If A is dense in [0,1] and f(x) = 0, x in A, prove ∫fdx = 0.
In summary, the claim holds true for Riemann-integration as long as the set ##A## is dense in ##[0,1]## and the function ##f## is Riemann-integrable, with the integral equaling zero.
Eclair_de_XII
1,083
91
"A set ##A\subset [0,1]## is dense in ##[0,1]## iff every open interval that intersects ##[0,1]## contains ##x\in A##. Suppose ##f:[0,1]\rightarrow ℝ## is integrable and ##f(x) = 0,x\in A## with ##A## dense in ##[0,1]##. Show that ##\int_{0}^{1}f(x)dx=0##."
Let ##P=\{x_1,...,x_n\}## be a partition of ##[0,1]##
##M_i=sup\{f(x):x\in[x_{i-1},x_i]\}##
##m_i=inf\{f(x):x\in[x_{i-1},x_i]\}##
##U(P,f)=\sum_{i=1}^nM_i(f)(x_i-x_{i-1})##
##L(P,f)=\sum_{i=1}^nm_i(f)(x_i-x_{i-1})##
##\int_{0}^{1} fdx=sup\{L(P,f):P \space \text {a partition of} \space [0,1]\}=inf\{U(P,f):P \space \text {a partition of} \space [0,1]\}##
I haven't actually attempted a solution yet; everything that follows is scratchwork...
Basically, I think I have to use the fact that ##A## being dense in ##[0,1]## gives the following implication:
##\int_{x\in A}f(x)dx=0 \space ⇒ \int_{0}^{1} f(x)dx=0##,
since ##f(x)=0,\forall x\in A##, then ##\int_{x\in A} f(x)dx=0##.
So my plan is to construct a series of open intervals that intersect ##[0,1]## as such:
##Q_i=(a_i,b_i)## where ##a_i=b_{i-1}##
Then, I define the initial open interval as ##Q_0=(a_0,b_0)##, with ##a_0\leq 0## and ##b_0 > 0## and the final open interval as ##Q_n=(a_n,b_n)## where ##b_n\geq 1##.
Then I construct a partition using those open intervals with ##(x_{i-1},x_i)=(a_i,b_i)##, with ##x_0=0## and ##x_n=1##. So I would construct a lower and upper sum, which by the conditions of the problem, must be equal to each other, and equal to zero (still going to need to figure this part out).
This is my current idea of how to handle the problem. Can anyone tell me if anything I have written is off? Thanks.
The claim is not true with the usual definition of integrable, which is Lebesgue-integrable. The Indicator function that is 1 on the irrational numbers and zero elsewhere is Lebesgue-integrable and has integral 1 on [0,1], even though the set on which it is zero - the rational numbers in [0,1] - is dense.
The claim may be true if we restrict ourselves to Riemann integration, as the above indicator function is not Riemann-integrable.
From your plan outline, it looks like you are working with Riemann integrals. Some element of the proof will have to exclude cases like the irrational indicator function on the grounds that they are not Riemann-integrable. Also, the proof will need to use the density of ##A##, a fact that the above plan does not reference.
I think the proof can be easier than your plan.
First prove that the 'sup' bit is zero, using the density premise. This is the only bit where you need to refer to partitions.
Then complete the proof using the premise that ##f## is integrable. What does that premise tell us about the relation between the 'sup' bit and the 'inf' bit?
Sorry; I should have mentioned that this class is working with Riemann integration, and that ##f## is Riemann-integrable.
My guess:
Let ##O## be an open interval such that ##O\cap [0,1]\neq ∅##.
Because ##A## is dense in ##[0,1]##, ##O\cap [0,1] \subseteq A##. So let ##P=\{x_1,...,x_n\}##.
Then, since ##A## is dense in ##[0,1]## and if ##x\in (a,b)\subset [0,1]##, then ##f(x)=0##.
So ##m_i=inf\{f(x):x\in (x_{i-1},x_i)\subset [x_{i-1},x_i]\}=0,\forall i\in ℕ##, since we assume that ##f(x)\geq 0,\forall x\in ℝ##.
So ##sup\{L(P,f)\}=0##. Since ##f## is Riemann-integrable, ##sup\{L(P,f)\}=inf\{U(P,f)\}=\int_{0}^{1} f(x)dx=0##.
Related to If A is dense in [0,1] and f(x) = 0, x in A, prove ∫fdx = 0.
1. What does it mean for A to be dense in [0,1]?
A set A is said to be dense in [0,1] if every point in [0,1] is either in A or a limit point of A. In other words, for any point x in [0,1], there exists a sequence of points in A that converges to x.
2. How does A being dense in [0,1] relate to the integral of f(x)?
Since A is dense in [0,1], it means that there are infinitely many points in A that are close to any given point in [0,1]. Therefore, the integral of f(x) over [0,1] is essentially the same as the integral of f(x) over A, since the points outside of A will have a negligible effect on the overall integral.
3. Why is it important that f(x) = 0 for x in A?
If f(x) was not equal to 0 for x in A, then the integral would not necessarily be 0. This is because the points in A would have a non-zero contribution to the integral, and since A is dense in [0,1], this contribution would be significant.
4. How does the density of A in [0,1] affect the proof of ∫fdx = 0?
The density of A in [0,1] is crucial in the proof, as it allows us to use the fact that the integral of a continuous function over an interval is equal to the limit of integrals over subintervals. This allows us to break up the integral over [0,1] into smaller intervals that contain points from A, making the integral of f(x) over A easier to calculate.
5. Can this theorem be applied to other intervals besides [0,1]?
Yes, this theorem can be applied to any closed interval, as long as A is dense in that interval and f(x) is equal to 0 for x in A. However, the specific values of the integral may vary depending on the interval and the function.
