If the air temperature were the same as the human body's....
In summary: Since it feels slightly hot, I can presume the temperature of the skin is lower than average body temperature.Not necessarily. The fan may be blowing colder air than your skin, because it's moving air through colder air.
Nantes
54
Damn title character limits.
I just had the weirdest thought while rearranging my computer's case fans. I put my hand in front of one of them and felt a light breeze of air, telling me it was working. This is due to the local cooling produced where the fan's airstream comes in contact with the skin. Since the air being blown is at a lower temperature than the human body, that local skin cooling triggers my sensory neurons, my skin feels slightly cold and thus I know there's air flowing against it. But what if the air were the exact same temperature as my skin? No heat transfer would occur and my neurons would not be activated. Thus, I can only think of two other mechanisms by which I could perceive the fan if I were not looking at it nor hearing it: perhaps the moving air slightly disturbs the hairs on my skin, which trigger sensory neurons of their own, OR the airstream would be strong enough to actually push my skin. The latter case is obviously not true with 120 mm case fans.
Assuming my hair sensitivity theory is correct, if the fan were functioning in a low enough setting so that the airstream's speed did not disturb the hairs, it stands to reason that the fan would be completely undetectable if the air temperature were the same as my body's. I would not be able to feel it blowing air at all.
It's quite a perturbing thought, no?
Science news on Phys.org
Not necessarily. Air flow increases evaporation, which can cool even if the temperature is higher than your body temperature.
That happens.
If the airflow is too weak, you don't feel it. That is not very surprising I think.
Likes Ravi Singh choudhary
Yes, I'm more interested in whether equalizing air temperature would make undetectable a previously-detectable fan.
Your evaporation comment makes sense. I've noticed though that ceiling or table fans very rapidly lose their subjective cooling effect when the air temperature is very hot. I live in Brazil, and during heat waves I feel like using a fan is actually like blowing hot air at you, making the heat feel worse. Perhaps the evaporation effect only works to an appreciable degree if one is actually sweating.
I doubt that. Maybe some fan with extremely hot or cold air and very weak air flow.
Nantes said:
I would assume the evaporation effect would only work if I were actually physically sweating, as opposed to just having microscopic water droplets on my skin which (I think) is usually the case.
This is easy to test - air from your lungs has body temperature to a good approximation. It also has a high humidity, so air from a fan at the same temperature feels colder.
Since it feels slightly hot, I can presume the temperature of the skin is lower than average body temperature. Not a very valid test.
Related to If the air temperature were the same as the human body's....
1. How would the human body react if the air temperature were the same as its own?
If the air temperature were the same as the human body's, the body would not be able to effectively regulate its internal temperature. This could lead to overheating, dehydration, and other health issues.
2. Would it be dangerous to be in an environment where the air temperature is the same as the human body's?
Yes, it would be dangerous to be in an environment where the air temperature is the same as the human body's. As mentioned before, the body would not be able to regulate its temperature and could lead to serious health risks.
3. How would this affect our daily activities and routines?
If the air temperature were the same as the human body's, it would greatly impact our daily activities and routines. We would not be able to function normally and would have to constantly seek out cooler environments to avoid overheating.
4. Can the human body adapt to an environment with the same air temperature?
No, the human body is not able to adapt to an environment with the same air temperature as its own. Our bodies are designed to function within a specific temperature range and any significant change can lead to health problems.
5. How does the body maintain a constant internal temperature in different environments?
The body maintains a constant internal temperature through the process of thermoregulation. This involves mechanisms such as sweating, shivering, and changes in blood flow to different areas of the body to regulate heat loss and retention.
  • Thermodynamics
  • DIY Projects
  • Biology and Medical
  • General Engineering
  • Thermodynamics
