Identity element for group theory
In summary: All the pieces are there, you just have to put them togetherIn summary, to prove that (S, *) is a group where S is the set of all real numbers except for -1, we must follow the axioms of associativity, identity element, and inverse. The identity element for S is 0, which can be shown by plugging it into the definition for *. To find the inverse, we must solve for an element that satisfies the equations for the identity element. Both of these steps require using ordinary addition and multiplication of real numbers.
kala
Show that (S, *) is a group where S is the set of all real numbers except for -1. Define * on S by a*b=a+b+ab
Well I know that i have to follow the axioms to prove this. So I started with G1 which is associativity. This one I got to work. Then G2 says i need to find an identity element. But this is where i got confused. I think that the identity element is 0. but i don't know if that is write. I don't really know how to find it. Then finally G3 is the inverse and I also got stuck here. I don't really know what the inverse would be. Can anyone help.
you just need to work from the definition
so you want to find an element, call it "e", s.t
a*e=e*a. (need to check this holds both ways)
plug that into the definition for *. what i mean is replace the b with e and solve for e. try that. if it works one way you need to show that it works the other way.
Just a note, if this group commutes or is abelian you only need to show one direction, but you would need to show commutativity.
There's an easy way to tell -- plug it into see if it satisfies the identity.
Yes you do; you're just being timid. You know the equations that the identity is supposed to satisfy... and you know how to turn it into an ordinary equation involving ordinary addition and ordinary multiplication of real numbers... and you know how to solve equations involving ordinary addition and ordinary multiplication of real numbers... You know all the steps involved, and the path is direct, you just have to start moving.
Again, same situation as the last question.
FAQ: Identity element for group theory
What is the identity element for group theory?
The identity element for group theory is an element that, when combined with any other element in the group, results in the same element. In other words, it is the equivalent of the number 1 in multiplication, where any number multiplied by 1 is equal to that number.
Why is the identity element important in group theory?
The identity element is important in group theory because it provides a reference point for all other elements in the group. It allows for the creation of inverse elements and the ability to perform operations on the group without changing its structure. It also helps to define the group's properties and relationships between its elements.
Can there be more than one identity element in a group?
No, there can only be one identity element in a group. This is because if there were multiple identity elements, it would break the definition of an identity element as a unique element that produces the same result when combined with any other element in the group.
Is the identity element the same for all groups?
No, the identity element can vary depending on the group. For example, in a group of integers under addition, the identity element is 0, but in a group of positive integers under multiplication, the identity element is 1. It is specific to the operations and elements defined within a particular group.
How is the identity element represented in group theory?
The identity element is often represented as the identity matrix, denoted by the letter "I". However, depending on the group, it can also be represented by other symbols or notations, such as the number 1 or the identity function.
