Identity permutation as product of even number of 2-cycles
In summary, according to Gallian, r can't be 1 since then it won't map all elements to themselves. If r=2, then it's already even, nothing else to do. If r>2, then consider the last two factors: ##\beta_{r-1} \beta_r##. Let the last one be (ab). If the rightmost 2-cycle is (ab), then r is even.
Kaguro
221
57
Prove that the identity permutation can be written as ##\beta_1 \beta_2...\beta_{r-1} \beta_r## where ##\beta## are 2-cycles and r is even.
None
The book I'm following (Gallian) basically says:
If r>2,
Then consider the last two factors: ##\beta_{r-1} \beta_r##.
Since the order of elements inside a two cycle is irrelevant (xy)=(yx), all possible ways to write the last two factors are:
(ab)(ab)
(ac)(ab)
(bc)(ab)
(cd)(ab)
Why?!
What happened to the other ones like : (ad)(ab) and (bd)(ab) ?
Kaguro said:
Homework Statement:: Prove that the identity permutation can be written as ##\beta_1 \beta_2...\beta_{r-1} \beta_r## where ##\beta## are 2-cycles and r is even.
Relevant Equations:: None
If r>2,
(ab)(ab)
(ac)(ab)
(bc)(ab)
(cd)(ab)
Why?!
I don't understand the problem. Are you sure you translated it correctly? You can always write ##1=\prod_{k=1}^ng_k \cdot \left(\prod_{k=1}^ng_k\right)^{-1} ## in any group. Here e.g. ##(1)=\ldots (ef)(cd)(ab)(ab)(cd)(ef)\ldots##
Kaguro said:
Check this one:
https://math.stackexchange.com/ques...itten-as-the-product-of-r-transpositions-then
All the answers mention that if (ab) is the last element then there can be only 4 types of transpositions possible for the second last element.
Maybe, but you said: "if ... then can be written as ... " and I gave the answer that this is always trivially the case:
1 = g_n (g_{n-1}(g_{n-2}(\ldots (g_3(g_2(g_1g_1^{-1})g_2^{-1})g_3^{-1}) \ldots )g_{n-2}^{-1})g_{n-1}^{-1})g_n^{-1}
##2n## elements whose product is ##1## - in any group.
Likes Kaguro
See the proof from Gallian textbook:
Clearly, r ##\neq 1##, since a 2-cycle is not the identity. If r = 2, we
are done. So, we suppose that r > 2, and we proceed by induction.Suppose that the rightmost 2-cycle is (ab). Then, since (ij) = ( ji), the product ##\beta_{r-1} \beta_r## can be expressed in one of the following forms shown on the right:
e= (ab)(ab),
(ab)(bc) = (ac)(ab),
(ac)(cb) = (bc)(ab),
(ab)(cd) = (cd)(ab).
If the first case occurs, we may delete ##\beta_{r-1} \beta_r ## from the original product
to obtain ##\epsilon =\beta_1 \beta_2 ... \beta_{r-2}##, and therefore, by the Second Principle of
Mathematical Induction, r -2 is even. In the other three cases, we replace the form of ##\beta_{r-1} \beta_r## on the right by its counterpart on the left to obtain a new product of r 2-cycles that is still the identity, but where the rightmost occurrence of the integer a is in the second-from-the-rightmost 2-cycle of the product instead of the rightmost 2-cycle.
We now repeat the procedure just described with ##\beta_{r-2} \beta_{r-1}##, and, as before, we
obtain a product of (r - 2) 2-cycles equal to the identity or a new product of r 2-cycles, where the rightmost occurrence of a is in the third 2-cycle from the right. Continuing this process, we must obtain a product of
(r - 2) 2-cycles equal to the identity, because otherwise we have a product equal to the identity in which the only occurrence of the integer a is in the leftmost 2-cycle, and such a product does not fix a, whereas the identity does. Hence, by the Second Principle of Mathematical Induction, r - 2 is even, and r is even as well.
I don't understand how can the author say only these are the possible elements..
Can you help me?
Yes. I see this is obviously one way to write the identity. I'm trying to see why every possible identity has to be a product of even number of 2-cycles?
Firstly, I think the statement which is proven is another than you wrote it is. It says:
If we have a product of length ##r## of transpositions which multiply to the identity, then ##r## is necessarily even.
It doesn't say there is such a representation, it says if there is such a representation, then its length is even. It is a step towards the theorem that the sign function is a group homomorphism ##\varphi \, : \,\operatorname{Sym}(n) \longrightarrow \{\pm 1\}\, , \,\varphi (\sigma )=(-1)^r##.
Secondly, that there are only four possibilities is a simple observation: Given ##(ab)## as last transposition on the right, and having another transposition ##(xy)## on the left of it, then there are obviously four possibilities:
##\{a,b\}\cap\{x,y\}=\{a,b\}\, , \,\{a,b\}\cap\{x,y\}=\{a\}\, , \,\{a,b\}\cap\{x,y\}=\{b\}\, , \,\{a,b\}\cap\{x,y\}=\emptyset ##. These are all possible constellations for the numbers ##x,y.##
Likes Kaguro
... Oh.
Didn't think of it like that.. So c and d are just placeholders for any number which is not a and b. So (bc) and (bd) are equivalent. And (ac) and (ad) are equivalent...
Right... I'm an idiot.
Thank you very much! Now I can progress.:biggrin:
