I Identifying gluon in Feynman diagram
  • #51
CAF123 said:
but can you say anything about what the exchange of e.g a colour decuplet actually means
I don't think I can. As we went through before, in SU(3) charges are matrices instead of numbers. This tells you which matrices.
  • #52
Orodruin said:
I do not understand what deeper physical meaning you are trying to find that you find in the singlet and octet cases that you do not find in the decuplet and septenvigintuple cases.
Just to the extent that 3 and 8 are the relevant representations through which the fields of QCD transform. We don't discuss the 10 or 27 representation when developing QCD so I just wondered what is the physical meanings of these representations in the product state 8x8. Does that perhaps clarify my question?
  • #53
As far as we can tell, Nature has only picked singlets, triplets and octets for color representations of particles. In theory there could by 6's or 15's or 35's or... Just like the only elementary charges picked were 0, +/-1/3, +/- 2/3 and +/-1.
  • #54
Ok but what is the difference between a 8x8 configuration transforming in the 10 representation over one transforming in the 10bar or 27 rep?
There must be some physics there that is not encoded in say writing 8x8 = 1 + 8 + 35 + 10 + 3 + 7 or some other nonsensical sum of irreps. I realize that these decompositions are obtained by Young Tableuax but I am trying to understand what is the physical meaning of product states of the form 8x8 transforming in the 10 or 27 rep and the corresponding difference.
Thanks!
  • #55
A lot of the discussion in this thread was also brought up in the following video
1) At the beginning of it, it's said that a proton-proton scattering event cannot take place with the exchange of a single gluon. The argument is that an attempt to draw a Feynman diagram for this process results in colourful outgoing states with the exchange of a single octet. Now if I've understood this correctly, even though the diagram in the attachment is viable, when we sum over all possible quark colours the exchanged gluon would be equivalent to the ninth gluon, ie the one that transforms in the 1 of SU(3) colour and hence not physical.
(i.e I realize $b \bar b$ does not exist alone as one of the eight gluons (there is no linear combination of the eight orthogonal states to get a pure ##b \bar b## gluon state) but I could write the exchanged gluon as, say, ##b \bar b - g \bar g## which is a viable gluonic state and as far as I can see would not violate colour conservation in the above diagram. But if we change the quark colours that the gluon couples too, we would get a different gluon and the sum over all these for the full amplitude would amount to a non physical gluon).
2) I've seen in many sources that the colour factor ##C_F## for the amplitude between two colour singlet states mediated between a single gluon is given to be ##4/3##. It is then said this results in an interaction potential between two singlets to be ##-4/3 r^{-1}##. But if this process does not exist (as demonstrated e.g in the context of the proton proton scattering above) then what is the meaning of this non vanishing colour factor - should it not be identically zero since the process is not feasible?
See such remarks made in e.g, at the beginning of this video and at 55:30.
  • #56
Well, that's 20 minutes of my life I am not going to get back.
CAF123 said:
I've seen in many sources that the colour factor CFC_F for the amplitude between two colour singlet states mediated between a single gluon is given to be 4/34/3.
That's not what he's written down on the board. He's written down that scattering between two quarks, and those are triplets.
I'm done. Sorry, but in the time it took me to wade through the video and discover that this is not what he said, I could have helped a half-dozen other people.
Likes vanhees71
  • #57
No, as I wrote at the bottom of my last post, the relevant part of the video is around 55:30. I mentioned this precisely so as to avoid needless watching of the whole video and to hone in on exactly where my questions arose. To be exact, the relevant part is 55:13 - 1hr:04, where he starts by considering the scattering of two colour singlets through exchange of a single gluon and the state of the incoming quark antiquark pair is the entangled colour singlet ##\propto r \bar r + b \bar b + g \bar g##. He cranks through the colour factors and at about 1hr:04, notes the end result is just 4/3. I do not understand why this is non zero given that the process singlet -> singlet cannot be mediated through a single gluon.
  • #58
If you do the frigging calculation with the correct frigging matrices you'll get the frigging right answer.
If you keep trying to take shortcuts by using r,g and b, or following random Youtube videos by obviously confused professors, you might not.
Likes vanhees71
  • #59
See the same result quoted at the bottom of this page (immediately preceding the summary) https://www.ippp.dur.ac.uk/~krauss/Lectures/QuarksLeptons/QCD/SimpleExample_1.html
and e.g in the exercises of 'An introduction to particle physics' by Mann - 'Show that 2 mesons in the colour singlet state ##\frac{1}{\sqrt{3}} (r \bar r + g \bar g + b \bar b)## experience a potential V=-4/3 1/r'
So I wouldn't say the professor is confused or that it is a random video. I am the one who is confused about this issue hence I ask on the forum.
Perhaps @Orodruin @vanhees71 can chip in again?
Thanks
  • #60
That is the force between two triplets that are in the overall singlet state. It is not, repeat not, the force between two singlets.
  • #61
Not between two mesons. That is the short range potential between quark and anti-quark in a (colour singlet) meson, i.e., the QCD (colour) analogue of the attractive QED (electrostatic) potential. It is this potential that makes mesons the mesons we observe.
