If ## p ## and ## p^{2}+8 ## are both prime numbers, prove that....
If both p and p^2 + 8 are prime numbers, then p must equal 3, as it is the only odd prime that satisfies the condition. For any prime p greater than 3, p^2 + 8 is divisible by 3, making it composite. The proof shows that if p is odd and greater than 3, it leads to a contradiction, confirming that p cannot be anything other than 3. Consequently, for p = 3, p^3 + 4 equals 31, which is also prime. Thus, if p and p^2 + 8 are both prime, p^3 + 4 is guaranteed to be prime as well.
Math100
If ## p ## and ## p^{2}+8 ## are both prime numbers, prove that ## p^{3}+4 ## is also prime.
None.
Proof:
Suppose ## p ## and ## p^{2}+8 ## are both prime numbers.
Since ## p^{2}+8 ## is prime, it follows that ## p ## is odd, so ## p\neq 2 ##.
Let ## p>3 ##.
Then ## p^{2}\equiv 1 \mod 3 ##,
so ## p^{2}+8\equiv 0 \mod 3 ##.
Note that ## p^{2}+8 ## can only be prime for ## p=3 ##.
Thus ## p^{3}+4=27+4=31 ##, which is also prime.
Therefore, if ## p ## and ## p^{2}+8 ## are both prime numbers,
then ## p^{3}+4 ## is also prime.
Math100 said:
Homework Statement:: If ## p ## and ## p^{2}+8 ## are both prime numbers, prove that ## p^{3}+4 ## is also prime.
Math100 said:
Proof:
Let ## p>3 ##.
Why is this true? It's not enough just to assert it.
Relevant Equations:: None.
Proof:
Let ## p>3 ##.
How? You only have that ##p## is odd, i.e. ##p=2k+1## so ##p^2=4k^2+4k+1\equiv k(k+1)+1 \mod 3.## However, you used ##p^2\equiv 1 \mod 3## which is equivalent to ##k(k+1)\equiv 0 \mod 3.## Thus you have to prove: If ##p=2k+1>3## is prime, then either ##k## or ##k+1## is divisible by three. or the other way around: If ##k## and ##k+1## are not divisible by ##3## then ##2k+1## is composite. It is true, but you have to show why.
What if ##p=3##?
This is another strange question. The condition that ##p^2 + 8## is prime only holds for ##p = 3##. That ##3^3 + 4 = 31## is prime seems a fairly random conclusion from ##p = 3##.
What if ##p=3##?
If ## p=3 ##, then ## p^2+8=9+8=17 ##. Thus ## p^3+4=27+4=31 ##. But how should I prove that if ## p=2k+1>3 ## is prime, then either ## k ## or ## k+1 ## is divisible by ## 3 ##? And should I mention/include that if ## p=2 ##, then ## p^2+8=4+8=12 ##. Thus ## p^3+4=8+4=12 ##? This means ## p ## cannot be even, which is why I claimed ## p\neq 2 ## in my previous proof. But you said that I only have that ## p ## is odd. Then I need to show ## p=2 ## doesn't necessarily work for ## p^2+8 ## and ## p^3+4 ##.
Proof:
Let ## p>3 ##.
What you have proved at this point is that if ##p## is a prime number, then if ##p^2+8## is also prime, it must be that ##p=3## .
I said you only have that ##p## is odd, because that is what you deduced from at that point. So ##p=2k+1## for some integer ##k##. If ##k## and ##k+1## are both coprime to ##3## then ##k\equiv 1 \mod 3## and ##k+1\equiv 2 \mod 3##. Therefore ##k=3m+1## for some integer ##m## and ##k\cdot(k+1) = \ldots ## and so on.
Remember that your goal is to show that ##p^2=(2k+1)^2 \equiv 1\mod 3.##
p is not multiple of 2 but OP made use of the fact that p is not multiple of 3 to deduce p^2 ##\equiv## 1 (mod 3), I think.
Maybe it helps the OP to analyze his proof in order to understand how to proofread those deductions.
Condition ##(A)##: ##p## is prime
Condition ##(B)##: ##p^2+8## is prime
Conclusion ##(C)##: ##p^3+4## is prime
This is usually written as: ## (A) \wedge (B) \Longrightarrow (C)##.
An equivalent statement would be: ##\lnot (C) \Longrightarrow \lnot (A) \vee \lnot (B)##
which is in words: If ##(C)## is wrong then either ##(A)## is wrong or ##(B)## is wrong (or both). If ##p^3+8## is composite then either ##p## is composite, ##p^2+8## is composite or both are.
One of these statements has to be shown.
Proof:
This is the direct version of the proof, i.e. ## (A) \wedge (B) \Longrightarrow (C)##.
Since ## p^{2}+8 ## is prime and ##2^2+8=12## is not, it follows that ## p ## is odd, so ## p\neq 2 ##.
Math100 said:
Let ## p>3 ##.
Why?
Better is: If ##p=3## then ##p^3+8=17## is prime and ##p^3+4=31## is also prime. Hence the statement is true for ##p=3## and we are allowed to assume ##p>3.##
Let ##p=2k+1## with ##k>1.## (We already know that ##p## is odd, and we assume ##p>3##.)
Why?
