If f : R −→ R is continuous and f (7) > 2, then ∃δ > 0 such that
  • Thread starter Askhwhelp
  • Tags
    Continuous
In summary: The proof is valid for any strictly positive number ε. The number 7 is a local maximum because it is the point at which the graph crosses the y-axis twice.
Askhwhelp
86
If f : R −→ R is continuous and f (7) > 2, then ∃δ > 0 such that ...
If f : R −→ R is continuous and f (7) > 2, then ∃δ > 0 such that f (x) > 2 ∀x ∈ Vδ (7).
I know the definition of continuous at a point. However, the question does not specific any particular point. Will it still work?
Could anyone help get me started?
What I got so far
For all epsilon > 0 there exist δ > 0 such that whenever x in R and |x-7|< δ, it follow that |f(x) - f(7)| < |f(x) - 2|< sth that I am not sure
Am I going the right direction?
Will it still work?
What I got so far
You're not told that [itex]f(7) = 2[/itex], you're told that [itex]f(7) > 2[/itex].
The definition of continuity says that something is true for all strictly positive numbers, so you may want to see what follows if you take a particular strictly positive number.
First, you need to understand why this is true. Then you turn that understanding into the e-d formal proof.
So, f(7) > 2. If f is continuous, then it must be > 2 for a (perhaps small) distance either side of 2. Note that:
f may be > 2 for all x.
f may only be greater than 2 close to 7 (x = 7 may be a local maximum of 2.1, say).
But, one thing f can't do is jump down to less than 2 arbitrily close to 7.
If you draw a graph of f, it must remain > 2 for a finite distance round 7.
You can use e-d proofs as follows:
[itex]Let \ \epsilon = f(7) - 2[/itex]
[itex]Then \ \exists \ \delta > 0 \ s.t. |x-7| < \delta \Rightarrow \ |f(x) - f(7)| < \epsilon[/itex]
[itex]\Rightarrow f(x) > f(7) - \epsilon \ = \ 2[/itex]
Note that (in case you're wondering):
[itex]|f(x) - f(7)| < \epsilon \ \Rightarrow \ f(x) \in (f(7)-\epsilon, f(7)+\epsilon)[/itex]
[itex]\Rightarrow \ f(7)-\epsilon < f(x) < f(7)+\epsilon[/itex]
And we only needed the first inequality in this case.
The trick in my view with these problems is not to think about e-d until you've understood the geometry of the situation.
Thanks
Try to clarify
Good
FAQ: If f : R −→ R is continuous and f (7) > 2, then ∃δ > 0 such that
What does the notation "f : R −→ R" mean in this statement?
The notation "f : R −→ R" means that the function f maps from the real numbers (R) to the real numbers (R).
2. What does it mean for a function to be continuous?
A function is continuous if it has no breaks or gaps in its graph and if the limit of the function at any point is equal to the value of the function at that point.
3. Why is the statement "f (7) > 2" important in this context?
This statement is important because it provides a specific value for the function at a particular point. It also allows us to determine if there is a point close to 7 where the function is still greater than 2.
4. What is the significance of the symbol "∃" in this statement?
The symbol "∃" means "there exists," so the statement is saying that there exists a value of δ (the Greek letter delta) such that the conditions in the statement are satisfied.
5. How does this statement relate to the concept of continuity?
This statement is a direct application of the definition of continuity. It states that if a function is continuous and has a particular value at a point, then there is a small interval around that point where the function will still have a value greater than 2. In other words, the function does not have any sudden jumps or breaks at that point.
