If F is algebraically closed, show Alg ext is closed too
  • Thread starter Mr Davis 97
  • Tags
    Closed
In summary, an algebraic extension E of a field F is algebraically closed if every polynomial in F[x] can be factored into linear polynomials. This definition is important to consider when determining if a field is algebraically closed.
Mr Davis 97
1,462
44
Let E be an algebraic extension of F in which every polynomial in F[x]
can be factored into linear polynomials. Then E is algebraically closed.
This seems like a very easy problem, but I'm not sure how to write things down formally.
Start with the definition that you use: What is an algebraic closed field? What is an algebraic extension? How do they relate to F?
That's why we have "
" above. It's meant to tell us which definitions and notations you are used to. "This seems like a very easy problem" because it could well be the definition. Thus the question about your definition is the crucial part.
Likes Mr Davis 97
FAQ: If F is algebraically closed, show Alg ext is closed too
What does it mean for a field to be algebraically closed?
A field F is algebraically closed if every non-constant polynomial with coefficients in F has at least one root in F.
What is Alg ext?
Alg ext is the set of all algebraic extensions of a given field F. In other words, it is the collection of all fields that can be obtained by adjoining algebraic elements to F.
Why is it important to show that Alg ext is closed if F is algebraically closed?
Showing that Alg ext is closed when F is algebraically closed is important because it allows us to extend the properties of F to all of its algebraic extensions. This allows us to apply theorems and techniques from F to a larger class of fields, making our analysis more versatile and comprehensive.
How can we prove that Alg ext is closed if F is algebraically closed?
We can prove that Alg ext is closed when F is algebraically closed by using the fundamental theorem of Galois theory. This theorem states that every algebraic extension of a field can be expressed as a splitting field of a separable polynomial over that field. Since F is algebraically closed, all polynomials over F are separable, and thus all algebraic extensions of F are splitting fields. Therefore, Alg ext is closed.
What are some examples of algebraically closed fields?
Some examples of algebraically closed fields include the complex numbers, the algebraic closure of the rational numbers, and the algebraic closure of finite fields. In general, any field can be made algebraically closed by adjoining all of its algebraic elements.
