If $k$ is large, the expression above is approximately $\frac{1}{3}$.
  • MHB
  • Thread starter Ackbach
In summary, when an expression is approximately $\frac{1}{3}$ when $k$ is large, it means that as the value of $k$ increases, the expression gets closer to $\frac{1}{3}$. This can be proven using mathematical analysis and the concept of limits. However, we cannot say for certain that the expression will always equal $\frac{1}{3}$ when $k$ is large, as it depends on the specific expression and its coefficients. The value of $k$ directly affects the approximation, with larger values of $k$ resulting in a closer approximation to $\frac{1}{3}$. This approximation can be used in calculations, but may not always be accurate for smaller values of $k
Ackbach
MHB
4,155
93
Here is this week's POTW:
Let $k$ be a positive integer. Suppose that the integers $1, 2, 3,\dots, 3k+1$ are written down in random order. What is the probability that at no time during this process, the sum of the integers that have been written up to that time is a positive integer divisible by $3?$ Your answer should be in closed form, but may include factorials.
Remember to read the http://www.mathhelpboards.com/showthread.php?772-Problem-of-the-Week-%28POTW%29-Procedure-and-Guidelines to find out how to http://www.mathhelpboards.com/forms.php?do=form&fid=2!
Congratulations to castor28 for his correct solution to this week's POTW, which was Problem A-3 in the 2007 Putnam Archive. His solution follows:
[sp]
We consider the sequence modulo 3, and look at the conditions required to have a good sequence. We may ignore the positions of the 0's, which contribute nothing to the running total (except for the fact that the first number must not be one of them).
The other numbers constitute a sequence of 1's and 2's, of length $2k+1$, in which each number after the first is uniquely determined by the numbers before it. This gives two possible sequences: $11212121\ldots$ and $22121212\ldots$. Because we have $k+1$ numbers in class 1 and $k$ numbers in class 2, only the first sequence is allowed.
The number of sequences of $(k+1)$ 1's and $(k)$ 2's is the number of ways to choose the $k$ 2's in a set of $2k+1$ numbers, i.e., $\binom{2k+1}{k}$. If we factor in the fact that the first number must not be a multiple of 3 ($2k+1$ choices out of $3k+1$), we get the probability:
$$ \frac{2k+1}{3k+1}\times\frac{1}{\binom{2k+1}{k}}=\frac{k!\,(k+1)!}{(2k)!\,(3k+1)}$$
[/sp]
FAQ: If $k$ is large, the expression above is approximately $\frac{1}{3}$.
What does it mean when an expression is approximately $\frac{1}{3}$ when $k$ is large?
When an expression is approximately $\frac{1}{3}$ when $k$ is large, it means that as the value of $k$ gets larger and larger, the expression will get closer and closer to the value of $\frac{1}{3}$. This is known as the limit of the expression as $k$ approaches infinity.
How do we know that the expression is approximately $\frac{1}{3}$ when $k$ is large?
This approximation is based on mathematical analysis and the concept of limits. By evaluating the expression at extremely large values of $k$, we can see that the resulting value approaches $\frac{1}{3}$. This can also be proven using calculus and the concept of infinite series.
Can we say for certain that the expression will always equal $\frac{1}{3}$ when $k$ is large?
No, we cannot say for certain that the expression will always equal $\frac{1}{3}$ when $k$ is large. This is because the concept of "large" is relative and depends on the specific expression and its coefficients. However, in most cases, the expression will approach $\frac{1}{3}$ as $k$ gets larger.
How does the value of $k$ affect the approximation of the expression to $\frac{1}{3}$?
The value of $k$ directly affects the approximation of the expression to $\frac{1}{3}$. As the value of $k$ increases, the expression will get closer to $\frac{1}{3}$. Conversely, if the value of $k$ decreases, the expression will move further away from $\frac{1}{3}$.
Can we use this approximation to simplify the expression in calculations?
Yes, we can use this approximation to simplify the expression in calculations. If the value of $k$ is extremely large, the expression can be simplified to $\frac{1}{3}$ for practical purposes. However, it is important to note that this is only an approximation and may not always be accurate for smaller values of $k$.
