If dx/dt=kx, and if x=2 when t=0 and x=6 when t=1, then k=
  • MHB
  • Thread starter karush
In summary, the equation dx/dt=kx represents a differential equation where x is a function of t and k is a constant. It relates the rate of change of x over time, with k determining the proportionality constant. To solve for k, we use the given initial conditions and algebra. This equation can be used to model real-life situations in various fields. Changing the value of k will affect the rate of change of x over time, with a larger value resulting in a faster rate of growth or decay and a smaller value resulting in a slower rate of change.
karush
MHB
3,269
If $\frac{dx}{dt}=kx$, and if $x=2$ when $t=0$ and $x=6$ when $t=1$,
then $k=$
or rewriten as
$\frac{dx}{kx} = dt$
I saw this posted on another forum but didn't understand how this was integrated.. the ans appears to \(\displaystyle ln 3\)
We have the separable ODE:
\(\displaystyle \frac{dx}{dt}=kx\)
\(\displaystyle \frac{1}{x}\,dx=k\,dt\)
\(\displaystyle \ln|x|=kt+C\)
Now, we know the point:
\(\displaystyle (t,x)=(0,2)\)
Hence:
\(\displaystyle C=\ln(2)\)
Thus:
\(\displaystyle \ln|x|=kt+\ln(2)\)
We also know the point:
\(\displaystyle (t,x)=(1,6)\)
Hence:
\(\displaystyle k=\ln(6)-\ln(2)=\ln(3)\)
FAQ: If dx/dt=kx, and if x=2 when t=0 and x=6 when t=1, then k=
What does the equation dx/dt=kx represent?
The equation dx/dt=kx represents a differential equation, where x is a function of t and k is a constant. It describes the rate of change of x over time, with k determining the proportionality constant.
What is the relationship between x and t in this equation?
In this equation, x and t are related through the derivative of x with respect to t. This means that the value of x at any given time t is determined by its initial value and the rate of change, k.
How do we solve for k in this equation?
To solve for k, we need to use the given initial conditions. In this case, we have x=2 when t=0 and x=6 when t=1. We can plug these values into the equation and use algebra to solve for k. In this example, k=4.
Can this equation be used to model real-life situations?
Yes, this type of equation is commonly used in physics and chemistry to model systems that exhibit exponential growth or decay. It can also be used in economics, biology, and other fields to describe various phenomena.
How does changing the value of k affect the solution to this equation?
Changing the value of k will affect the rate of change of x over time. A larger value of k will result in a faster rate of growth or decay, while a smaller value of k will result in a slower rate of change. This can be seen by comparing the solutions to the equation with different values of k.
