If ## n>1 ##, show that ## n ## is never a perfect square
  • Thread starter Thread starter Math100
    Square
For any integer n greater than 1, n! is never a perfect square. The proof is approached by considering the largest prime factor of n!, denoted as p, which must divide n!. If n! were a perfect square, then p would have to appear with an even exponent in its prime factorization. However, applying Bertrand's conjecture, it can be shown that there exists a prime p such that n < p < 2n, leading to a contradiction since p cannot appear twice in the factorization of n!. Thus, it is concluded that n! cannot be a perfect square for n > 1.
  • #31
SammyS said:
Define some number, I've called it ##k## such that ##k## is the quotient defined by Euclidean division for ##n/2## .
In the example, ##n!=83521!##, we have that ##k=41760## , so that ##2k=83520##. So, if there is a prime number, ##p_B~,## such that ##41760<p_B<83520## , then what can be stated about ##2p_B##?
We technically have that ##p_B\ge41761## , so that ##2p_B\ge83522>83521=n##.
Doesn't that mean ## 2p_B\geq n ##?
  • #32
##p_B## certainly divides ##n!##
Consider the following list:
1\quad 2 \quad 3\quad \ldots\quad n/2\quad \ldots \quad p_B\quad \ldots \quad n
Now, every prime divisor of ##n!## must divide one of these numbers. Hence particularly ##p_B## has to divide one of these numbers one more time, if ##p_B^2\,|\,n!##
Can this happen? If yes, why? If not, why?
Likes SammyS
  • #33
No.
  • #34
Suppose for the sake of contradiction that ## n! ## is a perfect square.
Let ## p ## denote the largest prime such that ## p<n ##.
Then ## p\mid n! ##.
Since ## n! ## is a perfect square,
it follows that ## p^2\mid n!\implies p\mid (\frac{n!}{p}) ##.
Note that ## \frac{n!}{p}=1\cdot 2\cdot 3\dotsb (p-1)(p+1)\dotsb n ##
where ## \frac{n!}{p} ## must have ## 2p ## as its factor.
Thus ## p<2p<n ##, which is a contradiction because the Bertrand's conjecture
states that there exists at least one prime ## p ## satisfying ## n<p<2n ##.
Therefore, if ## n>1 ##, then ## n! ## is never a perfect square.
  • #35
The Prime, ##p##, guaranteed by Bertrand (below) has nothing to do with the choice of ##p## above.
For prime, ##p##, what is the smallest composite number divisible by ##p~?##
  • #36
fresh_42 said:
No. ##83521=17^4.## The largest and only prime factor is ##17## and ##n \not\lt 2\cdot 17.## So your proof does not work in this case. I do not see why ##83521!## shouldn't be a square.
17 is the largest prime factor in ##17^4##, not in ##(17^4)!##.
  • #37
So what?
My reply was to
Math100 said:
Let ## p ## denote the largest prime such that ## p\leq n ##.
Thus ## n<2p ##, so ## p\mid n! ## but ## p^2\nmid n! ##, which is a contradiction.
  • #38
fresh_42 said:
So what?
My reply was to
So what? Having ##n = q^4## where ##q## is a prime smaller than ##p## affects nothing. ##n## is ##17^4##, not 17.
  • #39
Yes. But that wasn't my message. I responded to: why the OP's proof doesn't work.
I have nowhere claimed that ##17## is the largest prime divisor of ##17^4!## However, it is the largest prime divisor of ##17^4=17 \cdot 17 \cdot 17\cdot 17.##
I only explained why the proof does not work. So, please either quote the complete quotation or read the thread.
fresh_42 said:
Math100 said:
Because there exists a prime ## p ## in the prime factorization of the integer 83521 only once, thus ## p^2\nmid 83521! ##.
  • #40
This is your quote:
fresh_42 said:
Why? What if n=p4 for example?
This never happens because ##p## was assumed to be the largest prime smaller than ##n##. If ##n = p^4## for some prime ##p##, then ##p## is not the largest prime factor in ##n!##, which was the assumption:
Math100 said:
Let p denote the largest prime such that p≤n.
If ##n = q^4## for some prime ##q##, then there exists a prime ##p## which is larger than ##q## but smaller than ##n## by Bertrand'd conjecture because ##n \geq 8 q > 2q##. Therefore, ##n## cannot be equal to ##p^4## where ##p## is the largest prime less than or equal to ##n##. Talking about ##n = p^4## is therefore going to be quite confusing to OP.
The real issue in the proof of the OP is this:
Math100 said:
Thus n<2p,
This should be something akin to "Since ##p## is the largest prime smaller than ##n##, ##n < 2p## by Bertrand's postulate." Later, this is also an issue:
I don't know if this is just sloppiness from the OP or not. It should read "because there exists a prime p in the prime factorization of the integer 83521! only once".
A more compact version of the proof being attempted would read:
Let ##p## be the largest prime such that ##p \leq n##.
##p## exists in the prime factorization of ##n!## exactly once unless ##n \geq 2p##.
