If f(3x) = f(3) + f(x) , then prove that : f(1) = f(3) =f(9) = f(27) = f(81) = 0
  • MHB
  • Thread starter Riwaj
In summary, MarkFL said that if f(3x) = f(3) + f(x) and x\in R , then f(1) = f(3) =f(9) = f(27) = f(81) = 0 .
Riwaj
Q.1) If f(3x) = f(3) + f(x) and x\in R , then prove that : f(1) = f(3) =f(9) = f(27) = f(81) = 0 .
Q.2) If g(x) = x2 -4x + 3 and g(x+1) = g(x-1) , then find the value of x .
Mathematics news on Phys.org
(Sweating) its very urgent
Okay, we are told:
\(\displaystyle f(3x)=f(3)+f(x)\)
Suppose we let $x=3^a$, where $a\in\mathbb{N_0}$...we then get:
\(\displaystyle f\left(3^{a+1}\right)=f(3)+f\left(3^a\right)=f(3)+\left(f(3)+f\left(3^{a-1}\right)\right)=?\)
isn't there any simper way .
Did you understand what MarkFL was telling you? Since f(3x)= f(3)+ f(x), taking x= 1, f(3)= f(3(1))= f(3)+ f(1) so f(1)= ?
f(9)= f(3(3))= f(3)+ f(3)= 2f(3).
f(27)= f(3(9))= f(3)+ f(9)= f(3)+ 2f(3)= 3f(3).
f(81)= f(3(27))= f(3)+ f(27)= f(3)+ 3f(3)= 81f(3).
g(x+ 1)= (x+ 1)2- 4(x+ 1)+ 3.
g(x- 1)= (x- 1)2- 4(x- 1)+ 3
Multiply those out and set them equal. You have a linear equation to solve for x.
MarkFL said:
Okay, we are told:
If carry this out, we find that:
\(\displaystyle f\left(3^a\right)=a\cdot f(3)\)
This, along with the given equation should suggest that $f$ could be a logarithmic function. Can you find a logarithmic function that satisfies the given equation, but for which
\(\displaystyle f(1)=f(3)=f(9)=f(27)=f(81)=0\)
is not true?
Another approach to this problem, as we saw in a previously posted problem of yours, is to use the axis of symmetry. Since:
\(\displaystyle g(x+1)=g(x-1)\) then the axis of symmetry $x_S$ has to be:
\(\displaystyle x_S=\frac{(x+1)+(x-1)}{2}=x\)
In fact, we must have:
\(\displaystyle g(x+k)=g(x-k)\) where $k\in\mathbb{R}$
But, we also know:
\(\displaystyle x_S=-\frac{b}{2a}\)
For the general quadratic $ax^2+bx+c$...so equate the two expressions for the axis of symmetry and solve for $x$. What do you get?
FAQ: If f(3x) = f(3) + f(x) , then prove that : f(1) = f(3) =f(9) = f(27) = f(81) = 0
What is the given equation and what does it mean?
The given equation is f(3x) = f(3) + f(x), which means that the function f has the property of being linear with respect to multiplication by 3. This means that if we multiply the input value of f by 3, the output value of f will also be multiplied by 3.
How does this equation prove that f(1) = f(3) = f(9) = f(27) = f(81) = 0?
By substituting x = 1 into the given equation, we get f(3) = f(3) + f(1). This means that f(1) = 0 since f(3) = f(3) + 0. By repeatedly substituting x = 3 into the equation, we can show that f(3) = f(3) + 0 = f(3) + f(3) = 2f(3) = 0. This same logic applies for x = 9, x = 27, and x = 81, thus showing that f(1) = f(3) = f(9) = f(27) = f(81) = 0.
Can you explain the concept of linearity in functions further?
Linearity in functions means that the function has the property of preserving the operations of addition and multiplication. In other words, if we add or multiply the input values of the function, the output values will also be added or multiplied accordingly. This is represented mathematically as f(x + y) = f(x) + f(y) and f(kx) = kf(x), where k is a constant.
Is this equation valid for all values of x or only specific values?
This equation is valid for all values of x. This is because the equation defines a property of the function f that holds true for all input values. This means that no matter what value we substitute for x, the equation will still hold true.
Can this equation be used to solve other problems in mathematics?
Yes, this equation can be used to solve other problems in mathematics, particularly in linear algebra and differential equations. In linear algebra, this equation is known as the homogeneous property and has applications in solving systems of linear equations. In differential equations, this equation is known as the superposition principle and is used to find solutions to linear differential equations.
