kyphysics
- 676
- 437
My water heater has an issue. I still get cold water, but is that safe to drink if the water heater is not working? Thanks!
Your cold water supply comes directly from the water main. For hot water, a branch pipe comes off the cold water supply and delivers water to the hot water heater tank, where it is heated and then delivered to the hot water taps via a separate system of pipes. So the only connection between the hot water lines and cold water lines happens before the water gets to the hot water heater.kyphysics said:Essentially, yes. I think that's what I'm asking.
Basically, would anything bad happen if I showered with , brushed my teeth with, or used for food prep the water out of the faucet if the water heater is not working and we cannot get hot water.
Can we still use the water that does come out, in other words (even if it's only cold)?
It is generally not advised to drink water from a water heater, hot or cold (but as @Dullard says, the risk is higher when it is hot). Three reasons:kyphysics said:My water heater has an issue. I still get cold water, but is that safe to drink if the water heater is not working?
In our house the upstairs bathroom sinks were "upgraded" so that the hot water line is connected through a small electrically powered pump to the cold water line. The pump will periodically run to move a volume of water from the hot water line to the cold water line. This has the effect of moving some hot water out of the hot water tank and into the hot water line and some water from the cold water line into the hot water tank.Janus said:Your cold water supply comes directly from the water main. For hot water, a branch pipe comes off the cold water supply and delivers water to the hot water heater tank, where it is heated and then delivered to the hot water taps via a separate system of pipes. So the only connection between the hot water lines and cold water lines happens before the water gets to the hot water heater.
Heh - I've considered doing this retrofit for mine. If I do it, the pump will be on a timer which will turn it on for a few minutes, once a day, at 6:00 am. It would serve the shower only.jbriggs444 said:In our house the upstairs bathroom sinks were "upgraded" so that the hot water line is connected through a small electrically powered pump to the cold water line...
If I had it to do over again, there is no way I would agree to have such an arrangement. Even now, it is tempting to simply unplug the pump.
Sounds a bit like the hot water loop you have in large buildings. The hot water is continuously circulated through it so that hot water is quickly available at any tap no matter how far the tap is from the main hot water tank.jbriggs444 said:In our house the upstairs bathroom sinks were "upgraded" so that the hot water line is connected through a small electrically powered pump to the cold water line. The pump will periodically run to move a volume of water from the hot water line to the cold water line. This has the effect of moving some hot water out of the hot water tank and into the hot water line and some water from the cold water line into the hot water tank.
Everything is at the same pressure, of course, so the pump does not need to work very hard circulating water through the loop.
The intended effect of this arrangement is that when one turns on the hot water tap in the sink or shower, the water is hot almost immediately -- the hot water pipes being kept full of hot or at least warm water from the tank.
One unfortunate side effect is that cold water drawn from the tap is not cold. Another unfortunate side effect is that the insulation on the hot water tank does nothing to prevent heat being lost from the hot water which is always in the hot water pipes.
Yep, just done on the cheap using existing pipes.Janus said:Sounds a bit like the hot water loop you have in large buildings. The hot water is continuously circulated through it so that hot water is quickly available at any tap no matter how far the tap is from the main hot water tank.
And for that. . . I'd like to thank you. . ✔crashcat said:I just want to comment on how bizarre this thread is.
I'm not seeing in the OP where the cold water tap is specified.crashcat said:I just want to comment on how bizarre this thread is. A simple question with a one line answer: Yes, your cold water tap, if you normally drink out of it, is still safe to drink.
russ_watters said:It is generally not advised to drink water from a water heater, hot or cold (but as @Dullard says, the risk is higher when it is hot). Three reasons:
- Hot water from the tap is generally at a good temperature for promoting bacteria growth: it is warm, but not hot enough to kill bacteria (it is actually legally required not to be for scalding safety reasons).
- Hot water leaches/dissolves contaminants into it better than cold water does.
- Hot water lingers in tank longer than in pipes, which, again, enables leeching and bacteria growth.
In a modern and well-maintained system these risks are probably low, but they are worth noting.
https://denverwatertap.org/2017/12/13/psa-dont-drink-cook-hot-water-tap/
https://homeexplained.com/is-it-bad-to-drink-hot-water-from-the-tap/
Thanks for the very detailed, response, BoB. No issues with safety before water heater broke. It's fixed now!rbelli1 said:The water coming into your home should be safe as is. You should be able to contact your water company and get their test reports. This information may also be on the internet. Independent testing labs will also test the water for you.
Boiling water will kill bacteria and viruses but will do little for chemical contaminants from the source or leached from plumbing at any point from the plant to your faucet. Some volatiles may boil out.
Filter type purifiers will remove various materials from the water. All of them improve the flavor but no general statement can say what else is removed. They may or may not make it safer. They will generally not claim to remove pathogens.
Distillation will give the purest water.
Was there a concern about your water safety before the heater broke? The safety after should be the same as before except for the elimination of issues around the hot water system.
BoB
There are a few possible reasons for a water heater to stop working, including a malfunctioning heating element, a faulty thermostat, or a power supply issue. It's best to have a professional inspect and diagnose the problem.
Yes, you can still use the cold water from your tap for drinking and cooking. The cold water comes directly from the main water supply and is not affected by the water heater.
No, it is not safe to use hot water from the tap if the water heater is not working. The hot water may contain bacteria or other contaminants that are normally killed by the hot water heater. It's best to wait until the water heater is fixed before using hot water for drinking or cooking.
If you suspect your water may be contaminated, you can have it tested by a professional. You can also look for signs of discoloration, unusual odor, or a metallic taste, which may indicate contamination. It's important to address any potential water quality issues as soon as possible.
The length of time you can go without a functioning water heater before it becomes a health concern depends on various factors, such as the quality of your water supply and your personal health. It's best to have the issue addressed as soon as possible to avoid any potential health risks.
