If H is a subgroup, then H is subgroup of normalizer
  • Thread starter Mr Davis 97
  • Tags
    Subgroup
In practice it is easier to use the subgroup criterion and verify that ##g^{-1}ng \in N## for all ##n \in N, g \in G##.
Mr Davis 97
1,462
44
Show that if ##H## is a subgroup of ##G##, then ##H \le N_G (H)##
Essentially, we need to show that ##H \subseteq N_G (H)##; since they are both groups under the same binary operation the fact that they are subgroups will result. So let ##h \in H##. We want to show that ##h \in N_G (H)##, i.e. we want to show that ##hHh^{-1} = H##. But since the map ##\sigma_h (x) = hxh^{-1}## is automorphism an and thus a permutation from ##H## to ##H##, the set ##hHh^{-1}## is just a permuted version of ##H##, and so by set theory ##hHh^{-1} = H##, and ##h \in N_G (H)##.
Isn't the point to show that ##H \trianglelefteq N_G(H)## or even better, that ##N_G(H)## is the largest subgroup with this property? For ##H \leq N_G(H)## you only need to write ##hHh^{-1} \subseteq H## which is trivial for (sub-)groups, no conjugation or automorphism needed, just the group operation.
Likes Mr Davis 97
I'm just reading the problem word for word. I haven't learned about normal subgroups yet, so maybe that's why is seems trivial. But, one question. Why does ##hHh^{-1} \subseteq H## imply that ##H \le N_G (H)##?
##N_G(H)=\{\,g\in G\,:\,gHg^{-1}\subseteq H\,\}## per definition and this implies automatically that it contains ##H## because ##H## is a group.
A normal subgroup ##N## is one which has the property that ##gNg^{-1} \subseteq N## for all ##g\in G\,.## The clue is that normal subgroups are exactly those for which there can be defined a group structure on the set of equivalence classes ##\{\,[g]\,:\,[g]=gN\; , \;g \in G\,\}##. With an ordinary subgroup this cannot be done, with a normal subgroup it can (well definition is what fails with ordinary subgroups). The definition of ##N_G(H)## also shows that ##H## is normal in ##N_G(H)## - per construction, and this is why it is called normaizer of ##H## in ##G##. It's also the largest such subgroup for otherwise an element ##gNg^{-1}## would already be in ##N_G(H)##.
Likes Mr Davis 97
Ah I see. Also, one thing, Dummit and Foote defines ##N_G (A) = \{ g \in G ~|~ gAg^{-1} = A \}##. Not sure why it is equality and not subset.
This doesn't make a difference: ##gNg^{-1} \subseteq N \Longrightarrow N \subseteq g^{-1}Ng \subseteq N## as the relation is true for ##g## as well as ##g^{-1}##.
Likes Mr Davis 97
Related to If H is a subgroup, then H is subgroup of normalizer
1. What is a subgroup?
A subgroup is a subset of a group that retains all the properties of the original group. It is also a group in its own right, with its own identity element, inverse elements, and operation.
2. What is the normalizer of a subgroup?
The normalizer of a subgroup is the largest subgroup of a group that contains the given subgroup as a normal subgroup. It is denoted as N(H) and consists of all elements in the group that commute with every element in the subgroup H.
3. How do you prove that H is a subgroup of the normalizer of H?
To prove that H is a subgroup of the normalizer of H, we need to show that it satisfies the three criteria for being a subgroup: closure, associativity, and inverse elements. Additionally, we need to prove that H is a normal subgroup of the normalizer, meaning that it is invariant under conjugation by elements in the normalizer.
4. What is the significance of H being a subgroup of the normalizer of H?
If H is a subgroup of the normalizer of H, it means that every element in H commutes with every element in the normalizer, and therefore with every element in the group. This can be useful in proving properties of the group and its subgroups, and can also help in constructing new subgroups.
5. Can a subgroup be a normalizer of itself?
Yes, a subgroup can be a normalizer of itself. This happens when the subgroup is already a normal subgroup of the group. In this case, the normalizer of the subgroup is the entire group, since all elements commute with the subgroup.
