Identifying unknown organic compounds
In summary, a chemist found that liquids P and Q (in no specific order) reacted with bromine, while R did not. When sodium carbonate was added, R produced bubbles of gas, but P and Q did not. When metallic sodium was added, P and R produced gas, while Q did not. The reactions can be represented by the following equations: P + Br2 → P-Br, R + Na2CO3 → R-CO3 + Na+, P + 2Na → P-Na + Na+. Bromine can react with both butyric acid and heptyne due to their double and triple bonds, respectively.
Shaybay92
124
A chemist has three liquids (Ethanol, butanoic acid and 3-heptyne) labelled P,Q,R (in no specific order). When drops of bromine solution were added to samples of each liquid, P and Q decolorised the bromine, but R did not. When drops of sodium carbonate solution were added to fresh samples, R produced bubbles of colourless gas, but P and Q did not. When ap iece of sodium metal was added to fresh samples of the three liquids, P and R produced bubbles of gas, but Q did not.
Find P, Q, R and give equations for each of the reactions that occurred.
P - Reacted with Bromine, Reacted with sodium to give gas
Q - Reacted with Bromine
R - Gave off bubbles with Na2CO3, Reacted with sodium to give gas
I'm not sure of the reaction with metallic sodium. What gas is given off when it is added to organic compounds? Also does bromine only react with the butanoic acid and heptyne because they have double/triple bonds??
It can react with slighly acidic protons - similarly to the reaction with water.
Yes for heptyne, no for butyric acid.
http://en.wikipedia.org/wiki/Bromine#Organic_chemistry
you would need more information to accurately identify the unknown compounds P, Q, and R. While the reactions described can give some clues about the properties of these compounds, they are not sufficient to determine their chemical structures. In order to accurately identify the compounds, you would need to perform further tests and analyses, such as infrared spectroscopy or mass spectrometry, to determine the functional groups and molecular structures present in each compound. Additionally, you may need to compare the results of these tests with known compounds in order to make a definitive identification. Without this additional information, it is difficult to give equations for the reactions that occurred. As for the gas given off when sodium is added to organic compounds, it could vary depending on the specific compounds present. It is possible that the gas given off could be hydrogen or a hydrocarbon gas. Again, without further testing and analysis, it is difficult to determine the exact gas produced.
FAQ: Identifying unknown organic compounds
1. What is the process for identifying an unknown organic compound?
The process for identifying an unknown organic compound involves several steps. First, the compound is analyzed using techniques such as mass spectrometry, infrared spectroscopy, and nuclear magnetic resonance spectroscopy to determine its molecular weight and structure. Next, the compound can be subjected to various chemical tests to observe its reactivity and functional groups. Finally, the results from these tests are compared to known compounds in databases or literature to identify the unknown compound.
2. What are the most common techniques used to identify unknown organic compounds?
The most common techniques used to identify unknown organic compounds include mass spectrometry, infrared spectroscopy, and nuclear magnetic resonance spectroscopy. These techniques provide information about the molecular weight, functional groups, and structure of the compound, which can be compared to known compounds to identify the unknown.
3. How accurate are the results from identifying unknown organic compounds?
The accuracy of the results from identifying unknown organic compounds depends on the quality of the data obtained and the expertise of the scientist performing the analysis. It is important to carefully interpret the data and consider all possible factors that may affect the results. In some cases, further testing may be necessary for a more accurate identification.
4. Can unknown organic compounds be identified without using specialized equipment?
While specialized equipment such as mass spectrometers and spectroscopes are often used to identify unknown organic compounds, there are also chemical tests that can be performed using common laboratory equipment. However, the results from these tests may not be as precise and may require further analysis to accurately identify the compound.
5. What are the limitations of identifying unknown organic compounds?
The limitations of identifying unknown organic compounds include the availability of reference databases and the complexity of the compound. If there is no match in the databases, it may be difficult to determine the exact identity of the compound. Additionally, highly complex compounds may require extensive testing and analysis, which can be time-consuming and expensive.
