MHB If matrix lambda is diagonal with entries 0,1 then lambda squared is lambda
  • Thread starter Thread starter Jameson
    Lambda Matrix
Jameson
Insights Author
MHB
This is part of a proof I am working on involving idempotent matrices. I believe it is true that for any real symmetric matrix A ($n \times n$ for this), even with repeat eigenvalues, it can be decomposed into the form $A=Q \Lambda Q^{T}$. For the matrix I'm working on, we assume that all eigenvalues of A are 0 or 1.
What I need to show now is that $\Lambda^2=\Lambda$ (which in turn helps me show that $A^2=A$, thus is idempotent). It makes sense intuitively since when doing the row-column multiplications, the only time you would get a non-zero answer is when you have two non-zero elements being multiplied together in the sum, which only occurs when $i=j$. I'm trying to formulate a more rigorous argument for this though.
Just to make sure I'm clear, $\Lambda$ is an $n \times n$ matrix with all non-diagonal entries equal to 0, and diagonal entries equal to 0 or 1.
I know that $ \displaystyle \Lambda^2_{ij} = \sum_{k=1}^{n} \Lambda_{ik}\Lambda_{kj}$
Can I start here to make my argument you think?
I'd use the dot product definition of matrix multiplication for this one. First get the $i \ne j$ case out of the way by showing that if $i \ne j$ then the $i$th row and $j$th column are either zero or orthogonal (since $\Lambda$ is diagonal so they can't have nonzero entries in the same dimension) so their dot product is zero. For $i = j$, use the fact that $\Lambda$ is diagonal and contains only entries 0, 1 to argue that the $i$th row and the $j$th column are equal, so their dot product is either 0 if they are zero (if the diagonal entry contains zero) or 1 otherwise (if the diagonal entry contains a 1, i.e. the two vectors are of unit length).
Thanks, Bacterius. That was the logic I was thinking of but I didn't state it fully as you did. I think I can use your argument to sufficiently show what I need to. :)
Thread 'Derivation of equations of stress tensor transformation'
Hello ! I derived equations of stress tensor 2D transformation. Some details: I have plane ABCD in two cases (see top on the pic) and I know tensor components for case 1 only. Only plane ABCD rotate in two cases (top of the picture) but not coordinate system. Coordinate system rotates only on the bottom of picture. I want to obtain expression that connects tensor for case 1 and tensor for case 2. My attempt: Are these equations correct? Is there more easier expression for stress tensor...
