If the centrifual force does not exist then why?
  • Thread starter zeromodz
  • Tags
    Force
In summary: The problem with recognizing two distinct physical tendencies here: 1) centripetal forces such as gravity, which attract matter toward a center; and 2) Inertia, by which objects in motion tend to move in a straight line except when acted upon by another force. Objects revolving around an axis have inertia that causes them to tend to remain in (linear) motion tangential to the path of their orbit. Yet they are centripetally forced toward the center by whatever binds them to it, whether gravity or a rope or the resistance of joints to let go of their sockets.In summary, the centrifugal force causes objects to flatten out in space where there is little friction, and it is explained as
zeromodz
246
If the centrifugal force does not exist, then why in space where there is little friction do spinning objects tend to flatten out. Like Jupiter's rings for instance, they are sooo thin. What makes them so thin. The only thing I can think of is the centrifugal force flattening it out.
Centrifugal force = mrw^2
Generally, I think what you are calling "centrifugal force" is explained as momentum/velocity in the opposite direction as a centripetal force due to motion.
I'm not sure why the rings of a planet flatten out but might it have to do with the gravitational field of the planet rotating along the planet's axis? Are there any planets with rings that aren't perpendicular to the axis of rotation?
It's a good question. I hope someone has an answer for it.
When they say that the so-called centrifugal force is fictitious, they don't mean that it doesn't exist -- they mean that "force" isn't the correct word to describe the effect. There is no external agency pulling on the object in the outward direction by applying a force to it. The tendency of mass to move in a straight line is producing the effect.
You're referring to the centripetal force, not the centrifugal force, and it is very real. What happens when you go around a curve in your car? You feel a force pulling you to the outside of the curve. That's exactly why planets are fatter around their belt and why rings form.
Words "fictitious force" mean that it is a real force, but it only manifests in certain coordinate systems. More specifically, accelerated ones.
If you go to coordinate system which rotates with object in question, you have to add centrifugal force to account for dynamics.
If you are in an inertial coordinate system, there is no need for centrifugal force to describe what's going on. If you account for all the forces acting on particles forming the rings, you will get the correct dynamics without including centrifugal force into consideration.
There's also the laymans (non-physicsist) version of the term centrifugal force, which refers to the reaction force due to centripetal force. The issue physicists have is using the term centrifugal force to describe the reaction force (which is a real force). As long as it's qualified as a "reactive centrifugal force" then there should be no confusion. Wiki article:
http://en.wikipedia.org/wiki/Reactive_centrifugal_force
What is the problem with recognizing two distinct physical tendencies here: 1) centripetal forces such as gravity, which attract matter toward a center; and 2) Inertia, by which objects in motion tend to move in a straight line except when acted upon by another force. Objects revolving around an axis have inertia that causes them to tend to remain in (linear) motion tangential to the path of their orbit. Yet they are centripetally forced toward the center by whatever binds them to it, whether gravity or a rope or the resistance of joints to let go of their sockets.
FAQ: If the centrifual force does not exist then why?
If the centrifugal force does not exist, then why do objects move away from the center of rotation?
The perceived force that causes objects to move away from the center of rotation is actually a result of the inertia of the object. Without a force acting on it, an object will continue moving in a straight line. In the case of circular motion, the object is constantly changing direction, causing it to appear as though a force is pushing it away from the center.
If the centrifugal force does not exist, then how do we explain the feeling of being pushed outward on a spinning ride?
The feeling of being pushed outward on a spinning ride is actually due to the centripetal force, which is the force that keeps the object moving in a circular path. This force is provided by the ride itself, and as the ride spins faster, the centripetal force increases, making it feel like we are being pushed outward.
If the centrifugal force does not exist, then why do we use it in calculations and equations?
The concept of centrifugal force is often used in calculations and equations to simplify the analysis of circular motion. While it is not a real force, it can still be a useful concept in understanding the dynamics of rotating systems. However, it should always be kept in mind that the perceived centrifugal force is actually just a result of other forces acting on the object.
If the centrifugal force does not exist, then why does it appear in Newton's laws of motion?
The centrifugal force is sometimes included in Newton's laws of motion to account for the apparent forces that are observed in rotating frames of reference. However, this is only done for convenience and it does not mean that the centrifugal force is a real force in itself. Newton's laws of motion still hold true, even in the absence of a centrifugal force.
If the centrifugal force does not exist, then how do we explain the force that objects experience when traveling around a curve?
The force that objects experience when traveling around a curve is again due to the centripetal force. As an object moves along a curved path, it is constantly changing direction and the centripetal force is needed to keep it moving in that path. This force is provided by the object's own inertia or by some external force acting on it.
