If ## p\geq q\geq 5 ## and ## p ## and ## q ## are both primes ....
  • Thread starter Thread starter Math100
    Primes
Math100
If ## p\geq q\geq 5 ## and ## p ## and ## q ## are both primes, prove that ## 24\mid p^{2}-q^{2} ##.
None.
Proof:
Suppose ## p\geq q\geq 5 ## and ## p ## and ## q ## are both primes.
Note that ## p ## and ## q ## are not divisible by ## 3 ##,
so we have ## p^{2}-1\equiv 0 (mod 3) ## and ## q^{2}-1\equiv 0 (mod 3) ##.
This means ## 3\mid((p^{2}-1)-(q^{2}-1)) ##,
and so ## 3\mid p^{2}-q^{2} ##.
Since ## p^{2}-q^{2} ## is divisible by 3, it follows that ## p^{2}-q^{2} ## is also divisible by 24.
Thus, ## 24\mid p^{2}-q^{2} ##.
Therefore, if ## p\geq q\geq 5 ## and ## p ## and ## q ## are both primes,
then ## 24\mid p^{2}-q^{2} ##.
I'd like to see some justification for that! If a number is divisible by ##24##, then it is divisible by ##3##. But not the converse.
This must be the third or fourth problem now where you have failed to factorise a difference of squares. It should be completely automatic by now that ##x^2 - y^2 = (x-y)(x+y)##. Especially in the context of factorisation problems, this should be the first thing you think about.
Likes pasmith and Mark44
The other thing I suspect you never do is write down some examples first to see what's going on. The first thing I did was write down ##25, 49, 121, 169, 289##. Just looking at those numbers gave me a big clue on how to solve this.
I know that ## p^{2}-q^{2}=(p-q)(p+q) ##. But what can we do with this?
Looks for factors of ##2##. There must be a factor of ##2^3## there somewhere!
Also, see post #4.
I know that ## p^{2}-q^{2}=49-25=24 ##,
also ## p^{2}-q^{2}=121-49=72 ##,
and all of these results are divisible by 24.
But how should I express them in terms of solving this in proof?
What's the relationship between one odd prime and the next?
For starters, p and q are odd, so p + q and p - q are even. Now you have 4 as a factor of p^2 - q^2.
Likes PeroK
What do I do from there?
Since ## p ## and ## q ## are odd, it follows that ## p+q ## and ## p-q ## are even.
Now we have ## p+q=2m ## and ## p-q=2n ## for ## m, n\in\mathbb{Z} ##.
Thus ## p^{2}-q^{2}=(p+q)(p-q) ##
=(2m)(2n)
=4mn
=4k,
where k=mn is an integer.
You have that already. You need an additional idea. See post #8.
Likes Math100
Odd primes: ## 5, 7, 11, 13, 17, 19, 23... ##.
Their differences are ## 2, 4, 2, 4, 2, 4... ##.
But note that ## 25 ## isn't a prime, and ## 27 ## isn't a prime either.
So, perhaps, let ##p = q + 2k##.
Likes Math100
If ## p=2k+q ##, then ## p^{2}=(2k+q)^{2}=4k^2+4kq+q^2 ##.
  • Sad
Likes PeroK
You already have ##p^2 - q^2 = (p-q)(p+q)##.
So ## p^{2}-q^{2}=(p-q)(p+q) ##
## =(q+2k-q)(q+2k+q) ##
## =2k(2k+2q) ##
## =4k(k+q) ##.
## =2k(2k+2q) ##
## =4k(k+q) ##.
Nearly there!
Likes Math100
But what does ## p^{2}-q^{2}=4k(k+q) ## have anything to do with ## p^{2}-q^{2} ## being divisible by 24?
You only have to show that ##k(k + q)## is even and that gives you the factor of ##8##. The factor of ##3## you have already found.
Likes Math100
How to show/prove that ## k(k+q) ## is even?
If ##k## is even then you're done!
Likes Math100
Let ## p=q+2k ## where ## k=2m ## is an even integer.
No, I mean if ##k## is even the ##k(k + q)## is even. At this level that should be "obvious", in the sense that it doesn't need to be justified further.
And, if ##k## is odd ...
I found out that if ## k ## is odd, then ## k=2m+1 ## for some ## m\in\mathbb{Z} ##.
Thus ## k(k+q)=(2m+1)(2m+1+q) ##
## =4m^2+2m+2mq+2m+1+q ##
## =4m^2+4m+2mq+q+1 ##,
but ## k(k+q) ## is not odd.
  • Wow
Likes PeroK
If ##k## is odd, then ##k + q## is even.
So that means ## p=2k+q ## where ## q=2m+1 ## for some ## k,m\in\mathbb{Z} ##.
This is not relevant now.
To get back on track we reached this stage:
We need to show that ##k(k + q)## is even, because then ##p^2 - q^2## is a multiple of ##8##. Note that the product of two numbers is even if either number is even. If ##k## is even, then we are done. And, if ##k## is odd, then ##k + q## is even. Either way, ##p^2 - q^2## is a multiple of ##8##.
That should finish the proof.
Likes Math100
Alternatively, k(k+q) \equiv k(k+1) \mod 2 and a product of successive integers is even.
Okay, so here's my revised proof:
This means ## 3\mid ((p^{2}-1)-(q^{2}-1)) ##, and so ## 3\mid p^{2}-q^{2} ##.
Let ## p=2k+q ## where ## q=2m+1 ## for some ## k, m\in\mathbb{Z} ##.
Then we have ## p^{2}-q^{2}=(2k+q)^{2}-q^{2} ##
## =4k^2+4kq+q^2-q^2 ##
## =4k^2+4kq ##
## =4k(k+q) ##.
Now we consider two cases.
Case #1: Suppose ## k ## is an odd integer.
Then we have ## k=2n+1 ## for some ## n\in\mathbb{Z} ##.
Thus ## k(k+q)=(2n+1)(2n+1+2m+1) ##
## =(2n+1)(2n+2m+2) ##
## =4n^2+4mn+4n+2n+2m+2 ##
## =2(2n^2+2mn+3n+m+1) ##
## =2t ##,
where ## t=2n^2+2mn+3n+m+1 ## is an integer.
Case #2: Suppose ## k ## is an even integer.
Then we have ## k=2n ## for some ## n\in\mathbb{Z} ##.
Thus ## k(k+q)=2n(2n+2m+1) ##
## =2(2n^2+2mn+n) ##
## =2s ##,
where ## s=2n^2+2mn+n ## is an integer.
Since ## k(k+q) ## is even in both cases,
it follows that ## 8\mid p^2-q^2 ##, so ## 24\mid p^2-q^2 ##.
then ## 24\mid p^2-q^2 ##.
  • #31
That's far too long. You only need ##p = q + 2k##. You don't need the rest of those variables. To do something rigorously you don't need to write out every detail.
You seem so focused on the details that you forget the ideas involved and what is important.
Likes Orodruin and Math100