At short distances QCD is asymptotically free. This means that the q-q interaction gets weaker at short inter-quark distances, and at r \sim 0.1 \mbox{fm} the lowest order (one-gluon exchange) diagrams dominate. So, it is not unreasonable to expect a Coulomb-like potential analogous to that arising from one-photon exchange in QED. Indeed, we can show that \langle q\bar{q}|V(r) |q\bar{q}\rangle_{\mbox{singlet}} = -\frac{4}{3} \frac{\alpha_{s}}{r} , \ \ \ r \sim 0.1 \mbox{fm} . The factor 4/3 arises from summing the colour factors of all possible lowest-order q_{i}\bar{q}_{k} \to q_{j}\bar{q}_{l} partonic processes in the colour singlet meson. The colour factor for such partoinc processes arises when we calculate the Feynman amplitude \mathcal{M}\left( q_{i}\bar{q}_{k} \to q_{j}\bar{q}_{l} \right). It is defined by C \left( q_{i}\bar{q}_{k} \to q_{j}\bar{q}_{l} \right) = \left( \frac{\lambda^{a}}{2}\right)_{ji} \left( \frac{\lambda^{a}}{2}\right)_{kl} . Now, group theory comes to the rescue because of the following identity \left( \frac{\lambda^{a}}{2}\right)_{ji} \left( \frac{\lambda^{a}}{2}\right)_{kl} = \frac{1}{2} \left( \delta_{jl} \delta_{ik} - \frac{1}{3}\delta_{ji}\delta_{kl} \right) . So, you find the following colour factors C(x\bar{x} \to x\bar{x}) = \frac{1}{3}, \ \ \ x = r, g, b , C(x\bar{x} \to y\bar{y}) = \frac{1}{2} , \ \ \ x \neq y , C(x\bar{y} \to x\bar{y}) = - \frac{1}{6} \ \ \ x \neq y .
So, “inside” the colour singlet meson, we have 3 partonic processes (diagrams) of the form x\bar{x} \to x\bar{x} and 6 diagrams of the form x\bar{x} \to y\bar{y}. Thus C(q\bar{q} \to q\bar{q})_{\mbox{singlet}} = (\frac{1}{\sqrt{3}})^{2} \left( 3 \times (1/3) + 6 \times (1/2) \right) = \frac{4}{3} .
In similar but more complicated way, you can calculate the colour factor for two quarks exchanging a gluon within a colour-singlet Baryon qqq. However, one can deduce the value C(qqq)_{[1]} = 2/3 by simple group theory arguments.
Likes dextercioby
  • #62
Thanks @samalkhaiat ! Few comments-
1)Why is it clear that this process describes the interaction between a q qbar pair in a single meson rather than the interaction between two mesons? I see, for example, that only the t channel exchange is considered and not a s channel. I am thinking that it is the s channel exchange that would describe an interaction between two mesons perhaps? Then the group theory factors are ##\lambda^a_{ki} \lambda^a_{lj}## and by summing over k and i (and also l and j) for colour singlet in initial (and final) state I get factors of ##\text{Tr} \lambda_a## which are identically zero (ie singlet -> singlet via one gluon is not permissible).
2) Where do the factors of ##1/\sqrt{3}## (used in the final equation display) come from in your analysis?
Thanks
  • #63
1) You seem to over-look the most obvious facts and jump to strange and unfunded conclusions: the interaction potential between e^{-} and p^{+} in the Hydrogen atom is - \frac{\alpha}{r}. Do two Hydrogen atoms experience the same potential?
2) We can explain the heavy mesons spectrum very well by solving the Schrodinger equation for q\bar{q} system with potential of the form V(r) = - \frac{4}{3} \frac{\alpha_{s}}{r} + b r + \mbox{spin-dependent potential} .
Perhaps you should tell me: why and how is that so? Can you show me how to write the meson-meson scattering amplitude in terms of their constituent quarks?
Look, the singlet state contains equal contributions from r\bar{r}, \ g\bar{g} and b\bar{b}. Hence you only need to evaluate, say, the r\bar{r} contribution and multiply this by 3: 3 \cdot \frac{1}{\sqrt{3}} \left(r\bar{r} \right) \cdot \frac{1}{\sqrt{3}} \left(r\bar{r} + g\bar{g} + b\bar{b} \right) . Now, the colour factors for r\bar{r} \to r\bar{r} , \ r\bar{r} \to g\bar{g} and r\bar{r} \to b\bar{b} are C = \frac{1}{3} , \ \frac{1}{2} and \frac{1}{2} respectively, giving you an overall colour factor C(q\bar{q} \in [1]) = \frac{4}{3} .
  • #64
1)Ok, indeed after reconsideration I see it cannot be. I suppose, however, the s channel exchange is then a viable diagram for the interaction between a q and q bar inside a single meson except that after imposition of the colour algebra its contribution simply vanishes so we are left with only the t channel exchange as discussed solely in the video too? (I say the s channel exchange is zero because it gives the factor ##\text{Tr} \lambda^a## outside the amplitude which is zero).
2) In the attachment of this post, I draw a diagram for one of the contributions to the naive process meson + meson - > meson + meson scattering through one gluon exchange. This diagram is consistent as far as I can see with all colour conservation and viable gluon mediation state. I call this a 'naive' process because it's well known that a singlet -> singlet cannot happen by exchange of one gluon. So it must be the case that by summing up all possible colour configurations for the quarks, it is then seen that the full amplitude for this process is zero. Is it the case that in this summation of all colour configurations, perhaps the exchanged gluon would be equivalent to the ninth (i.e unphysical SU(3) singlet) gluon and hence the process is not viable? (this is also alluded to in the video at the beginning for the pp -> pp scattering).
Thanks!