We have ##p^2=(2k+1)^2=4k^2+4k+1\equiv k^2+k+1 \mod 3.## In order to conclude ##p^2\equiv 1\mod 3## we have to show that ##k^2+k=k(k+1)\equiv 0 \mod 3.##
Otherwise, i.e. if ##k^2+k=k(k+1)\not\equiv 0 \mod 3## then ##3## doesn't divide ##k## nor ##k+1## which is only possible if ##k\equiv 1\mod 3 ## and ##k+1\equiv 2\mod 3.## Therefore there is an integer ##m## such that ##k=3m+1.## This means ##p=2k+1=6m+3## and ##3\,|\,p.## As ##p## is prime, we have ##p=3## which contradicts our assumption ##p>3.##
Therefore $$p^2\equiv 4k^2+k+1 \equiv k^2+k+1\equiv k(k+1)+1\equiv 0+1 \equiv 1\mod 3\,.$$
It is here, where the reader can see, why the assumption ##p>3## has been made in the first place.
Why?
Please give us a reason. Hint: Use the fact that ##p=2k+1## and ##k^2+k\equiv 0\mod 3## as seen in the consideration above.
The rest is obsolete. We already dealt with ##p=3## and assumed ##p>3.##
_________
What did we actually prove?
We have shown that if ##p## and ##p^2+8## are both prime, then ##p=3## since otherwise we get a contradiction. So if we set
Conclusion ##(D)##: ##p=3##
then we have shown ##(A)\wedge (B) \Longrightarrow (D).##
Now clearly ##(D) \Longrightarrow (C)## since ##3^3+4=31## is prime, which proves the initial statement.
However, conclusion ##(C)## is a corollary, a present, a gift. We get it on top without any extra work since we have proven the stronger statement ##(A)\wedge (B) \Longrightarrow (D).##
These are the elaborations and considerations you must do in order to prove something. A proof is meant to convince people. In order to convince somebody, including yourself, you have to find a chain of conclusions starting with ##(A)## and ##(B)## until you end up at ##(D).## I wrote ##(D)## because this is what we get. It is much stronger than ##(C)## and we always minimize assumptions and maximize conclusions in mathematics. So ##(C)## is indeed a corollary, not the major statement.
We have actually shown ##p^2\equiv 1\mod 3## for prime numbers ##p>3.## Everything else is a variation of this basic statement. And its shortest proof would have been
p^2-1=(p-1)(p+1)
If ##p>3## is prime, then ##(p-1\, , \,p\, , \,p+1)## contains a number divisible by ##3## which is not ##p.##
This is left if you strip all decorations and deviations.
I gave away this long text to demonstrate what you should try to achieve with your proofs. It is almost a complete solution, so it is what you should have done.
Likes Delta2 and PeroK
But why does "Since ## p^2+8 ## is prime and ## p^2+8>8>2 ##"? Where does ## p^2+8>8>2 ## come from? Also, how does ## p^2=(2k+1)^2=4k^2+4k+1\equiv k^2+k+1 \mod 3 ##? Where does ## 4k^2+4k+1\equiv k^2+k+1 \mod 3 ## come from?
The conditions from post #1 are that both p and ##p^2 + 8## are prime. These two conditions are sufficient to eliminate the possibility that p = 2. I don't see the need for saying ##p^2 + 8 > 8## in order to conclude that ##p \ne 2##.
There is also a typo in the work shown by @fresh_42 in this line:
The equation ##p^3+8=17## should read ##p^2+8=17##.
This is an application of the rules of modular arithmetic, specifically the second property amongst those listed after reflexivity, symmetry, and transitivity. See https://en.wikipedia.org/wiki/Modular_arithmetic.
Likes Math100 and Delta2
I just realized that ## p^2\not\equiv 1 \mod 3 ## for ## p>3 ##. So if ## p=2k+1 ## for ## k>1 ##, then ## p^2+8=(2k+1)^2+8=4k^2+4k+9\equiv k^2+k+3 \mod 3 ##.
Was this a typo? If p = 5, ##p^2 = 25 \equiv 1 \mod 3##. There are many more counterexamples.
Do you read what I write?
p^2-1=(p-1)(p+1)
Likes Math100
Suppose ## p ## and ## p^2+8 ## are both prime numbers.
Since ## p^2+8 ## is prime and ## 2^2+8=12 ## is not,
Assume ## p=3 ##.
Then ## p^2+8=17 ## is prime and ## p^{3}+4=31 ## is also prime.
Thus, the statement is true for ## p=3 ##.
Let ## p>3 ## be an odd prime.
Then ## p\equiv 1 \mod 3 ## or ## p\equiv 2 \mod 3 ##.
Now we consider two cases.
Case #1: Suppose ## p\equiv 1 \mod 3 ##.
Then ## p^2+8\equiv 0 \mod 3 ##.
Thus ## p^2+8 ## is not prime.
Case #2: Suppose ## p\equiv 2 \mod 3 ##.
This means ## p^2+8 ## can only be prime for ## p=3 ##,
so ## p^{3}+4=3^{3}+4=31 ## is also prime.
Therefore, if ## p ## and ## p^2+8 ## are both prime numbers,
Likes anuttarasammyak
p is not 2 because 12 is not prime. Once that is shown the parity of p is irrelevant.
He knows that p is prime, which is much more important.
fresh_42 said:
What if ##p=3##?
He assumed p > 3. For that reason p is not equal to 3.
I
The conclusion that "## p ## is odd" is illogical and irrelevant. It follows immediately that p is not 2. From that you can conclude that p is odd, but it is still irrelevant.
Math100 said:
Assume ## p=3 ##.
oddness is still irrelevant
You don't need cases. Just calculate ## 1^2 \bmod 3 ## and ## 2^2 \bmod 3 ##. They have the same value. What is it? Add 8 and mod by 3. What do you get?
By the way, you should use \bmod for the binary operator so you don't get excess space in front of it. Only use \mod for the congruence relation, i.e., with parentheses.
