If g o f = idA and f o g = idB, then g = f^-1 proof?
  • Thread starter Norm850
  • Tags
    Proof
In summary, the conversation discusses the proof that if two sets A and B have functions f and g with f: A -> B and g: B -> A, and g o f = idA and f o g = idB, then f is invertible and g = f^-1. The conversation also includes a hint for proving this, and a question about the necessity for f to be 1-1 and onto. It is determined that the proof is sufficient for g = f^-1, but it must first be shown that f^-1 exists.
Norm850
Hey guys,
I need to prove: Suppose A and B are sets, and f and g are functions with f: A -> B and g: B -> A. If g o f = idA and f o g = idB, then f is invertible and g = f^-1.
So far I have understood why g must be the inverse of f, but I do not know how to prove it.
Thanks!
Take an arbitrary element a in A and b in B and show that they relate via composition of both functions.
Hint: f(a) = b, g(b) = a
Okay, not really sure how to do that but here's my attempt:
Suppose g o f = idA,
then dom(g o f) = dom(idA) = A
and (g o f)(a) = g(f(a)) = idA(a) = a.
Suppose f o g = idB,
then dom(f o g) = dom(idB) = B
and (f o g)(b) = f(g(b)) = idB(b) = b.
A function is only invertible if it's 1 - 1 and onto. Is this the case? You didn't specify.
So what I have is sufficient for g=f^-1? But first I need to show that f^-1 exists?
FAQ: If g o f = idA and f o g = idB, then g = f^-1 proof?
What does "g o f = idA" mean?
The notation "g o f" represents the composition of two functions, g and f, where the output of f becomes the input for g. The "idA" signifies the identity function, which returns the same value as its input. Therefore, "g o f = idA" means that the composition of g and f results in the identity function for the domain A.
How is this related to the inverse of a function?
The inverse of a function undoes the original function's operation. In this context, "f o g = idB" implies that the composition of f and g results in the identity function for the domain B. Since the composite functions result in identity functions for different domains, it can be concluded that g is the inverse of f and vice versa.
What does the notation "g = f^-1" mean?
The notation "g = f^-1" represents the inverse function of f, which undoes f's operation. This is equivalent to swapping the input and output of the original function f.
How can we prove that g is the inverse of f?
To prove that g is the inverse of f, we can use the fact that "g o f = idA" and "f o g = idB". These conditions satisfy the definition of inverse functions, where the composition of a function with its inverse results in the identity function.
Can this proof be applied to all functions?
Yes, this proof can be applied to all functions as long as the composition of g and f results in the identity function for the respective domains. However, it is important to note that not all functions have inverses, as some may not have a one-to-one correspondence between their input and output values.