If ##n \geq 2p##, then by Bertrand's postulate there exists a prime ##q## such that ##p < q < 2p \leq n##, which contradicts ##p## being the largest prime ##p \leq n##.
Thus, ##n < 2p## and ##p## occurs only once in the prime factorization of ##n!##.
As explained above, your example of ##n = 17^4## with ##p = 17## is not applicable because 17 is not the largest prime ##p## such that ##p \leq 17^4##.
  • #41
I do not see why we should debate this nonsense. Read the posts.
Therefore, if ## n>1 ##, show that ## n! ## is never a perfect square.
  • #42
It is quite clear that you yourself has not read my post considering your post is submitted 6 minutes after mine, which is rather lengthy. At most you have glanced over it.
To summarize:
Your example of ##n = p^4## is not applicable and will just confuse the OP because ##p## was assumed to be the largest prime such that ##p \leq n##.
So unless you want to argue that you can find an ##n = p^4## for which ##p## is the largest prime such that ##p \leq n##, it is highly relevant.
  • #43
I see that you deliberately a) ignore what I said, b) ignore why I said it (not to you btw), c) did not read the thread, and d) willingly misunderstand my example which was only meant as an answer to post #13.
Nowhere did I say that ##17## is the largest prime in ##17^4!##
The opposite is true, I said it is ##83497.##
I (still) claim that ##17## is the largest prime in ##17^4.##
My example explains why a certain argument by the OP does not work.
Of course, it is up to you to go on misunderstanding me and arguing about it. You wouldn't be my first encounter with a professor who was wrong but insisted to be right qua office. Congratulations.
  • #44
fresh_42 said:
Nowhere did I say that 17 is the largest prime in 17^4!
But implicitly, you did say that. This is the message you quoted:
It clearly states "Let ##p## denote the largest prime such that ##p \leq n##", so this is the assumption. You go on to say:
fresh_42 said:
Why? What if n=p^4 for example?
We are still working under the assumption that ##p## is the largest prime such that ##p \leq n## so I cannot read this in any other way than implying that ##n = p^4## where ##p## is the largest prime such that ##p \leq n##.
Context is important.
fresh_42 said:
I (still) claim that 17 is the largest prime in 17^4.
Nobody has disputed this.
It does not, because it does not apply to the OP's context of ##p## being the largest prime such that ##p \leq n##.
  • #45
I observe if n!=M^2 where M is an integer,
n!=\Pi_p p^{2n_p}
where p is all the prime numbers p<n. It means n! consists of all the prime numbers in pairs.
It is obviously impossible if there exists n/2 < p < n at least.
  • #46
It happens that In the (London) Times leaders today
https://www.thetimes.co.uk/article/the-times-view-on-mathematics-living-by-numbers-m2hskf7p0 it is proclaimed:
"The Times view on mathematics: Living by Numbers
Maths is not only useful but elegant and beautiful"
"The Hungarian theorist Paul Erdos proved, at the age of 17, that between any two whole numbers n and 2n there must lie at least one prime." is their example!
So far as I could work out in a quick (Wikipedia) check, Chebyschev had proved the theorem in the 19th century, but Eordos' proof 1932 proof has an elementary character that previous ones didn't - so maybe useful here?
Likes anuttarasammyak
  • #47
Math100 said:
Because there exists a prime p in the prime factorization of the integer 83521 only once, thus p2∤83521!.
p is the largest prime <= 83521, not the largest prime factor if 83521. You had it right the first time.
  • #48
Wrong. ##p=17## is the largest prime factor of ##83521 = 17^4.##
  • #49
Again, this is not what was assumed when the OP introduced ##p##. It is also not what @Prof B said, he was clearly referring to the OP’s assumption. It was introduced as the largest prime ##p\leq n##. Please read this by the OP again:
There is no number on the form ##q^4##, where ##q## is prime, such that ##p = q##.
This is also your post which shows that you do understand the proof - you are just introducing new meanings for p that do not correspond to what the OP introduced:
fresh_42 said:
In my example, we have p=83497 which divides n!=83521!
This is the correct p for n = 83521. p is not 17 because 17 is the largest prime factor in 83521, which is not the same as the largest prime smaller than 83521.
I suggest you take the time to reread the entire thread with this in mind. What @Prof B said was perfectly appropriate with the OP’s assumption.
Again, to recap. OP says:
You say in response:
This statement is incompatible with the OP’s assumption of ##p## being the largest prime smaller than n because ##n = p^4 \geq 8p > 2p## means that there is at least one prime larger than ##p## but less than ##p^4##, violating the OP’s assumption of ##p## being the largest prime sich that ##p\leq n##.
The big problem here is that you are alternatingly using p to denote a prime such that n = p^4 and using it to denote the largest prime factor in n.
Prof B said:
p=83497 is is the largest prime <= 83521, not the largest prime factor if 83521. You had it right the first time.
(Boldface my addition)
I’d say there is no wonder that OP is getting confused by this.
  • #50
Orodruin said:
Again, this is not what was assumed when the OP introduced ...
Guess I made the mistake to confuse prime with prime factor at the wrong places.
