Identifying zero force members in truss
In summary, zero force members in trusses are structural members that do not experience any force or stress when the truss is loaded. They can be identified using the method of joints or the method of sections. It is important to identify these members because they do not contribute to the strength or stability of the structure and can be removed to reduce weight and cost. They can be present in all types of trusses, but identifying them may be limited by assumptions and external loads or reactions.
fredonon
http://imgur.com/lPIRaie
1. What are the Zero force members in this truss?
2. Is the truss internally statically determinate?
Im not too sure what question 2 is but I would guess yes?
Many thanks~
Please post homework/coursework questions in the appropriate HW forum after filling out the HW template. Be sure to include an attempt at solution when posting the question.
The Technical Forums are not intended to host HW threads.
Related to Identifying zero force members in truss
1. What are zero force members in trusses?
Zero force members in trusses are structural members that do not experience any force or stress when the truss is loaded. This means that they do not contribute to the overall stability or strength of the structure.
2. How do you identify zero force members in trusses?
To identify zero force members in trusses, you can use the method of joints or the method of sections. In the method of joints, you check for any members that are connected to only two other members and have no external forces acting on them. In the method of sections, you draw a section through the truss and check for any members that are not cut by the section and have no external forces acting on them.
3. Why is it important to identify zero force members in trusses?
Identifying zero force members in trusses is important because they do not contribute to the strength or stability of the structure. This means that they can be removed without affecting the overall integrity of the truss, which can help to reduce the weight and cost of the structure.
4. Can zero force members be present in all types of trusses?
Yes, zero force members can be present in all types of trusses, including simple, complex, and compound trusses. However, the number and location of these members may vary depending on the design and loading conditions of the truss.
5. Are there any limitations to identifying zero force members in trusses?
Identifying zero force members in trusses is based on the assumption that the truss is perfectly rigid and all connections are completely frictionless. In real-life structures, these assumptions may not hold true, which can lead to errors in identifying zero force members. Additionally, the presence of external loads or support reactions may also affect the accuracy of the results.
  • Mechanical Engineering
