If tension provides the torque to this pulley, what is its equation?
The discussion focuses on the equations governing the motion of a pulley system with a hanging bucket. The initial equations presented include tension, linear acceleration, and angular acceleration, but there is confusion regarding the use of symbols for acceleration. It is clarified that the linear acceleration should be denoted as "a" while angular acceleration is represented by "α," emphasizing the need for consistent notation. Participants recommend working with symbols rather than numerical values until the final expression is derived to avoid errors. The approach to solving the problem is deemed correct, provided the notation is properly aligned.
haseebaslam
A bucket of weight 15.0 N (mass of 1.53 kg) is hanging from a cord wrapped around a pulley. The pulley has a moment of inertia of pulley=0.385 kgm^2 (of radius R = 33.0 cm). The cord is not stretched nor slip on the pulley. The pulley is observed to accelerate uniformly. If there is a frictional torque at the axle equal to, =1.10Nm. First calculate the angular acceleration, α, of the pulley and the linear acceleration of the bucket.
a = α*radius
Net Torque = I*angular acceleration
15 - Tension = 1.53*a
T = 15 - 1.53*R*α
T*0.33 - 1.10 = Iα
Is this approach correct?
haseebaslam said:
Homework Statement: A bucket of weight 15.0 N (mass of 1.53 kg) is hanging from a cord wrapped around a pulley. The pulley has a moment of inertia of pulley=0.385,m^2 (of radius R = 33.0 cm). The cord is not stretched nor slip on the pulley. The pulley is observed to accelerate uniformly. If there is a frictional torque at the axle equal to, =1.10⋅m. First calculate the angular acceleration, α, of the pulley and the linear acceleration of the bucket.
Relevant Equations: a = α*radius
15 - Tension = 1.53*α
T = 15 - 1.53*r*α
T*0.33 - 1.10 = Iα
Always start with an extended FBD...
You have
##15 - T = 1.53 a##
and
##T = 15 - 1.53ra##
Is the "a" in this second equation supposed to be an ##\alpha##?
-Dan
Likes haseebaslam
Some problems with the units. Is the MoI of the pulley 0.385 kg m2?
Is the frictional torque 1.10Nm?
Your first equation has force on the left, mass/time2 on the right, but I see you corrected that in the next line.
But your approach looks right.
Likes topsquark and haseebaslam
You have
##15 - T = 1.53 a##
and
##T = 15 - 1.53ra##
-Dan
Sorry about that, the a in my first equation is for linear acceleration. In the second equation, I substitute linear acceleration to get angular acceleration in the equation.
Angular acceleration is ##\alpha## (alpha) and the relation is ##a=\alpha r.## Do you see the difference between the symbols for Greek ##\alpha## and Latin ##a##?
So if you wish to substitute, you should write ##T=15-1.53r\alpha##, not ##T=15-1.53ra.##
Note: I highly suggest working with symbols rather than values until you reach a final expression for whatever you wish to compute. Inserting numbers at an early stage makes it less clear where things come from and makes it harder to check for errors. You also run the risk of introducing rounding errors down the line. Only insert numerical values at the very end.
Likes jim mcnamara and topsquark
  • · Replies 23 ·
  • · Replies 18 ·
  • · Replies 22 ·
13K
