acesuv
- 63
davenn said:they don't have to, they just float upwards.
its only the lightest gasses that are lost to space, eg, Hydrogen and Helium
Pythagorean said:Escape velocity is dependent on mass. Gas molecules have very little mass so they require very little escape velocity.
Though, there's probably other factors for gas molecules because of their small inertia. A small inertia means even the smallest forces will push you around.
Just change the colour.BruceW said:how do you do the red highlighting? that would be really useful.
No!Pythagorean said:Escape velocity is dependent on mass. Gas molecules have very little mass so they require very little escape velocity.
It looks that it was answered already, change the color.BruceW said:how do you do the red highlighting?
To find out how someone does something on a message boat, press quote on his post, and you see his tags.BruceW said:how do you do the ...
acesuv said:so there's gas in orbit around earth?
Devils said:Its called the atmosphere.
If gasses escapes Earth, then how do they reach escape velocity?
Escape velocity is calculated using the formula ve = √(2GM/r), where G is the gravitational constant, M is the mass of the planet, and r is the distance from the center of the planet to the object.
Yes, gas molecules can reach escape velocity if they have enough energy and are able to overcome the gravitational pull of the planet. This is often seen in the form of atmospheric escape, where lighter gases such as hydrogen and helium are able to escape from the Earth's atmosphere into space.
The main factors that affect the escape velocity of a planet are its mass and radius. Planets with a larger mass and smaller radius will have a higher escape velocity, making it more difficult for objects to escape its gravitational pull.
The Earth's atmosphere is composed of different layers with varying densities. As gas molecules move upwards, they collide with other molecules and lose energy, making it difficult for them to reach escape velocity. Additionally, the Earth's gravity is constantly pulling on these molecules, making it hard for them to escape into space.
Gas molecules that reach escape velocity will continue to travel at a high speed and may eventually escape the planet's gravitational pull and enter space. However, they can also be pulled back by the planet's gravity or be affected by other forces such as solar wind and magnetic fields.
