MHB If a and b are unit vectors....
If vectors a and b are unit vectors and |a + b| = sqrt(2), the dot product (2a - b) · (a + 3b) simplifies to -1. This result arises because the condition |a + b| = sqrt(2) implies that a and b are orthogonal, leading to a · b = 0. The calculation shows that (2a - b) · (a + 3b) equals 5(a · b) - 1, which confirms the answer is indeed -1. The discussion clarifies how the zero product property applies in this context. Thus, the conclusion that the dot product equals -1 is validated.
Raerin
If a and b are unit vectors and |a + b| = sqrt(2). What is the value (dot product) of (2a-b).(a+3b)?
Is the answer -1 by any chance? If not...
I know how to find the dot product and find the magnitude and add vectors, etc. but I have never came across this a question before. I am very unclear on how to do it.
Mathematics news on Phys.org
Re: If a nd b are unit vecotrs...
Note that
\[\begin{aligned} (2\mathbf{a}-\mathbf{b}) \cdot (\mathbf{a}+3\mathbf{b}) &= 2\mathbf{a}\cdot\mathbf{a} +6\mathbf{a}\cdot\mathbf{b} - \mathbf{a}\cdot\mathbf{b} -3\mathbf{b}\cdot\mathbf{b} \\ &= 2\|\mathbf{a}\|^2 +5\mathbf{a}\cdot\mathbf{b} - 3\|\mathbf{b}\|^2\\ &= 5\mathbf{a}\cdot\mathbf{b} - 1\quad\text{since $\mathbf{a}$ and $\mathbf{b}$ are unit vectors}\end{aligned}\]
Since $\|\mathbf{a}+\mathbf{b}\| = \sqrt{2}$, squaring both sides and expanding via dot product leaves you with
\[\|\mathbf{a}\|^2+ 2\mathbf{a}\cdot\mathbf{b} + \|\mathbf{b}\|^2 = 2 \implies 2\mathbf{a}\cdot\mathbf{b} = 0\implies \mathbf{a}\cdot\mathbf{b} = 0\]
Therefore, we now have that
\[(2\mathbf{a}-\mathbf{b})\cdot (\mathbf{a}+3\mathbf{b}) = 5\mathbf{a}\cdot\mathbf{b} - 1 = -1\]
So yes, your answer is correct.
Chris L T521 said:
Note that
I don't understand how 2a . b = 0 becomes a . b = 0. Does the 2 become irrelevant if the dot product is 0?
Also, if a . b = 0 then 5a . b -1 be 5(0) - 1 and that's how you get -1?
Since $\mathbf{a}\cdot\mathbf{b}$ is a scalar, then by the zero product property $2\mathbf{a}\cdot \mathbf{b} = 0$ implies that either $2=0$ (which is absurd) or $\mathbf{a}\cdot\mathbf{b}=0$ (which is the correct choice). With that result, you can now substitute zero in for $\mathbf{a}\cdot\mathbf{b}$ in the simplified form of $(2\mathbf{a}-\mathbf{b})\cdot(a+3\mathbf{b})$ to get $5\mathbf{a}\cdot\mathbf{b} - 1 = 5(0) - 1 = -1$.
I hope this clarifies things! (Bigsmile)
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
