Identifying Identical Points Using Overlapping Error Ellipses
In summary, the conversation discusses using a least squares software to generate coordinates and error ellipses, and determining if two points are identical based on their error ellipses. The speaker is seeking guidance on how to approach this problem, and a suggestion is given to create an error ellipse for the difference between the points. The complexity of the process depends on the correlation of the uncertainties in the measurements.
Scott S
I'm not very familiar with statistics, so that's my main problem.
I use a least squares software to generate the coordinates of points and their associated 95% error ellipses. If the error ellipses meet a certain pre determined tolerance then I'm done.
However, I have a situation where I have two points which should be identical in Y and X coordinates but are 500 meters apart in elevation.
Of course the error ellipses are slightly different in size and orientation for each point.
Is there (a relatively easy to understand) method to determine if these points are identical based on the error ellipses?
I've done some research and can't find anything which relates to this particular problem.
So, any help or guidance would be greatly appreciated.
Thanks, Scott.
You can make an error ellipse for the difference between the points and see if zero is included. If their individual uncertainties are uncorrelated, this process is quite easy, if not it is more complicated and it will depend on how your measurements are done.
Likes Scott S
Ah! Nice!
Thank you very much.
Related to Identifying Identical Points Using Overlapping Error Ellipses
1. What are overlapping error ellipses?
Overlapping error ellipses are graphical representations of uncertainty in scientific data. They are used to show the range of possible values for a set of measurements or observations, taking into account the margin of error for each individual data point.
2. How are overlapping error ellipses calculated?
Overlapping error ellipses are calculated using statistical methods such as standard deviation or confidence intervals. The size and orientation of the ellipse is determined by the magnitude and direction of the uncertainty in the data.
3. What do overlapping error ellipses indicate?
Overlapping error ellipses indicate the degree of uncertainty in a set of data. The more overlapping the ellipses are, the greater the uncertainty in the data. On the other hand, if the ellipses do not overlap at all, it suggests a high level of confidence in the accuracy of the data.
4. How can overlapping error ellipses be used in scientific research?
Overlapping error ellipses can be used to compare and analyze data from different sources or experiments. They can also be used to identify potential areas of agreement or disagreement between data sets, which can inform further research and experimentation.
5. Are there any limitations to using overlapping error ellipses?
Yes, there are some limitations to using overlapping error ellipses. They are based on statistical assumptions and may not accurately represent the true uncertainty in the data. Additionally, they may not be suitable for all types of data, such as non-normal or highly skewed data.
  • Differential Geometry
12K
  • STEM Academic Advising
