If a plane has more than 2 principal axes ?
In summary, the statement that "If a plane has more than 2 principal axes (axes of symmetry) through a point, then every axis through that point must be a principal axis" is not necessarily true for all plane figures. It may only hold true for certain figures, such as circles, squares, or regular hexagons. The concept of a "principal point" is further explained in the attached document on p. 25. It is also unclear if this statement is meant to apply to figures or to the plane itself. Further clarification is needed to fully understand its meaning.
phydis
28
" If a plane has more than 2 principal axes (axes of symmetry ) through a point, then every axis through that point must be a principal axis "
I can understand above statement regarding a circle, but square also has more than 2 principal axes, how can it be true for every axis of a square or a regular hexagon ?
someone please explain this..
Thank you!
A "plane" has an infinite number of axes of symmetry through every point.
When you write "plane", I think you must mean more... plane figures, planer bound shapes, polygons?
Since you mention examples of a circle, square, and regular hexagon, if you mean such as that, I'm not sure what the idea means.
For further example, an equilateral triangle has three axes through the center point that are clearly symmetric (bilateral symmetry), but other lines through that midpoint do not show any symmetry.
Are you sure the statement is meant to apply to figures? The statement reads like a mangled and circular definition of a plane itself, or some kind of corollary concerning non-Euclidean geometry...?
What is the context?
Likes 1 person
Related to If a plane has more than 2 principal axes ?
1. What are principal axes in relation to a plane?
The principal axes of a plane refer to the three orthogonal axes that pass through the center of mass of the plane and are used to describe the rotational motion of the plane.
2. How many principal axes can a plane have?
A plane can have a maximum of three principal axes since it is a two-dimensional object and cannot rotate around more than three axes.
3. What is the significance of having more than 2 principal axes?
If a plane has more than 2 principal axes, it means that it is not symmetric and can rotate around all three axes, making its motion more complex and difficult to predict.
4. How does the number of principal axes affect the stability of a plane?
The number of principal axes does not directly affect the stability of a plane. However, if a plane has more than 2 principal axes, it may be more difficult to control and maintain its stability during flight.
5. Can a plane with more than 2 principal axes exist in the real world?
Yes, there are several types of planes in the real world that have more than 2 principal axes, such as helicopters and tiltrotor aircraft. These types of aircraft have complex mechanisms that allow them to rotate around multiple axes for better maneuverability.
