If a bead is placed on a rod and rotated...
In summary, the conversation discusses the problem of a bead placed on a rod with a coefficient of friction m and an initial angular velocity a, and finding the time it takes for the bead to start moving when neglecting gravity. The concept of normal force is brought up and clarified, with the understanding that the rod and bead are in contact and experiencing friction. It is mentioned that some force is causing the acceleration of the bead.
Vriska
138
A bead is placed on a rod with coefficient of friction m, it's accelerated from rest with angular velocity a, find the time it takes to start moving. Neglect gravity
Force of friction =Nm
They said there's no gravity, so i don't quite see where the normal force is coming from so it'd fly off instantly. Well this is the wrong answer, where the heck is the normal force coming from? If i do this in space, id expect the rod to just move on without doing anything bc it's actually not pressing against anything
Its a bead on the rod. The bead has a hole in it and the rod passes through the hole snugly hence there's friction when it moves. Some force causes it to accelerate.
Oh thanks, i thought it was a bead on top of a road : 7.
Related to If a bead is placed on a rod and rotated...
1. What is the purpose of placing a bead on a rotating rod?
The purpose of placing a bead on a rotating rod is to study the effects of rotational motion on the bead, such as changes in speed, direction, and acceleration.
2. How does the position of the bead change as the rod rotates?
The position of the bead changes as the rod rotates due to the centripetal force, causing the bead to move in a circular path around the center of rotation.
3. What factors affect the speed of the bead on the rotating rod?
The factors that affect the speed of the bead on the rotating rod include the length of the rod, the angle of rotation, the mass of the bead, and the force applied to the rod.
4. Can different types of beads be used on a rotating rod?
Yes, different types of beads can be used on a rotating rod as long as they are able to move freely along the rod and are not too heavy to cause the rod to break or bend.
5. How can the motion of the bead on the rotating rod be represented mathematically?
The motion of the bead on the rotating rod can be represented mathematically using equations of rotational motion, such as torque, angular velocity, and angular acceleration.
14K
11K
