If a beam of light with an angle of incidence
In summary, the angle of incidence is the angle at which a beam of light hits a surface, measured between the incident ray and the normal line. It determines the angle of reflection or refraction, and is equal to the angle of reflection in the law of reflection. The intensity of light is not affected by the angle of incidence, and it can be greater than 90 degrees, known as an oblique angle.
samrifai13
The maximum depth of Lake Baikal, in Russia, is 1780.7 m, making it the world’s deepest freshwater lake. If a beam of light with an angle of incidence of 59.42o enters the water from the air, what is the horizontal distance between the point where the light enters the water and the point where it strikes the lake’s bottom?
hi samrifai13! welcome to physicsforums. How far have you got in the question? If you don't post your working so far, we don't know how to help.
Related to If a beam of light with an angle of incidence
1. What is the angle of incidence?
The angle of incidence refers to the angle at which a beam of light hits a surface. It is measured between the incident ray (the incoming beam of light) and the normal line, which is a line perpendicular to the surface at the point of incidence.
2. How does the angle of incidence affect the path of light?
The angle of incidence determines the angle at which the light is reflected or refracted. If the angle of incidence is equal to the angle of reflection, the light will be reflected back in the same direction. If the angle of incidence is greater or smaller, the light will be refracted or bent as it passes through the surface.
3. What is the relationship between the angle of incidence and the angle of reflection?
The angle of incidence and the angle of reflection are equal in a phenomenon called the law of reflection. This means that the angle of reflection is always equal to the angle of incidence, measured from the normal line.
4. How does the angle of incidence affect the intensity of light?
The intensity of light is not affected by the angle of incidence. The intensity of light is determined by the properties of the light source and the material it is passing through, not the angle at which it hits a surface.
5. Can the angle of incidence be greater than 90 degrees?
Yes, the angle of incidence can be greater than 90 degrees. This is known as an oblique angle of incidence and can occur when light is passing through a medium with a higher refractive index, causing the light to bend away from the normal line.
