmatrix}
\begin{pmatrix}
-x_1\\
y_1 \\
z_1
\end{pmatrix}
gave me ##-147x_1^2 + 12y_1^2 = 5##. Am I correct so far?
And what next? Do I have to say what this last equation is geometrically? How do I find that out?
I haven't gone through the details yet, but the plot looks o.k. But you still need a ##z-##component. It cannot be only a two dimensional object, as it was a three dimensional at the start. And isn't there a sign error in the eigenvalue matrix?
Likes lesdes
Yes there is a sign error in the eigenvalue matrix. But I only made the error when typing it in this thread. I will correct that now.
You do not have to check whether the eigenvalues, eigenvectors and the multiplication ##P^TAP## is correct. I let Mathematica do the computations.
But where do I get the third component from? As it is not there anymore due to the last multiplication. Also in the book example, after applying this procedure the last equation was two dimensional. Is this a mistake?
The third component is hidden. It's ##0 {z_1}^2## since there's a zero eigenvalue. It's a type of cylinder.
Likes lesdes
I guess Mathematica also needs a correct matrix, but maybe you have a special version.
Likes lesdes
P =
\begin{pmatrix}
-4 & 1 & 1 \\
1 & 2 & -2 \\
2 & 1 & 3
\end{pmatrix}
You need to normalize the eigenvectors before forming the matrix P. The diagonalized matrix will then have the eigenvalues on the diagonal. In fact, the theorem you quoted stated this. So once you found the eigenvalues, you knew enough to figure out the geometric shape.
Likes scottdave and lesdes
Something is wrong: for the matrix
$$A = \begin{bmatrix} -5 & 2 & 3 \\ 2 & 1 & 0 \\3 & 0 & -1 \end{bmatrix}$$
I let Maple do the computations, and got eigenvalues ##-7, 2, 0## and the associated eigenvectors. You need to remember that when forming the matrix ##P## you must use normalized eigenvectors (that is, forming an orthonormal set). Doing that in Maple I get
$$P = \begin{bmatrix}
-4/\sqrt{21} & 1/\sqrt{6} & 1/\sqrt{14} \\
1/\sqrt{21} & \sqrt{2/3} & -\sqrt{2/7} \\
2/\sqrt{21} & 1/\sqrt{6} & 3/\sqrt{14}
\end{bmatrix}
This gives
$$P^T A P = \begin{bmatrix} -7 & 0 & 0 \\ 0 & 2 & 0 \\ 0 & 0 & 0 \end{bmatrix}$$
as it should.
Likes lesdes
\end{bmatrix}
This gives
as it should.
Ah yes now I see. I have the same result through mathematica.
So now I have ##-7x^2 + 2y^2 = 5##. This result should be equivalent to ##−5x^2+y^2−z^2+4xy+6xz=5## as I understand it? Hence if I graph both in mathematica, then I should receive the same graph?
So now I've plotted both equations in mathematica and I have the following results
It might be that I did not understand the quadratic form purpose. I thought the purpose was to write a more complicated equation into a simpler form. I am a little bit confused now.
The variables will be different: using
$$\pmatrix{x'\\y'\\z'} = P \pmatrix{x\\y\\z}, $$
your equation in the "primed" variables will be
$$-7 x'^2 + 2 y'^2 = 5,$$
which is a cylinder parallel to the ##z'##-axis in ##(x',y',z')##-space. That will be a rotated cylinder in ##(x,y,z)##-space.
Likes lesdes
Related to Identify the quadratic form of the given equation
1. What is a quadratic form?
A quadratic form is an algebraic expression in which the variables are raised to the second power or higher, and the highest power of any variable is two. It can be written in the form of ax^2 + bx + c, where a, b, and c are coefficients.
2. How do you identify the quadratic form of an equation?
To identify the quadratic form of an equation, you need to check if the highest power of any variable is two. If it is, then the equation is in quadratic form. You can also look for the presence of the term "x^2" in the equation, which is another indication that it is a quadratic form.
3. What are the characteristics of a quadratic form?
A quadratic form has a U-shaped graph called a parabola, and it has one or two real roots depending on the value of the discriminant (b^2 - 4ac). It also has a vertical line of symmetry passing through its vertex.
4. Can a quadratic form have a negative coefficient?
Yes, a quadratic form can have a negative coefficient. In fact, the coefficient of x^2 determines the direction of the parabola. If the coefficient is positive, the parabola opens upwards, and if it is negative, the parabola opens downwards.
5. How is the quadratic form used in real life?
The quadratic form has many real-life applications, such as in physics to calculate the trajectory of a projectile, in engineering to design bridges and buildings, and in finance to model the growth of investments. It is also used in optimization problems to find the maximum or minimum value of a function.
  • Linear and Abstract Algebra
