coverband
- 171
- 1
If |2/x| = y does 1 = |x/2|y ?
To solve this equation, you need to isolate the absolute value on one side of the equation. You can do this by dividing both sides by 2, which will give you |x| = 2y. Then, you can remove the absolute value by considering both the positive and negative solutions, giving you x = 2y or x = -2y.
This equation represents a relationship between the absolute value of a number and a variable. It is saying that the absolute value of 2 divided by x will always equal y. This can be seen as a function where y is the output and x is the input.
To graph this equation, you can first plot the points where x = 2y and x = -2y. Then, you can draw a line connecting these points. The graph will be a V-shaped curve, with the vertex at the origin (0,0).
The equations are related in that they have the same solution set. When solving the original equation, you get two possible solutions: x = 2y or x = -2y. When substituting these values into the second equation, you will get 1 for both solutions, showing that they are equivalent.
This equation can be applied in situations where there is a known relationship between two quantities, and the absolute value of one quantity is proportional to the other quantity. For example, in physics, the speed of an object can be represented by |2/x|, where x is the distance traveled and y is the time taken. In this case, y would represent the speed of the object.
